Old 08-04-2012, 01:48 AM   #1
bmnk
bmnk's Avatar
Help identify what this is / was used for...
So I've finally begun my 50' 3/4ton project, and as I was looking over the truck the other day I noticed something that I had previously overlooked.
I'm not sure if it was something that a previous owner added, or if this was from the factory. Either way I can't figure out what it would have been used for. It might be something obvious, but for the life of me I can't figure it out.
bmnk is offline   Reply With Quote
Old 08-04-2012, 08:04 AM   #2
Russell Ashley
Russell Ashley's Avatar
Re: Help identify what this is / was used for...
That was most likely a mount for a mirror. Doesn't look factory to me but that is about where the factory mirror was mounted.
Russell Ashley is offline   Reply With Quote
Old 08-04-2012, 10:33 AM   #3
mknittle
mknittle's Avatar
Aftermarket mirror. And they often bend or break the metal around the base.
On the optional{GM} mirror the screws are farther apart. look under the dash at the inside of the cowl you will see a sheet metal backer with 2 holes in it that is where tha mirrors mount. The passanger side morror was an option.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 08-04-2012, 11:17 AM   #4
mr48chev
mr48chev's Avatar
Yep, a big mirror. You can look at those brackets on five trucks and no two of the will be mounted exactly the same on the right hand side. I think they flipped a left hand bracket and bolted it on.
Usually they were on the 1 tons and up and both of my 1-1/2 ton cabs have that bracket.
mr48chev is online now   Reply With Quote
Old 08-05-2012, 02:22 PM   #5
sweet70beast
sweet70beast's Avatar
I agree. The ones I have seen have usually been on the bigger trucks, most of them still had the mirrors and arms on them.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
