10-21-2012, 12:54 AM | #1 |
Am I SOL? Where to buy one of these?
Pics below
This is currently my Daily Driver! Front Wheel cylinder started leaking on my 70 C-10. Figured I'd pull it and run down to the local parts store for a replacement. The Anchor bolt was seized on (tried penetrating oil/heat, etc etc.) Then I had the bright idea to have the wife hold the socket while I tried to stand on the handle to break it loose ( after all leverage is your friend). Well the socket slipped off and snapped the nub that holds all the springs for the drum brakes. I have spent hours searching online and can't find one anywhere (LMC/oldtrucks/ebay etc etc). Is Wheel Cylinder Anchor Bolt the right name? Does anyone know where to buy one, or have one laying around after doing the 5 lug disc brake conversion? I'm located in Shreveport Louisiana. I am not interested in conversions, just need to get this mean green machine back on the road. Details: 6 lug Standard Brakes 1 1/8 diameter cylinder/ and anchor bolt (60-72 C10 front drum brakes?) Thanks for the support
________________________ 72 Olds Cutlass w/442 option 69 C-10 Short Bed Fleet 1960 Biscayne Wagon/El Camino 1995 YJ 4.0 SOA SYE on 35s 01 Excursion Limited 7.3 PSD 06 Suzuki DRZ 400S |
10-21-2012, 01:17 AM | #2 |
The Older Generation
Re: Am I SOL? Where to buy one of these?
I'll check in the morning. I should have one I can send you. If you don't hear from me by 9am central time send me a PM.... LockDoc
10-21-2012, 01:19 AM | #3 |
Sure do appreciate it friend, thanks for lookin.
Hindsight: I wish I would have tried to rebuild the wheel cylinder without taking it off (did not even know that was an option till I broke the part)
________________________ 72 Olds Cutlass w/442 option 69 C-10 Short Bed Fleet 1960 Biscayne Wagon/El Camino 1995 YJ 4.0 SOA SYE on 35s 01 Excursion Limited 7.3 PSD 06 Suzuki DRZ 400S Last edited by Secret Squirrel; 10-21-2012 at 01:28 AM. Reason: Added After Thought |
10-21-2012, 01:42 AM | #4 |
should be a grade 8 bolt you can get from most autoparts houses
a wise man once said "There are only two real rules to life... 1 - Don't sweat the small stuff 2 - Everything is small stuff |
10-21-2012, 01:47 AM | #5 | |
I don't think you can do that. The pistons won't clear the bumps on the backing plate without loosening the retaining bolt so you can't get them out. That is a safety feature... LockDoc
10-21-2012, 01:51 AM | #6 | |
http://67-72chevytrucks.com/vboard/a...1&d=1242965113 LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 10-21-2012 at 01:57 AM. |
10-21-2012, 02:02 AM | #7 | |
Tried lookig on all the websites of local parts stores, don't have any listing for wheel cylinder anchor bolt.
10-21-2012, 02:09 AM | #8 | |
10-21-2012, 02:15 AM | #9 |
I have 2 complete redone front assemblies off of my 70 that nobody bought on Craigslist.
I'm in California though, and they are kinda heavy. |
10-21-2012, 02:25 AM | #10 |
In the AM I will look through my parts boxes and see if I have one. as many as I torn down, I'd be suprised if I don't. I'll let you know in the morning.
10-21-2012, 02:29 AM | #11 | |
Two of my cars are hanging out in So Cal with my parents until my next move (when and where that may be?) I am strapped for cash, would you consider a trade? I could have my buddy pay for the shipping (he owes me) and I can send you a thank you gift? I have not been able to bust that bolt loose yet, so It be great to have a back up plan on the way over from Cali.
10-21-2012, 02:37 AM | #12 |
Thanks for all the support gents, that sick feeling in my gut is starting to go away. I have to get some sleep, that truck kicked my rear tonight. Time to let the wounds heal, and re attack in the morning.
I will send thank you gifts/comp or pay for shipping to anyone who saves my bacon!
________________________ 72 Olds Cutlass w/442 option 69 C-10 Short Bed Fleet 1960 Biscayne Wagon/El Camino 1995 YJ 4.0 SOA SYE on 35s 01 Excursion Limited 7.3 PSD 06 Suzuki DRZ 400S Last edited by Secret Squirrel; 10-21-2012 at 02:44 AM. Reason: sp |
10-21-2012, 02:50 AM | #13 |
Group 5.055 PIN, Brake Shoe Anchor
Looks like 3841719 or 3840699 are the part numbers depending on HD brakes or not. The applications might help someone shake a used one loose. One number runs from 60-72 for the HD and the other 64-71.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
10-21-2012, 02:57 AM | #14 |
Let me know, i'll help you out.
10-21-2012, 09:44 AM | #15 |
Re: Where to buy this part? Anchor Bolt???
do you have a freind with a welder and a lathe. im betting i could just fix it.
if you cant find anybody then send me the bad one and a good one (if you can) and i will fix it free just pay shipping.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ Last edited by corvettejim1968; 10-21-2012 at 09:51 AM. Reason: add |
10-21-2012, 09:54 AM | #16 |
I have one if you can't find one closer but I would think the parts houses would have those , try the rack where they have the universal parts.
10-21-2012, 10:05 AM | #17 |
I have an extra axle here that will be converted to disc so I will not need them. Let me know if you need me to ship.
Just read its the front. I have those too... Actually I am about to go out and pull apart the front A-arms to replace with later model so if need be I can ship tomorrow. |
10-21-2012, 10:32 AM | #18 |
I have one. I have included a picture with measurements. I know there are two different lengths but I don't know what the reference is on them. From your picture it looks like you might have the long one.... If this is the right one PM me your addy and I will send it to you. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 10-21-2012 at 10:39 AM. |
10-21-2012, 10:41 AM | #19 |
I may have one on my older parts truck. It's a 62 with drum brakes. I'm in Shreveport.
Posted via Mobile Device |
10-21-2012, 12:13 PM | #20 | |
After it snapped I got the BFH and gently tapped on it to try to break the rust from the threads, well I started out with little taps. I'll need a new one
10-21-2012, 12:20 PM | #21 |
Such great ideas, why not go the the local junk yard and pick yourself up one.
10-21-2012, 12:31 PM | #22 |
Ok PMs have been sent, you guys are awesome.
LocDoc, The picture I posted of an Anchor bolt was one I found on the web. The one I need is the one you have (takes a 1 1/8 wrench or Deep Socket) to remove. I'll definitely use an anti seize when I rebuild it.
10-21-2012, 12:38 PM | #23 |
Defiantly an option, have to wait for a day when I don't have my kids with me to start looking.
10-21-2012, 02:40 PM | #24 |
Grandpa in the rustmobile...
why I love this forum
I have one soemweere at home as well but it would be quite some time before you got it lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
10-21-2012, 02:48 PM | #25 |
Agreed, no matter where Uncle SAM sends me the forum is always near by and ready to help out. Hopefully I can get my old girl back on the road soon. I am still fighting to get the broken Anchor Pin off.
