Old 10-15-2012, 11:31 AM   #1
fdwrench
Park brake
Hi,
I have installed a Heidt front end and can not run the park brake in the original position on the frame.
What have you used for parking brake controls?
Has anyone used an electric setup?
Thank you
Ed
fdwrench is offline   Reply With Quote
Old 10-15-2012, 12:08 PM   #2
mr48chev
mr48chev's Avatar
Re: Park brake
I put a regular pedal type park brake that fastens to the left kick panel in my 48 years ago when I changed things over. I put it up out of the way a bit and used the release lever that came with it. running the cables was a lot more work and effort than installing the pedal assembly.
If you run a floor shift you could install a park brake lever that mounts on the floor, and lays down next to the shifter. They are usually in bucket seat cars but wouldn't look too out of place sitting on the floor next to the shift handle. Actually there are lots of options if you look around a bit.
Old 10-15-2012, 12:21 PM   #3
fdwrench
Re: Park brake
I guess that I should say that it is a 55 second series.
I have an ididit with the shifter on the column.
Old 10-15-2012, 01:09 PM   #4
mr48chev
mr48chev's Avatar
Re: Park brake
Not inexpensive but it saves trying to make a junk yard part work and it might go with the column nicely. http://www.lokar.com/product-pgs/eme...op-ebrake.html
Old 10-15-2012, 03:24 PM   #5
OrrieG
OrrieG's Avatar
Re: Park brake
I found that a 74 truck has the same bolt/stud spacing as the 59 hinge bolts. Here is a photo of the bracket mounted. The 74 cable goes thru the firewall to a bracket on the crossmember. From there you need to transition to the stock cable that goes thru the pulley to the rear hardware. If you need more detail, message me with an email address and I can send more photos on the install.
Old 10-18-2012, 08:36 AM   #6
andrew_k
Re: Park brake
I'll buy anybody's extra 55-59 e-brake handles for $15 or less. Always afraid of the gears breaking down in these!
andrew_k is offline   Reply With Quote
Old 10-18-2012, 09:19 AM   #7
lonelywanderer
Re: Park brake
i actually moved mine further back then lengthened the arm and shortened the rod. works just like original
lonelywanderer is offline   Reply With Quote
Old 01-05-2020, 11:10 PM   #8
Strider
Strider's Avatar
Re: Park brake
Hey OrrieG,
Can you show more detail on the install of the park brake here? And you used a 1974 pedal?
Looks good for sure!
1967 C-10 250 I6 w/ TH350 3.08 10 bolt HUGGER ORANGE aka "The General"
'57 GMC short step REGINA SPECIAL
2013 CREW CAB SILVERADO 5.3 6 SPEED Z71 WHITE DAILY DRIVER
"When you have eliminated the impossible, whatever remains, however improbable, must be the truth." ~Sherlock Holmes
"Deeds will not be less valliant because they are unpraised." ~ Aragorn
Strider is offline   Reply With Quote
