#276 |
Beer Drink'n Knuckle Dragger
Re: [PROJECT] Laidout53 Part II
Truely inspiring here...can't wait to get off my deployment and start chopping up the new '54 2ton...nice work bud.
Jack
![]() ![]() - 67 GMC Long-Wide 350/SM420 My BACON Wrapped Meatloaf Recipe |
#277 |
the pollock
nice...
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
#278 |
Well I started on the firewall today. cut the new one cut and bent, and capped the "doghouse" part of it.
![]() ![]() ![]() "Doghouse" capped ![]() ![]() Test fit... ![]() More to come, Including floor boards and a removable trans tunnel. Justin
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
#279 |
Keep it coming
Posted via Mobile Device |
#280 |
will do...
#281 |
![]() Join Date: Aug 2005
Just saw the dash; Love it!
#282 |
67cheby
![]() Join Date: Sep 2008
man, AMAZING job on the dash and door pieces !
#283 |
Thanks frizzle fry and 67cheby!!
#284 |
Nice job ad great fab work. Keep up the inspiration to us all!!!!!
#285 |
On the path to financial ruin!
![]() Join Date: Jan 2009
....and firewall too!!
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 |
#286 |
![]() Join Date: Jun 2012
i just went through every page...that has to be some of the best metal work ive ever seen, the dash is unreal man...awesome build
#287 |
Wow thanks guys!!
#288 |
What part of WA are you in?
#289 |
Gig Harbor
#290 |
Update time!
After cutting the old firewall out i realized the the floor boards need some rust repair and the lower corners on the firewall need to be rebuilt. So I decided to go ahead and make need floorboards (under support/cab mountincluded) and inner kickboard supports along with rebuilding the corners. I started with the passenger side first. Heres the pictures with the descriptions... First i removed old firewall and then i reinstalled the motor with the new 5sp trans and modified the trans mount to be removable. ![]() ![]() (in 5th with some clearance, will be making new shifter) ![]() ![]() Next i clearances the firewall and tacked on a flange ![]() ![]() Then I braced the door jam and then i completely cut the floor out. Before ![]() ![]() Rebuilding ![]() Cab under support(Old versus New) ![]() ![]() ![]() Starting the floorboard ![]() ![]() ![]() ![]() Then came time to make the upper peice that connects to the firewall ![]() Then i fab'd a new inner kickboard panel ![]() Next I welded the firewall flange and doghouse part fully ![]() And here is on side ready to be drilled for spot welds and to be welded in place. ![]() ![]() Then im on to the other side and then Ill build a new removable trans tunnel and the cab will be 95% done. Justin
#291 |
Ah man. All these new pics and all I'm seeing is "Sorry, this pic removed or deleted."
#292 |
#293 |
Ya im just now seeing that to, Ill figure that out. it wasnt me....
#294 |
Ok, they should be back up real soon! I exceeded my bandwith for photobucket...
#295 |
Since i dont know how to edit post #290 heres the update. If a mod can delete that post i would appreciate it, Thanks....
![]() After cutting the old firewall out i realized the the floor boards need some rust repair and the lower corners on the firewall need to be rebuilt. So I decided to go ahead and make need floorboards (under support/cab mountincluded) and inner kickboard supports along with rebuilding the corners. I started with the passenger side first. Heres the pictures with the descriptions... First i removed old firewall and then i reinstalled the motor with the new 5sp trans and modified the trans mount to be removable. ![]() ![]() (in 5th with some clearance, will be making new shifter) ![]() ![]() Next i clearanced the firewall and tacked on a flange ![]() ![]() Then I braced the door jam and then i completely cut the floor out. Before ![]() ![]() Rebuilding ![]() Cab under support(Old versus New) ![]() ![]() ![]() Starting the floorboard ![]() ![]() ![]() ![]() Then came time to make the upper peice that connects to the firewall ![]() Then i fab'd a new inner kickboard panel ![]() Next I welded the firewall flange and doghouse part fully ![]() And here is on side ready to be drilled for spot welds and to be welded in place. ![]() ![]() Then I'm on to the other side and then Ill build a new removable trans tunnel and the cab will be 95% done.
#296 |
Junk Yartist
Freakin awesome!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#297 |
67cheby
WOW, looks great ! i think it would look good to roll a couple panels into that firewall also, just to break up the flat a little .
#298 |
Thanks man!
Thanks. I agree with you, it would look good but its too big for my roller and when i get the inner fenders in you wont see as much of the firewall.
#299 |
67cheby
cool ! i understand ! beautiful work !
#300 |
Wow! Your reproduction of the floor pieces is incredible! Nice work!
(and thanks for fixing the pics!) |
