04-24-2012, 11:31 PM | #201 |
60-66 Nut
Re: Power Steering Adapter Plates
Sent you a PM.......
05-16-2012, 04:05 PM | #202 |
I have a 68 K-10. i want PS! Can you provide a list of everything I need to make this happen. Will buy your plate and rag coupler if needed. Want to keep old steering colum.
05-16-2012, 11:14 PM | #203 |
60-66 Nut
1) You will need a '68-'87 K series, or '88-'91 V series steering box and the pitman arm.
2) You will need the correct draglink for the front axle you are running. 3) You will need a power steering pump, brackets and pulleys for the engine you are running. 4) You will need the appropriate belt to drive the pump, and also the pressure and return lines from the pump to the box. 5) You may need a new rag joint, depending on whether you get a good one with the box or not. 6) There is bound to be some miscellaneous nuts, bolts, washers, clamps, fittings, etc. that you may need. 7) You will need an adapter plate to mount the box to the frame. The tube and flange will simplify the connection to your original steering column shaft.
05-17-2012, 12:53 PM | #204 |
I thank you sir! Does your plate work with the suggested boxes and could you clarify #7 about the the tube and flange?
05-17-2012, 11:02 PM | #205 |
60-66 Nut
Yes my power steering box adapter plate works with that year range of steering box....that is what it is designed to work with. The tube and flange allows you to connect your original steering column shaft to the power steering bos without having to weld. I'mnot sure on the '67-'68 4wd's. but if it is the same as the 2wd's your steering column shaft is already the correct length. So you may not need the tube and flange. This steering box adapter and the tube and flange was designed specifically for the '63-'66 trucks, so your situation will be a little different.
06-01-2012, 12:58 AM | #206 |
newbie here! i want everything i need to do the conversion? i got a 1963 chevy c10 stepside? what do i need and got any pics of the process, sorry im new to this
06-01-2012, 02:21 AM | #207 |
60-66 Nut
Post #203 above lists everything you will need. I don't have pics handy at the moment, but those are a part of the installation instructions.
06-07-2012, 09:18 AM | #208 |
I have a 67 K10 that I would like to install power steering on. Could you pm me the info I need to order your plate? Thanks, Jeff
Posted via Mobile Device |
06-07-2012, 10:48 PM | #209 |
60-66 Nut
I replied to your PM Jeff.
06-11-2012, 12:59 AM | #210 |
Hi, I'm new here.
I would like to order one of your adapter plates for my 1965 Chevy C20. Thanks! Posted via Mobile Device |
06-11-2012, 01:43 AM | #211 |
60-66 Nut
I'll send you a PM with payment details.
07-01-2012, 09:57 AM | #212 |
Would like to know everything you have currently available for purchase for a power steering conversion. Please let me know parts, pricing, and payment requirements. Thanks for the help.
07-01-2012, 11:19 PM | #213 |
60-66 Nut
Did you receive my reply to your PM a couple weeks ago about this?
What I have to offer is shown in this thread. The power steering box adapter plate and the tube and flange. I do not sell complete conversion kits. I see no sense in paying shipping on those heavy parts, such as the steeing box, that you can easily purchase locally either used or new. The pricing is still the same as in post #1 & #137. If you purchase both the plate and the tube and flange, the shipping is still $10.00. For payments I accept PayPal and money orders. Let me know if this will work for you and I can get these parts on their way.
07-02-2012, 09:17 AM | #214 |
Thanks for the info - just wanted to make sure there weren't any new parts that were offered that I didn't know about.
I didn't receive a PM - that's why I waited a while - then posted here. Sorry for the redundancy. I appreciate the help - will be ordering soon. Posted via Mobile Device |
07-03-2012, 02:18 AM | #215 |
Need to get one of your ps box adapter plates for our 66 burb, please forward paypal info when ya get a chance.
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
07-03-2012, 03:53 PM | #216 |
60-66 Nut
Thanks for the purchase
07-03-2012, 04:15 PM | #217 |
John,
Thank you! I could have easily fabbed up one of these plates, but your plate is a clean, well-designed, set-up that will definately save me time we don't have. Additionally, as we researched how to drop a BBC into our burb, I constantly came across tips, ideas, and shortcuts from you on every aspect of this conversion. THANKS for all the help you give this community!
07-05-2012, 03:16 PM | #218 |
Any progress on the 60-62 bracket?
07-06-2012, 12:00 AM | #219 |
60-66 Nut
Sorry but no. Just no time with working 75-80 hrs a week right now. Hopefully in a couple months.
07-14-2012, 10:31 PM | #220 |
I couldn't agree more. I really appreciate the help, and the brake booster bracket that I bought from you is top notch quality!
PM inbound for a Power Steering bracket and tube and flange. Posted via Mobile Device
66 Chevy C10 Stepside LWB My Build Thread 75 Harley FLH 84 Mercedes 300TD Diesel Wagon |
07-14-2012, 11:01 PM | #221 |
60-66 Nut
Thanks for the compliments guys
I replied to your PM Kevin
07-21-2012, 08:55 AM | #222 |
Ordered my parts - received them within a couple of days. Great quality and great service. Thanks for all the help.
07-21-2012, 11:03 PM | #223 |
60-66 Nut
07-27-2012, 04:37 AM | #224 |
Cap'n great job on the plates, thanks.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
08-08-2012, 10:40 PM | #225 |
Captainfab, you have a PM. Thanks.
