Old 10-22-2006, 07:59 PM   #1
TyJ
TyJ's Avatar
newer 2nd row seats
Has anybody here put a row of 73-91 seats in their sub? If so could you post some pics of em up and folded down, also do they take much fabrication or will they just bolt in?
thx in advance
TyJ is offline   Reply With Quote
Old 10-23-2006, 08:51 AM   #2
Faster57
Junior Member
Re: newer 2nd row seats
They go in without a lot of fabracation. The only thing I had to do was modify the lower seat center bracket and shim the lower seat outer stands that the seat sits on when it is in the seat position. To make the seat back latch I made a sheet metal piece from the wheel well forward. I will try to get some pictures posted of the brackets in place and the sheet metal filler for the latch. Dave
Faster57 is offline   Reply With Quote
Old 10-23-2006, 10:21 AM   #3
53burb
53burb's Avatar
I would be interested in pics also. My PO installed a late '70s seat, but it does not latch in the upright position. I kinda know what I have to do to get it to latch, but if your way is easier, then gret....
53burb is offline   Reply With Quote
Old 10-23-2006, 04:45 PM   #4
Faster57
Junior Member
Here are the pictures of mounting the brackets and hinge for the seat backs. I also included a shot of the brackets I made for the front seats. Dave
Old 10-23-2006, 04:48 PM   #5
Faster57
Junior Member
Here is the last of them. Dave
Old 10-24-2006, 07:16 AM   #6
Faster57
Junior Member
I made the filler panels to mount with screws. The hole in them is for a speaker. The back side has a stiffner added to it. I drilled the holes for the latch then welded nuts to the back side. Dave
Old 10-27-2006, 11:13 AM   #7
TyJ
TyJ's Avatar
Thanks a ton faster- couldnt have asked for anything better than that...
Ill post some pics when im done
Old 01-31-2011, 03:14 PM   #8
capev86
any updates on this?, new pictures?.....sounds promising!
capev86 is offline   Reply With Quote
Old 04-15-2012, 10:38 PM   #9
six8burban
.....yes updates?
six8burban is offline   Reply With Quote
Old 08-29-2012, 09:18 PM   #10
bondo510
anyone else have pics???
bondo510 is offline   Reply With Quote
