#51 |
Re: Windshield gasket blues: Precision supplies Steele and possibly Soff Seal
This is not the thread i wanted to open up first thing in the morning!!!
I HAVE to get my windshield replaced before February for inspection. Since i dont have the trim, hopefully it goes pretty smooth. Will have to see if there is a safelite around here...... |
#52 | |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Be sure and use a Precision gasket. We have them in the rubber and weatherstrip section of our website. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys Last edited by Classic Heartbeat; 11-30-2011 at 09:53 AM. |
#53 |
I had the windshield replaced on my '72 Cheyenne Super 10 (with trim) a couple of months ago using a Steele gasket. The glass shop injected sealant all the way around under the exposed lip on the outside of the glass as well as in the track that fits to the pinch weld. When installed, the gasket fit perfectly to the body, and I mean absolutely perfectly - no puckering, no stretching. And there were no leaks. Now there are leaks all along the bottom. The water is getting in around the glass, not the body.
I brought the truck back to the glass shop today and they figured out the sealant under the lip was no longer stuck to the Steele gasket, but was still stuck to the windshield. He suggested smearing a thin line of sealant around the gasket on the outside claiming I will barely see it. I'm not thrilled with that idea, as it seems half-assed and not stock, but more importantly, I'm still wondering why the sealant let go of the rubber and what should/could have been done differently? Did the rubber have some kind of coating on it? Is it too late to use a different sealant under the rubber if it can be cleaned properly with the glass in place? What should it be cleaned with? I hate to start over with such a nice fit.
1972 Cheyenne Super 10 LWB 1965 Nova SS Evening Orchid 1967 Nova Wagon Factory Disc (1 of 565), 327/PG 1964 Ford Fairlane 500 HT 1962 Nash Metropolitan Convertible (Wife's car) Last edited by 67L30WGN; 03-16-2012 at 03:18 AM. Reason: Additional question |
#54 | |
I used a precision gasket with an OEM windshield, and here in rainy washington it started leaking around the the window as well. So I put a thin bead of the highest quality clear sealant around the perimeter of the gasket... both edges. You can't tell it's there unless you look really close because I kept the bead about the width of a pen nub. No leaks. |
#55 |
That's encouraging. Thanks. Still wondering about the details as this is clearly not how leaks were intended to be stopped.
1972 Cheyenne Super 10 LWB 1965 Nova SS Evening Orchid 1967 Nova Wagon Factory Disc (1 of 565), 327/PG 1964 Ford Fairlane 500 HT 1962 Nash Metropolitan Convertible (Wife's car) |
#56 |
I was under the impression that leaks were expected by GM. They designed drain holes in the corners of the dash where it meets the bottom edge of the windshield.
#57 |
GM used a white sealant on the bottom and up the sides 6-8" and black butyl at the top outside on the flange. That's why original windshields didn't leak. The drain holes are for water that gets in the cowl area.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 03-17-2012 at 10:40 AM. |
#58 |
I had mine replaced last summer with a Precision seal with no problems. Most installs nowadays are urethane glue ins so it's important to get an experience tech who knows how to do these older style jobs.
#59 | |
Keith, did you ever get anymore info about this? I should try it.
project: "my happy mess" |
#60 |
Carpe manana
![]() ![]() Join Date: Dec 2010
VICTORY!!!!!!
With OEM 71-72 windshield trim and a new matching Precision gasket the install was completed IN UNDER ONE HOUR with no difficulty. My recommendation: Use OEM windshield trim and DO NOT waste $$$ on repro trim.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#61 |
What do you mean by this? "new matching Precision gasket"
#62 |
Carpe manana
Means we cut the existing Precision gasket to spare possible windshield damage and replaced that gasket with a new Precision gasket correct for 71-72 trim. There are two possible gaskets for use with windshield trim: one for the shallow 71-72 trim style and a second for the deep 70 and earlier trim style.
#63 |
C/10 junkie
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#64 |
yeah i replaced my on a 69 with a 72 shield, and trim. but the gasket was for a earlier truck. the trim would not stay in. then i figured out the i was using the wrong trim so i pulled an earlier trim set up out of storage and installed it on the wind , then installed the window with the help of my friend a rope cord , and some soapy water. we had it installed in 10 min. My advice just go with the earlier style trim it has a bigger lip on it so it seems to stay in the gasket better then the 71-72.
Good luck.
ORTEGAMOTOR |
#65 |
![]() Join Date: Sep 2007
deadhead, i was just going to tell you i have 67-70 trim sittin in my garage if you needed it but you got it installed.....good for you!!!
1967custom |
#66 |
Carpe manana
Thanks Mike! If you need similar work go see Sean at Lomas Auto Glass..he went the extra mile for me where other glass guys flaked. Pete
#67 | |
Okay, still at a loss - why do you mention OEM? Precision isn't the OEM.
#68 | |
Carpe manana
Reproduction trim is, in my experience, a total waste of money so go with good used OEM windshield trim when you can but be sure to get the gasket that fits whatever year trim you use.
#69 |
Ah, I wasn't reading it right. Thanks. I have my OEM chrome trim still, and learned, as others have mentioned, 71-72 chrome trim is smaller than earlier models - requiring a specific windshield gasket.
#70 |
Tech Help
![]() Join Date: Apr 2012
The Precision weatherstrip seals have been in the auto glass market for years, almost 2 decades in fact and the only issues I've dealt with in regards to customers are #1, the customer trying to use aftermarket trim and #2, ordering the wrong seal for the trim they have, shallow versus deep set trim.
PRECISION Updates Subscribe --->Installation Videos Follow ------->Instagram Like---------->Facebook |
#71 |
Great to hear, thanks for joining the discussion. Nice to hear the positive comments since I have both windshield and door Precision gaskets yet to install.
#72 | |
Tech Help
-d
#73 |
Thanks d, more pics just added.
#74 | |
One of the First
![]() Join Date: Jan 2000
Thank You
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
#75 |
Carpe manana
On a different but related note: I'd like to advocate for better vent window seals. The aftermarket vent seals I installed (unsure of brand) began to crack in less than 6 months. It's a lot of work to redo the vent windows just to have the rubber breakdown that fast. The factory seals get stiff but don't seem to crack. If Precision can manufacture vent seals from a rubber compound similar to the windshield gasket maybe that would solve the problem and win a lot of customers. Thanks, Pete
