#76 |
Machinist
Re: need help with my suspension 1970 gmc
Are you running drop spindles?
#77 |
![]() Join Date: Jul 2009
Yes and cpp uppers/lowers control arms.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ |
#78 |
Machinist
I picked up a set of 74200 Moroso springs used real cheap. 4.8 dia I hope they will fit... It looks like the will. I’m running a pair of stock spring that have been cut to lower the truck. Compressed they are 7.75 tall and if I remember right they are around 12" tall uncompressed. My truck will not transfer for anything. if it doesn’t dead hook and you have to lift it becomes a pedal fest...This thread has been a ton of help. It all makes sense now. Thanks guys
#79 |
Got the new body mounting bushings installed today. Still waiting on the headers and exhaust to get back from airborn coatings they are saying Friday! Man I hope so I'm dying to try it out!
#80 |
What headers and motor mounts do you have?
Posted via Mobile Device |
#81 |
solid moroso engine mounts and custom built headers. I hear that some of the members are running a bbc chevelle header. I was running a poly engine mount and super comp hooker headers but after installing the solid engine mounts the headers hung to low draging all the time so I built a custom set of fenderwell headers.
#82 |
Got the headers and exhaust back from airborn today
#83 |
Ok guys I ran the truck this pass weekend at ctc and it seems to be moving around alot
front to rear side to side any input?
#84 |
Machinist
Moving around? off the line ... on the big end?
#85 |
Front to rear when taking off and rear to front when stopping. A friend of mine was following me and said when I took a turn it looked like the front tire almost come off the ground. It has alot of movement in the suspension.
#86 |
So, is it tranfering weight then to the rear under acceleration and then tranfering it to the front under braking? Not sure I follow.
Is it moving weight to the outer front in a corner and lifting the inner rear? Posted via Mobile Device
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
#87 |
yes
