Old 11-12-2012, 09:27 PM   #1
fast50ranger
fast50ranger's Avatar
Flowmasters getting on my nerves...
Okay I am running a 427 with flowtech headers with 40 series flowmasters dumped under the bed of my truck. And it was okay when I wasn't driving the truck that much but as i spend more time driving the truck, it is way too loud for my taste (Getting old I guess ). Anyways what mufflers are you guys running that are not as aggressive as the 40 series but still sound good? Thanks.
Big Block Powered
fast50ranger is offline   Reply With Quote
Old 11-12-2012, 09:41 PM   #2
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Re: Flowmasters getting on my nerves...
I switched my BBC/'62 Bel-AIR from 40 Flowmasters to Magnaflow Super Turbos. Much more liveable inside and still sounded healthy.
TobyArnot is offline   Reply With Quote
Old 11-12-2012, 09:45 PM   #3
AusTx68
AusTx68's Avatar
I ran the 40 series for two years. First with them dumped under the bed. I later ran them out the back. Running them out the back made a huge difference to in-cab sound! Makes them much more tolerable. I later switched to 50 series for the good of my neighbors They are dumped and sound as loud as the 40s out the back.
The muffler shop tech told me that a dumped setup causes the sound to reverberate between the ground and bed causing a lot of sound to be transferred into the cab.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 11-12-2012, 09:50 PM   #4
69GWC
Yeah I would run them out the back first, this way its still loud just behind you..
69GWC is offline   Reply With Quote
Old 11-12-2012, 09:53 PM   #5
Tinkermc
I must agree since I did the same thang, run them out the back and get that droning noise out of your head.
Tinkermc is offline   Reply With Quote
Old 11-12-2012, 09:54 PM   #6
bodydropped68
bodydropped68's Avatar
Whatever muffler you chose you still need to get the exhaust to exit out back out from under the truck the resignation from the exhaust will still be there maybe try tail pipes first. Well that's my 2 cents worth of advice. And an X pipe helps alot too
bodydropped68 is offline   Reply With Quote
Old 11-12-2012, 09:59 PM   #7
ubtripn
ubtripn's Avatar
Sorry but I am not afraid to admit that I am learning. What is dumped?
ubtripn is offline   Reply With Quote
Old 11-12-2012, 10:25 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I was a Flowmaster guy for about 20 years, until I bought my first Magnaflows. Now I won't ever own any more Flowmasters.
I prefer the raspy, snarl sound of Magnaflow over the deep resonating of Flowmasters.
Tx Firefighter is offline   Reply With Quote
Old 11-12-2012, 10:29 PM   #9
shawno72
C/10 junkie
shawno72's Avatar
X2
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 11-12-2012, 10:38 PM   #10
Andy4639
Old member
Andy4639's Avatar
Cool Re: Flowmasters getting on my nerves...
I guess I'm the odd ball here. I run generic mufflers and love them. No since in paying that kind of money for something never seen in my opinion.
By the cheapest muffler you can. I have mine dumped over the rear end. I can talk normal in the cab and hear the radio fine. I wouldn't spend a bunch on a muffler for a D/D.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-12-2012, 10:49 PM   #11
LEX
LEX's Avatar
It's when the pipes stop shortly after the mufflers and exit down towards the ground somewhere underneath the undercarriage.
LEX is offline   Reply With Quote
Old 11-12-2012, 11:49 PM   #12
CG
BlahBlahBlah
I just picked up an off topic truck (old unibody) with a healthy 350 Chev, 3 inch exhaust and Flowmasters. It dumps about midway under the box. The cab is all bare metal with no insulation at all. Its very loud in the cab and right now it just gives me a big grin when I jump on it =)
Now if I had to drive it all the time I would go insane. Future plans are to completely insulate the cab with Lizard Skin sound and heat barrier. Its just a fun little truck so I wont be going crazy.
I did have Flow 40s on a 71, but they were pretty far back in the system and the exhaust ended up all the way out the back with no dump. It was fine in the cab.
Old 11-13-2012, 12:04 AM   #13
oklalawnboy
oklalawnboy's Avatar
I've got a good ole Thrush glasspack exiting out the rear and it sounds like my old truck back in the 70's. My Monte has 3" series 40 flowmasters and I can't hear anything in the cockpit. I love both sounds.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 11-13-2012, 12:08 AM   #14
Square_78
Square_78's Avatar
I have a flowmaster 40 coming off stock manifolds, and it dumps under the bed of my 78 c10. I thought it was loud until I got my 1970 with long tube headers and dual 40's running out the back. Its really loud, but now that Im used to it, I want it louder. I just sounds so good when you stomp on it. Perfectly tuned for the ears.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 11-13-2012, 12:15 AM   #15
gearys 5600
gearys 5600's Avatar
I had flowmasters on everything I owned for years, now I prefer Dynomax mufflers. just my .02 cents.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 11-13-2012, 12:23 AM   #16
weever82
weever82's Avatar
I am running the 50 series flowmasters on my 69' 454 and they sound amazing exiting behind the truck but too quiet for me. Might be what your looking for if your staying with flowmaster. I personally am going to switch it up to super 44's or 40's when I can but I drive about 10x a year and want it wicked loud!
Weev-
Weev-
Life's tough...... It's even tougher when your stupid - John Wayne
weever82 is offline   Reply With Quote
Old 11-13-2012, 01:39 AM   #17
mr48chev
mr48chev's Avatar
Pipes out the back will help get rid of the resonance even if you run straight pipes. It was bad enough with my 71 when I had a pair of burned out glass packs that had been on a 65 I had had that turned out and exited in front of the rear wheels. It was fun on runs to town but I drive 23 miles to work and the drone got pretty tiresome after a couple of years. I went to Headers, turbos (unknown brand but free) and tail pipe that exit behind the rear wheels and it's comfortable in the cab now but it still has a good rumble and sounds great with the windows down.
I've always said that I like a sweet and distinctive set of pipes but I've long outgrown loud just for the sake of being loud.
Old 11-13-2012, 02:24 AM   #18
bk2life
mufflers make your motor sound neat, but you cant hide horspower.
bk2life is offline   Reply With Quote
Old 11-13-2012, 04:13 AM   #19
nate68
I'm running Flow tech Terminators and am happy with them. The truck was my daily driver for a few years & they're not too loud inside. They don't have that hollow Flowmaster sound (which I don't care for)
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 11-13-2012, 09:10 AM   #20
69moneypit
Divorced .....WITH KIDS
69moneypit's Avatar
I have flow master super 40s dumped . Noise really only bothers me after a long ride and I'm stopped somewhere . The main problem isnt the noise it's the dust. Everyday I drive the truck I have to wash it. Next off day I'm running pipes out back . Didn't want to cause I plan on bagging truck this winter .
1969 GMC SWB
1975 Chevy Malibu 80k
1963 Ford Galaxie 63k (inherited)
2005 Nissan Armada (wife's idea)
69moneypit is offline   Reply With Quote
Old 11-13-2012, 11:04 AM   #21
fast50ranger
I think I am going to run them out the back first and see if it helps. This is the cheapest route right now.
Big Block Powered
Old 11-13-2012, 11:32 AM   #22
ubtripn
ubtripn's Avatar
Thank you Lex.
Old 11-13-2012, 12:20 PM   #23
68gmsee
Active Member
68gmsee's Avatar
...... it is way too loud for my taste (Getting old I guess ).....
You must be in the 'tween years cause now that I'm older I'm beginning to like the low rumble of the exhaust again. I saw a man that looked older than me ('course that's what we all say) cruising in a loud hotrod some time ago.
There's something nostalgic about a gray haired ol' guy cruising down the highway with loud mufflers. Brings a tear to the eye...
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 11-13-2012, 12:24 PM   #24
domeier
domeier's Avatar
I was just thinking the same thing yesterday. I have Flowmaster 40s that exit behind the the rear axles, and I'm about tired of the decibel level in the cab, (not to mention my neighbors probably want to shoot me whenever I wake their babies up at midnight to go get a pack of smokes.) The stainless exhaust was done about 12 years ago, and it's still in great shape. I'll replace with something quieter when it wears out.
Guess I must be getting old, too. I cringe now whenever I see those asinine giant wagon wheels, or somebody's pride and joy cowl induction hood scoop. It took me my whole life, but I've finally come to appreciate dead stock as the ultimate beauty trick. And yeah, I know... it's all in the eye of the beholder.
domeier is offline   Reply With Quote
Old 11-13-2012, 12:25 PM   #25
AusTx68
AusTx68's Avatar
The dust is my second biggest complaint on the dumped setup. For that reason I keep her on the street. Every now and then I have no choice. I hate when that happens.
exhaust, mufflers
