Old 04-17-2012, 03:16 PM   #26
Firebirdjones
Re: 1989 Suburban with 5.3LS/700R4
Interesting swap. I'm a 6.0 fan myself but that 5.3 should work nice for you. Too bad they didn't swap in a 60E instead of that 700, then you would have total control of both the engine and trans with simple key strokes
It will take alot of trial and error on the 700 to get the shift points in a happy spot for that 5.3.
If you had HPtuners I could send you a stock 5.3 tune file so you could flash that in to start with. I can tell you though they need alot of time tuning and tweaking to optimize even a stock engine.
Neat truck, and a good deal considering the coin it takes to do an LS swap and do it right. You'll have some fun with that.
Firebirdjones is offline   Reply With Quote
Old 04-17-2012, 03:16 PM   #27
2ndGenRR
2ndGenRR's Avatar
Originally Posted by Edahall View Post
The 10 bolts should hold up fine but anything can be broke by someone who tries hard enough. However, lower ratio gear sets are inherently weaker than the higher ratio gear sets. Where it would get you is if you into heavy pulling.
Have you noticed any fuel economy differences with the change?
No heavy pulling with this 'burb, I use my '06 3/4 ton 'burb for pulling. Haven't run enough fuel through it yet to notice a fuel economy change, but I have to believe it's going to be better without all the downshifting. I'm buzzing down the highway at 70 and only running 2200-2300rpm.
The Stable:
1952 GMC 1/2 ton, 5-window...Owned since age 16...that was awhile ago! Torn apart and waiting for my boys to get old enough to help me.
1990 Chevy K5, 5.3L, 4L60E, slowly going back together as my dune truck.
1951 Chevy 1/2 ton, 3-window...building to sell.
Daily Drivers: 1998 3/4 ton Burb with a 6.5 Turbo Diesel and 1994 1/2 ton Silverado.
I grew up in Flint, Michigan so I can't help but to bleed Chevy!
2ndGenRR is offline   Reply With Quote
Old 04-17-2012, 03:22 PM   #28
2ndGenRR
2ndGenRR's Avatar
Firebirdjones - Yeah, the 6.0L would be more fun, but now that an LS engine has been swapped into this truck I can always swap to another LS at some point or even go with a power adder of some sort.
For this summer, I'm just going to drive the wheels off it and see which direction I want to go from there.
The Stable:
Old 04-17-2012, 03:56 PM   #29
Firebirdjones
Very true, now that the hard work is done, another swap is cake.
Like you mentioned, I'd enjoy it as is for a while. There is alot to be found in the tune on these things. Those little 5.3's are pretty snappy for their size, and a stock tune leaves about 20-25 hp on the table. That might be enough to persuade you to keep it.
Old 04-17-2012, 08:21 PM   #30
Edahall
You could also bolt on a supercharger for a lot more power.
Edahall is offline   Reply With Quote
Old 04-17-2012, 10:03 PM   #31
2ndGenRR
2ndGenRR's Avatar
I was thinking STS rear-mounted turbo...see how fast I can find the limits of that 700r4!
The Stable:
Old 04-17-2012, 10:38 PM   #32
Firebirdjones
Yep, I have a maggie sitting here for the 6.0.
Old 04-17-2012, 10:39 PM   #33
Firebirdjones
Old 04-18-2012, 06:33 AM   #34
justpball
justpball's Avatar
Very nice truck bro!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 04-18-2012, 08:30 AM   #35
2ndGenRR
2ndGenRR's Avatar
Thanks justpball - Your truck is way sweet...saw that you bodydropped it earlier this year...lots of work going low!
The Stable:
Old 04-18-2012, 10:50 AM   #36
justpball
justpball's Avatar
Thanks! It is a lot of work... LOL
87 Crew SWB
Build for the crew
90 burb 2wd
Old 07-17-2012, 11:23 AM   #37
2ndGenRR
2ndGenRR's Avatar
Hey Guys - thought it was time to drop an update.
So, one afternoon my buddy and I decide to head to another buddies house and drag up the sandhill at the back of his property. Had a great time and I actually beat his big-block K20 a couple of times. Afterwards we sit around enjoying a few barley pops until it's time to head home. The wives of course, don't want us driving because of the barley pops (yes, they are smarter than us), so we load up with the wives at the wheel. They decide to drag up the hill...my wife wins and also pops the head gasket on my 5.3 while standing on the rev limiter...doh!
That's the bad news...the good news is that she feels really bad about it and I get the green light to spend some dough on a new engine, because you know those head gaskets are really hard to fix...
I was looking for a 6.0 until I called the local speed shop and they happen to have a 5.3 that has already had all the good upgrades and dyno tested at 450hp. They made me a good deal on it, so I dropped the 'burb off at their shop and they are swapping the engine for free in exchange for me showing the 'burb in their booth at the Metro Cruise in August (the Grand Rapids version of the Woodward Dream Cruise).
I'm really looking forward to getting it back, but I'm going to have to take it easy with the 10-bolts and 700r4. Should be a bunch of fun at the Silver Lake Sand Dunes as long as I roll into the gas...
The Stable:
Old 07-17-2012, 01:09 PM   #38
68Timber
I know the pieces fit
68Timber's Avatar
Congrats on the wifey participating in the hobby, some of us only wish!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 07-17-2012, 01:52 PM   #39
2ndGenRR
2ndGenRR's Avatar
You have no idea...she's a total speed demon. She doesn't like my '50 Chevy Sedan because it's too slow!
The Stable:
Old 07-17-2012, 10:44 PM   #40
turbo350
Sounds like a fun truck. Curious what were you getting for fuel mileage on the freeway with your set-up.
turbo350 is offline   Reply With Quote
Old 07-18-2012, 08:28 AM   #41
2ndGenRR
2ndGenRR's Avatar
I don't know...never got the chance to check it after the gear swap. Prior owner claimed he was getting close to 20mpg...which I'm skeptical about. I would guess closer to 16-17mpg.
The Stable:
Old 07-18-2012, 10:28 AM   #42
Firebirdjones
I'd bet the previous owner wasn't kidding on the fuel mileage, considering this is a larger burb.
I installed a 6.0 in my blazer with a 4L60 and it routinely gets 17 mpg city and 22 mpg highway with 3.73's and 33" tires.
Old 07-18-2012, 10:48 AM   #43
Edahall
That 20 mpg figure would easily be possible at 55 mph. After between 60-65 mph, these boxy trucks start to really suck fuel. On my old 1982 Suburban with the 6.2 diesel, I would lose 9 mpg driving 75 mph vs 60 mph.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Old 07-18-2012, 05:20 PM   #44
WarBeard
WarBeard's Avatar
Lockers IMO are what kills the ten bolt in offroad situations. If you have an open diff then you should be ok. Your front ten bolt (Going by the year) will be a 30 spline wich is the strongest of the ten bolts. I run 37''s on my 30 spline 10 bolt and all I ever brake is the U-joint I have never actually broken the axle itself. You can still drive home on this.
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 07-18-2012, 06:28 PM   #45
Firebirdjones
I cruise at 70 mph to get those figures I posted with my 6.0 in my 72 blazer 4x4. The 4L60 overdrive keeps the rpms reasonable even with 3.73's.
My 79 1 ton pickup with a 502/400 turbo and 3.73's gets 14 mpg if I keep it at 65 mph (about 2800 rpms). With the gear vendor going in I should pick up another 2-3 mpg
It's all in the tune...
