70+ ( Old Skool Club )
![]() Join Date: Nov 2003
1972 GMC Parts
I'm not sure where to post this but am sure it would get punted real quick off the parts for sale thread. I am seriously considering buying this 71 GMC to get the seat for my truck. What Is the 292 and posi leaf spring rear end or any other parts worth off this truck.The seller says the truck was running when parked outside in the North 40 10 years ago.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Roadtrip!
![]() Join Date: Feb 2003
Re: 1972 GMC Parts
I would guess the rear at about $250. Probably a little more if coil sprung.
The power steering i would put around $300 (complete) Maybe $75-$200 on the engine depending on if it runs and how good. Looks like a good truck!
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: 1972 GMC Parts
Thanks Eric, you are the man that should know. Is the Full Foam Seat an upgraded seat with better foam.
Re: 1972 GMC Parts
Yes,the full foam seat is a nice comfortable upgrade. The complete rear would be of most value to a GMC guy or Chevy with leaf option. I don't see too many changing from leaf to coil,so it would be worth the same as a coil,but only to a rear leaf truck owner. I'd put it at $300 because that's the least I see posi rears offered for here. Any 12-bolt can use the posi unit itself and I see those go for about the same alone.
The 292 should be offered with the crossmember,unless the buyer already has a 292 equipped truck. The price will vary,but at least $300 I'd think. You could put together quite a package with the p/s and asks considerably more. Just an FYI,although the factory pinstripe is a really cool option on that truck,you won't be able to remove it for use on another truck ![]() Looks like that left rear wheelcover is a cheezy aftermarket knock-off that used to be available. So,this truck parked well when running? ![]()
#5 | |
Re: 1972 GMC Parts
