08-24-2012, 11:31 PM | #1 |
Re: 1965 C-10 LS build
Thank you for the complement. I just took a look at your truck. WOW hope mine turns out even half of what yours looks like. Great Job.
This is my Build A 5.3L 1965 C-10 Fleetside http://67-72chevytrucks.com/vboard/s...d.php?t=502100 |
08-27-2012, 03:45 PM | #2 |
09-14-2012, 10:34 PM | #3 |
A little update. With most of the mechanical work done its time to work on the body. Not my favorite thing to do but it needs to get done. I finished up the rear roll pan and the reverse lights in the roll pan.
The other major issue was the drivers side cab corner. The previous owner changed it but it was touching the bed edge when I put the bed on the truck. The passenger side was fine the drivers touched. After I cut the old corner off and went to put on the new corner I did not fit very good. The corner stuck out the back of the cab about 1/2 of an inch. I guess it was not the previous owners fault on the first try. These after market parts really s@&k. I had to section out about 1/2 of an inch. Below is a picture of what had to be removed. Posted via Mobile Device[/QUOTE][/QUOTE] After that cut I had to cut the back side of the new corner and bend it down to make if fit with the rear of the cab. Then filled it in with a piece of metal. Posted via Mobile Device Well got that finished and ready for primer. Also blocked sanded the door and will prime the both in the morning. Well I was going to post a picture of the final sanding before primer but the photo bucket doesn't like me tonight. That's it for now have a great night. Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
12-06-2012, 01:26 AM | #4 |
It's been a while since the last post. So a little up date. Pulled the motor and trans out and put them in the corner for now. I was able to get the hood own and it fits good. Just finished a little work on the upper fender extensions. Now just have to decided on the colors and start priming and block sanding. I'm going to try to get it done by early spring.
I put down a couple coats of Lizard Skin on the floor, fire wall and part of the rear wall. Well that's all for tonight have a good night👍👍 Posted via Mobile Device Posted via Mobile Device
12-06-2012, 02:04 PM | #5 | |
The pictures didn't load on my post last night. So I will try them again. Thanks for looking.....
12-06-2012, 03:09 PM | #6 |
looks great
my 65 fleetside build http://67-72chevytrucks.com/vboard/s...d.php?t=442370 big back glass conversion http://67-72chevytrucks.com/vboard/s...dow+conversion |
12-12-2012, 07:55 PM | #7 |
