Old 09-06-2012, 08:50 PM   #351
99 to Life
99 to Life's Avatar
Re: Project "Popeye"
Glad to see you back on the horse. Are you buying patch panels or making your own?
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 09-06-2012, 09:52 PM   #352
BlueJeep
BlueJeep's Avatar
Originally Posted by LEEVON View Post
Any tips or experience to share with replacing the kick panels and toe boards?
My tip is decide how far you want to take it and stick to that. Once you cut into it, you'll likely find more rust... Only cut out what you need, and aftermarket kick panels don't fit on the bottom 4" or so. I cut that off on mine, fitted and welded the upper piece, then re-shaped the bottom 4" and welded it on last.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 09-06-2012, 10:37 PM   #353
mknittle
mknittle's Avatar
I made mine from scratch out of 18 guage. i made a forming tool that fits in a 20 ton press(overkill) out of 2" tubing and a piece of angle iron. after hearing storys about buying patch panels an rebending them I thought i would give it a try. I had to do a bit if hammer and dolly work to blend to the slight bend at the door post. It was pretty easy really.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 09-07-2012, 09:17 AM   #354
99 to Life
99 to Life's Avatar
For toe and kick panels, I'd just make my own. buy a bead roller and some metal and have at it. I think there is a time and place for some replacement panels, others I think just make more sense to make yourself.
Old 09-07-2012, 09:44 AM   #355
mknittle
mknittle's Avatar
Smile Re: Project "Popeye"
I agree about making everything you can. i have a bead roller but I didn't bother using it on the kick panels as I will cover them.
Mark
My GMC build.
Old 09-07-2012, 10:28 AM   #356
mknittle
mknittle's Avatar
forming tool
Mark
My GMC build.
Old 09-07-2012, 10:36 AM   #357
mknittle
mknittle's Avatar
oops
Mark
My GMC build.
Old 09-10-2012, 11:31 PM   #358
RocketKing
RocketKing's Avatar
Just read through the entire thread and I wanted to say great job! I can't wait to see where you go with this. Maybe if I ever get mine done I will come back up and see your progress in person again!
Rex
RocketKing is offline   Reply With Quote
Old 09-11-2012, 09:46 AM   #359
ZUBZ
ZUBZ's Avatar
Good thread, coming nicely. Love the whitewall tyres on the earlier trucks...
ZUBZ is offline   Reply With Quote
Old 09-16-2012, 03:20 PM   #360
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Any decisions on the rust repair yet?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-16-2012, 09:11 PM   #361
LEEVON
LEEVON's Avatar
Nope, just that it needs to be done. Thanks for all the tips...I got some motivation this weekend from the Ol Marais River Run in Ottawa, KS. 1600+ wicked cars and trucks.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-16-2012, 10:44 PM   #362
mknittle
mknittle's Avatar
That will do it every time!
Mark
My GMC build.
Old 09-30-2012, 08:07 PM   #363
LEEVON
LEEVON's Avatar
I haven't started on the cab rust yet, but I did get the last "big" chassis task done today, which was shock mounting. I used the stock trailing arm lower mount brackets, flipped side-to-side and forward. For the uppers, I used some shock tabs on the '50 parking brake bar which has the nice driveshaft bump that clears the rear end housing perfectly. The shocks are Monroe light truck, or maybe Jeep I don't recall but they have exactly 1/2" travel after full air and dump. Plus they were inexpensive. It was a great day for fabrication, my apprentice is a little bossy though, at least when she wasn't busy squirting everything (including me) with water.
Old 09-30-2012, 09:55 PM   #364
LEEVON
LEEVON's Avatar
So I was thinking, how many cars and trucks are represented in this build?
  • 1950 chevrolet 3100 body
  • 194_ chevrolet 3100 frame
  • 2002 chevrolet ? engine
  • 198_ chevrolet ? transmission
  • 198_ chevrolet ? bellhousing
  • 199_ chevrolet ? driveshaft
  • 2000-ish f-body accessories
  • 1979 pontiac trans am rear end
  • 1972 chevrolet C20 trailing arms
  • 1968 chevrolet C10 4 speed pedals
That list doesn't include NEW parts manufactured for other vehicles, such as:
  • Mustang II suspension
  • GM car rotors and calipers
  • Corvette LS7 throwout bearing
  • Silverado flywheel
  • C10 clutch and pressure plate
  • Jeep? shocks
I could keep going down to nuts and bolts, this is fun. The list will keep growing!
Old 10-01-2012, 02:59 PM   #365
99 to Life
99 to Life's Avatar
looking good, great when you have a good day on the truck. makes it so much more worth doing.
Old 10-01-2012, 09:41 PM   #366
chevyboy73
chevyboy73's Avatar
sweet truck, watching this! the truck I am looking at hopefully has patina like this!
2011 Silverado ECSB LT
2000 Silverado RCSB 2WD
super bad habit of not owning a vehicle for a long time
chevyboy73 is offline   Reply With Quote
Old 10-02-2012, 01:35 PM   #367
LEEVON
LEEVON's Avatar
Found a perfect bumper sticker
Old 10-02-2012, 01:39 PM   #368
OrrieG
OrrieG's Avatar
I'm a fan of "Keep Honking, I Am Reloading"
Old 10-11-2012, 08:28 PM   #369
50-MO
50-MO's Avatar
Looking good Leevon, I've decided that I am going to go the same route with the trailing arms so I am sure that I may have some questions for you. Heck, maybe you can come out to the house and share your expertise if you have the time. My brother in law works for Hendrick Motorsports and I am trying to see if he will score me a set of NASCAR truck arms first and now I am on the hunt for a crossmember.
50-MO is offline   Reply With Quote
Old 10-11-2012, 09:24 PM   #370
LEEVON
LEEVON's Avatar
Good plan, easy as pie. Come on over and take a look.
Old 10-15-2012, 03:23 PM   #371
LEEVON
LEEVON's Avatar
I drug the bed out of a barn in pieces this weekend and will be mocking it up right away, so I can set the rear wheel center line for good. I have a new front panel, 2 crossmembers and 1 rear stake pocket which is rotten where the tailgate and crossmember attach. Pics soon.
Old 10-15-2012, 11:35 PM   #372
NewType72
NewType72's Avatar
So subbed been checking out all three of the projects of yours tonight and I gotta say I'm digging all of them keep up the great progress man!
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 10-16-2012, 11:15 AM   #373
LEEVON
LEEVON's Avatar
Thanks! Great Progress is a generous description, but I'm trying!
Old 10-28-2012, 10:36 AM   #374
LEEVON
LEEVON's Avatar
I drug the bed out of the barn a couple of weeks ago and put it together yesterday. I had to use a replacement front panel, front support and rear stake pocket. I also rebuilt the rear support and stitched up several tears in the fenders and bedsides. I'm not going for pretty of course, just need good and solid. I plug welded the rear pocket, turned out pretty nice after some tweaking. I enjoy this kind of work, it was hard not to get carried away...remember PATINA is part of the deal!
If I can get a hand this afternoon I'll throw it on the frame.
Old 10-28-2012, 03:43 PM   #375
LEEVON
LEEVON's Avatar
Bed is on...digging the look.
