09-22-2012, 06:03 PM | #1 |
1972 Chevy Cheyenne Super
Carpet / padding options for a quiet ride
What kind of carpet / padding setup would you recommend for a quiet ride? I want to go with the molded carpet, but what would you recommend putting under it to keep the sound at a minimum? What about the firewall?
Thanks! Posted via Mobile Device
-Clayton 1972 Cheyenne Super LWB 350 - farm truck restore project - twitter @oldgreen |
09-22-2012, 06:20 PM | #2 |
Re: Carpet / padding options for a quiet ride
http://www.stockinteriors.com/?gclid...FegWMgoddj8AiQ
They have mass loaded vinyl and jute already on the carpet when you order it as an add on. I also sprayed 2 gallons of scorpion (al's liner if you diy) which is a lot like Line-X and put down the 1/8" foil backed foam. under the carpet. I also sprayed the underside of the cab with 2 gallons of the bedliner. When you knock on the bottom of the cab you barely hear a thud in the cab
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
09-22-2012, 06:31 PM | #3 |
http://www.b-quiet.com/
I used B Quiet under my carpet ... I wanted quiet and heat deterrent. I purchased mine off ebay ...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
09-22-2012, 10:31 PM | #4 |
I put Dynamat in mine. Started on the back wall of the cab and covered everything all the way to the firewall. I lined the cab corners too behind two 6 x 9 speakers. Lined inside the doors too.
How 'Bout them Dawgs! '10 Traverse LTZ 03 Silverado Z71 ext cab 99 Yamaha Grizzly 600 72 C10 350/350 sportside bed. 68 C30 flatbed. 350 4-speed. "I've got a good memory, it's just short!" |
Tags |
carpet, heat, sound |
