Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 08-20-2012, 08:36 PM   #1826
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by Tynee View Post
One woman in my life who's smarter than me is quite enough thanks. I like my trucks dumber than a box of rocks.
yeah, i know what ya mean, but i have 5 women in my life, try winning any discussion...
Thanks Dusty for the deal
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-09-2012, 12:03 PM   #1827
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Well, here is the new Scroggins-Dickey vortec tpi baseplate, mocked up with Kurt Lindner tpi
I believe it will be hooked up with FAST XFI mutiport fuel injection system...more to come on this part, as im still reading and learning which system is best for my app.
EFI Connection is still in the running, uses LS1 components w/1 coil per cylinder
Intake heater hose has to be changed for a 45 degree fitting...back into the season of working on the truck....lets see how far i get this year
SAFETY FIRST
AS usual, off topic
Jim
Old 09-10-2012, 02:04 AM   #1828
Captainfab
60-66 Nut
Re: PO has me PO'd
Is that the standard flow or high flow base?
Old 09-10-2012, 08:30 AM   #1829
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
#SD3816- doesnt say, but you can bolt on any factory or after market runners. Edelbrock offered hi flo
Im leaning more towards low end torque, as opposed to high rpm hp. As you know, these things stop flowing around 4500
Any advise you can give me would be great, did you solve your problem.....
I have a great tuner with a dyno local to me
SAFETY FIRST
AS usual, off topic
Jim
Old 09-11-2012, 01:04 AM   #1830
Captainfab
60-66 Nut
Re: PO has me PO'd
We never did get that engine to start and run right. My son solved the problem with an RPM Air Gap and a 750 Holley.
I think you will have better luck with either an aftermarket ECM such as the FAST XFI, Holley Avenger or at least an OEM OBD II PCM such as the 0411, than we did with the OBD I ECM we were trying to use.
From what I've read, the EFI Connection coil per cylinder conversion is a step in the right direction also. Although I haven't checked in the cost of that conversion, to know how affordable it is.
Old 09-11-2012, 06:19 PM   #1831
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I have nationally renowned tuner in my back yard, hes saying that an efi connection would be an overkill for my application and driving styles, so it will be the xfi system from fast
Cost is comparible with the two units, about 2 grand give or takel
SAFETY FIRST
AS usual, off topic
Jim
Old 09-12-2012, 01:32 AM   #1832
Captainfab
60-66 Nut
Re: PO has me PO'd
Since you have a good local tuner, you will have a big advantage over most of us in converting to EFI. When my son and I went thru this, we were dealing with someone 1200 miles away. At the time I did not know we had a decent chassis dyno and tuner not far away. Plus with the FAST XFI being a self tuning controler.
Old 09-12-2012, 11:14 AM   #1833
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I agree, it will help me, since i have zero knowledge in this area! Plus when i put my overdrive trans in the truck, it will plug in....
Like you said, self tuner will help!
First problem, throttle body has water outlets that are getting in my way, so i have to cut them off. They were used to prevent icing in the unit, so they can go away, since i dont live in alaska
SAFETY FIRST
AS usual, off topic
Jim
Old 09-12-2012, 02:09 PM   #1834
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
SAFETY FIRST
AS usual, off topic
Jim
Old 09-12-2012, 03:38 PM   #1835
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Started screwing around with the throttle body, of course 4 of 7 screws where seized, soaking in pbpower blaster and gunk right now. Then ican cut off the water outlets
Probably some heat and tapping the studs will soften them up
SAFETY FIRST
AS usual, off topic
Jim
Old 09-16-2012, 10:24 AM   #1836
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Started to fool around with all three cables, or putting a round cable in a square bracket.
Found an oversized washer, ground down to square, and a press fit in the bracket. Corners will be silver soldered, as there is a small gap.
The other square holes are the exact fit for oem cables, cruise and throttle
Might build a collar to keep the kickdown cable in place
SAFETY FIRST
AS usual, off topic
Jim
Old 09-16-2012, 10:44 AM   #1837
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
OOPS! Forgot i had this piece, makes it easier
SAFETY FIRST
AS usual, off topic
Jim
Old 09-16-2012, 11:07 AM   #1838
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Re: PO has me PO'd
That is going to be a neat looking motor.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 09-16-2012, 02:43 PM   #1839
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks for looking and the compliments....wanted fuel injection, so i can remote start in the winter, always liked the look of the early tpi stuff, and this one fell in my lap.
Maybe, some day i can afford the englese system, looks like the early quad webers
SAFETY FIRST
AS usual, off topic
Jim
Old 09-16-2012, 03:34 PM   #1840
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: PO has me PO'd
Looks good Jim. It is amazing how many changes a project goes through the longer you work on it.
FI is definately an improvement over most carb setups.
low'n slow is offline   Reply With Quote
Old 09-16-2012, 06:04 PM   #1841
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Time and money dictate the direction my build goes, in the beginning didnt have alot of money, but with my current job, things looked brighter. So, i could expand on some of the improvments i wanted...FI was one of them!
Thanks for your encouragement Bud, and following along. There are times when i think this project will never get done, but i sit back and look at the whole and where it all started, and i do see progress...
This fi will set me back, but i would rather have the truck roll out of the shop just the way i want it
I turned 62 the other day, thinking of retiring, but this truck is what keeps me working.....
SAFETY FIRST
AS usual, off topic
Jim
Old 09-16-2012, 09:02 PM   #1842
AJs72K5
AJs72K5's Avatar
Re: PO has me PO'd
Amen brother! The TPI looks sexy.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 09-17-2012, 06:19 PM   #1843
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks AJ, one other thing i forgot to mention in my rant....all the great people i have met along the way, 50 odd years and every day you meet someone with more info. then you previously had. Great board, huh?
Wish i had access when i started fooling around with cars
SAFETY FIRST
AS usual, off topic
Jim
Old 09-22-2012, 08:42 PM   #1844
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: PO has me PO'd
Motor is cool looking .... Hope she runs as well as she looks...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-25-2012, 03:39 PM   #1845
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks Bud, yeah, me too! The bottom end is the only thing in question, when i pulled the heads the cylinder walls where questionable......sooo, down the road it will have a stroked 400 sbc
Right now, im having problems with the water outlet on the intake. Been looking around to see what is available for the 1 1/2" outlet that i need. OEM seems to be about 1 1/4"
Throttle cable for the tpi should be here this week....plus i hooked up the oem fuel rail, just have to find a regulator and pressure gauge
SAFETY FIRST
AS usual, off topic
Jim
Old 09-25-2012, 06:54 PM   #1846
boonedogs72
boonedogs72's Avatar
Re: PO has me PO'd
what the info on the valve covers? are those centerbolt heads there on?
boonedogs72 is offline   Reply With Quote
Old 09-25-2012, 10:34 PM   #1847
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Yes they are, a company down around south carolina casts them, pcv is under the cover...ill have to get the contact info. tomorrow
SAFETY FIRST
AS usual, off topic
Jim
Old 09-25-2012, 10:55 PM   #1848
boonedogs72
Re: PO has me PO'd
cool thanks!
Old 09-26-2012, 08:51 AM   #1849
msgross
msgross's Avatar
Re: PO has me PO'd
You should have just found a totaled camaro or corvette... and pulled the engine...
very nice setup though
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 09-26-2012, 11:17 AM   #1850
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
cool thanks!
Boone, here is phone number and web, dont know how to do a link
866-258-5670
www.cool-LEDS.com
They work really well, if you have headers, since the spark plug wires feed thru the covers and directly at the spark plugs
Cost about 150.00
Nah, Mikey, i dont have thousands to thro at the truck at one shot, this way, i only have to thro hundreds at it each time
Thankyou for your continued service to the best country in the world, i for one sleep better knowing young men like you are covering my 6
Hope all is well with you and your family....call me if they ever need anything....
You cantrust a Marine with your money, and your life, just dont trust him with your wife
SAFETY FIRST
AS usual, off topic
Jim
