Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 10-07-2012, 11:25 AM   #101
Matt R
Matt R's Avatar
Re: 1990 Chevrolet Sport forever project
Here is the consequence of too much work and not enough clean up!
My build thread http://www.67-72chevytrucks.com/vboa...d.php?t=494247
Matt R is offline   Reply With Quote
Old 10-07-2012, 11:30 AM   #102
Matt R
Matt R's Avatar
Here is the building of the upper coilover mount.
Old 10-07-2012, 11:32 AM   #103
Matt R
Matt R's Avatar
Here is the moc up of the front suspension
Old 10-07-2012, 11:35 AM   #104
Matt R
Matt R's Avatar
Here is the paint shop I did the same 2 part epoxy paint on everything.
Old 10-07-2012, 10:49 PM   #105
Matt R
Matt R's Avatar
I decided to wrap up all the stuff under the truck while I had it jacked up 2 feet. Here is some exhaust pics. I reused one of the bends and the mufflers, this is all pretty temporary cause the big block but still tried to make it nice.
Old 10-07-2012, 10:51 PM   #106
Matt R
Matt R's Avatar
Here is some of the fuel and wire routing under the truck, nothing too fancy.
Old 10-07-2012, 10:59 PM   #107
Matt R
Matt R's Avatar
I didnt show this one, I got a bear tracker bump steer kit. It only allowed about 1 inch of end link correction. I needed a good bit more than that to get the tie rod end level at ride height. I cut the bear piece in half and welded a sleve to it to extend the end link.
Old 10-17-2012, 05:01 PM   #108
shawnr21
Great work Matt
shawnr21 is offline   Reply With Quote
Old 10-17-2012, 09:05 PM   #109
Matt R
Matt R's Avatar
Thanks Shawn, havent seen you in a bit.
Old 10-20-2012, 10:25 PM   #110
Matt R
Matt R's Avatar
Heres a few more pics of the front suspension. I didnt make my deadline for the show so i'm going to slow down just a bit and do a couple things differently.
Old 10-20-2012, 11:48 PM   #111
Matt R
Matt R's Avatar
I drove her a bit last week and things went pretty well. Need to work out a few bugs. I'm going to redo the steering box, pitman arm, ect. try to lessen the size of the tie rod end link.
Old 10-21-2012, 12:05 AM   #112
Matt R
Matt R's Avatar
Old 10-21-2012, 12:11 AM   #113
Matt R
Matt R's Avatar
I was trying to get it going pretty quick so I came up with a few things that were somewhat temporary. One is the radiator support, I kinda like the start of it I think i'll just add to it for the shroud.
Old 10-21-2012, 12:18 AM   #114
Matt R
Matt R's Avatar
It had abs on the rear brakes. I had to get rid of all that and put an adjustable proportioning valve in. The brakes performed great, wish I had the big brakes on the front though. Now that I have more time, i'm going to do the hydroboost now. I actually took the booster and old master cylinder off today to get a feel for what it is going to take.
Old 10-21-2012, 09:45 AM   #115
Matt R
Matt R's Avatar
Here's a few more random pics, kinda jumpin around I know.
Old 10-21-2012, 10:08 AM   #116
Dobok
Nice job so far.Matt; As for the steering is it just the arms are too close together and are binding or are you having trouble with the steering period. If its the steering only I know they have new special steering boxes that have better turning radiuses and faster too. Anyway just trying to help.
Dobok is offline   Reply With Quote
Old 10-21-2012, 11:23 AM   #117
Matt R
Matt R's Avatar
This is the major problem. Its my solution to bump steer, its just too long. The leverage on it is just too much at that length.
I've weighed what to do about it and all the options. Looks like a raised pitman arm will gain me an inch or more. I may raise the steering box up a bit too. It's going to take several different things to gain the correct angle of the tie rod end to correct bump steer. I was looking at a rack and pinion pretty hard but it requires lower pressure and the hydroboost likes the higher pressure. Plus the rack and pinion is made for much lighter cars. I am getting a new gear box and pitman arm. We'll see how much that does then decide if I need to raise the whole steering box or not. I will still need some length on the tie rod end but I need to minimize that as much as possible.
Old 10-21-2012, 08:58 PM   #118
jughead12
the stance of your truck is perfect! i love it!
jughead12 is offline   Reply With Quote
Old 10-21-2012, 10:02 PM   #119
Matt R
Matt R's Avatar
Thanks man, I'm loving it too. The pics just dont quite do it justice. I'm hating that it's back on jack stands though. Hopefully i'll get a few things worked out in the next couple weeks and be back on the road.
Old 10-22-2012, 05:13 PM   #120
Thunderwagen
Its looking really good.
1990 GMC Sierra
http://67-72chevytrucks.com/vboard/s...d.php?t=617587
Thunderwagen is offline   Reply With Quote
Old 10-22-2012, 07:50 PM   #121
Matt R
Matt R's Avatar
Thanks man, going out to work on it some now!!!!
Old 10-23-2012, 12:30 PM   #122
Dobok
Before you know it Matt, you'll be done and back on the road till the motor and tranny are ready. ENJOY it---It is one Great looking truck !!!!
Old 10-23-2012, 09:16 PM   #123
Matt R
Matt R's Avatar
Thanks man.
So i'm redoing all the steering to address the biggest problem which is bump steer. The second biggest problem is the steering gear box ratio. It's pretty sloppy feeling with the high stock ratio. It doesnt really do the new suspension any justice.
Old 10-25-2012, 06:30 AM   #124
simobones454
simobones454's Avatar
sits really good , not a bad height at all mate. Those batteries ,theres no problem with then sitting on there sides ?
simobones454 is offline   Reply With Quote
Old 10-25-2012, 04:20 PM   #125
Matt R
Matt R's Avatar
Thanks man. There are no problems with the batteries, they are a sealed glass mat design. They can be mounted in any direction without any problems.
