#151 |
![]() Join Date: May 2011
Signature test
I'm just testing a signature.
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com Last edited by Denee007; 09-01-2012 at 03:55 PM. Reason: info |
#152 |
![]() Join Date: Jul 2011
Re: My '59 Apache
Denee007,
In Kim57s thread you posted a lift. Is that the lift you bolt it in place when needed and unbolt it and put it next to the wall till next time. If so, how do you like it? Nice mustang by the way!
Build for my 1959 Fleetside... http://67-72chevytrucks.com/vboard/s...d.php?t=518308 |
#153 |
Maxjax
I'm so happy that someone asks about my maxjax! ; ). I love this lift! It's incredibly versatile, portable, you can unbolt it and roll it out of the way. You can also go to my blog www.classiccarsandtools.com and click on my MaxJax, and show you a little more about it. I don't make anything, I just get excited about things that make my life a little easier. If you go to my blog, would you please leave a comment? I have worked really hard on that thing and no one ever makes a comment! : (. Or you can even call me, and I can tell you everything you'd ever want to know about the MJ. 832-607-9116 going to bed early tonight though.
Dne' Posted via Mobile Device
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com Last edited by Denee007; 09-01-2012 at 09:43 PM. Reason: Cant spell |
#154 |
Re: My '59 Apache
Denee007- Excellent work on your projects! Very interesting build thread. Checked out your blog, too. (I have a weakness for old Mustangs, myself). Keep it up!
#155 |
Re: My '59 Apache
when you finish the truck send the lift to my place ,well you wont need it any more.Ha HA wish I had one I am getting too old to be crawling under trucks an cars.Love the tools I also had a 57 but it was brand X.
#156 |
'59 Apache on my MaxJax
I found this photo while going through my gazzilion photos on file. I think it's the only photo with my Apache on the lift! I put this pic on my blog. I had to use wood blocks to get to the frame. Notice the lift is at the first notch on the MJ. I need a hole in my ceiling for truck applications! ha ha! ; )
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com |
#157 |
column to gear linkage
Hi! seems like finding time to work on my truck is difficult! There's always something popping up to fix! Mom's home, my brother's stuff, lol. I love it! I love fixing stuff!
Here, I'm just about ready to either bolt this heim bracket or weld it. I had an extra U-joint and decided to use it. ![]() I felt the opening in the lower fender well looked like the heim and steering shaft should be there. ![]() I mounted my drop down battery box! Pretty neat! ![]() Going to workout, I'll be back! ; )
#158 |
Re: My '59 Apache
Nice work so far, the steering shaft looks like it was meant to be!
RIP John (Lambis), my beloved Father & best Friend. My Build 56 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=486721 |
#159 |
Re: My '59 Apache
cool work on the steering shaft, mine uses two may have to go your way and use three.I also have the drop down battery box,got to find time to work on mine but in the process of buying a home.looking good keep after it.
#160 |
Re: My '59 Apache
Looking good.
Kim |
#161 |
Re: My '59 Apache
Looks good, but do some research on U-joint phasing, it looks like the shaft u-joint to universal is out 90 degrees. Can't see the steering end. On steering it is not as critical as drivelines because of slow rotation speed, but it can cause binding, not a good thing in a corner!
#162 | |
Re: My '59 Apache
I forgot about that! thank you Orrie! I have to take it all back down anyway, I'll correct it then! thank you! and thanks everyone! dne'
#163 |
Re: My '59 Apache
The column drop looks great in there.All S.S Cnc machined in house at Scotts
Justin |
#164 | |
Re: My '59 Apache
55 gmc longbed stepside project http://67-72chevytrucks.com/vboard/s...28#post4708828 |
#165 |
AC stuff
It's not like I haven't been doing anything~ ; ) This requires a lot of thinking~ something I'm not used to! ha ha!
I've got all the hoses cut as I wanted them, and just sent them off to be crimped by Dwight@ Classic auto air (a really neat guy). Maybe a year or so from now, I'll be enjoying cool air from my apache! ![]() ![]() ![]()
#166 |
Getting the correct size belts
I re-installed the Alan Groves ac/ alt brackets back on my real engine. Took me three trips to Oreillys to get the correct belts. Now I can take it all back apart and paint parts. ; )
![]() ![]() Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
#167 |
Re: My '59 Apache
You're doing a nice job Denee.
Kim |
#168 |
Re: My '59 Apache
nice job which brand of ac unit is that?you will be done in no time.
#169 |
Re: My '59 Apache
Thanks! The complete AC unit is from Classic auto air. On my mustang I bought vintage air. The Apache's truck has been more difficult to install mainly because of the hoses and how they are being routed ( to be hidden). I recently sent the hoses back to classic air to be crimped.
Today I plan to remove my mock engine a start working on finishing boxing the front frame, then start removing the old paint from the engine compartment. But I'll be taking it easy as my low back has been messing with me. Gary's home today and willing to help me when the need arises; ). If at worse, I'll set up the lawn chairs and enjoy the day! ![]() Posted via Mobile Device
#170 |
first go around with engine compartment
I thought sure I was going to make leaps and bounds of progress, but that's OK, it was progress! I was careful with the aircraft paint remover keeping it away from paint. I'll work on it more Tuesday when I have some more time. I need to pull the steering column out. I did finish the brackets for the heim by welding in nuts in the frame re-enforced with 1/4" plate. I didn't get around to boxing the frame~ I'm happy! Now to figure out what color to paint the engine compartment! ; )
#171 |
Re: My '59 Apache
You're a lot braver than I would have been using stripper on a painted vehicle.
Looks like it did a nice job taking the paint off. Kim |
#172 |
Re: My '59 Apache
#173 |
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Re: My '59 Apache
I just finished a vintage air kit in my 58 so i feel your pain......I thought it would have been a bit better of a design and better fit. Nice thread and your doing some great work over there keep up the good work
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[ 1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123 1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909 1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625 Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic Aluinum Radiator Dealer pm for details |
#174 |
Re: My '59 Apache
ac only denee? i see 2 lines in/out.
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#175 |
Re: My '59 Apache
No no no, I'll be having heat too! I was just showing how these two particular hoses have to be ran. In this pic the hoses aren't crimped yet, since then, the hoses are all crimped and underneath my bed, with my radiator and condenser where I know it is all safe. Lol
