Old 11-26-2012, 04:11 PM   #1
tommys72
tommys72's Avatar
determing engine block numbers
i found the numbers on my block, they are V0121TDJ, i know the TDJ means it a 72 block, but how do i tie it into the vin to make sure its the original motor?
tommys72 is offline   Reply With Quote
Old 11-26-2012, 04:38 PM   #2
truckster
truckster's Avatar
Re: determing engine block numbers
That number will only show the year (72) and application (truck 350/175 hp/ TH350/ 4-barrel). It's not going to match the VIN, because the block numbers weren't that specific.
truckster is offline   Reply With Quote
Old 11-26-2012, 04:52 PM   #3
SS Tim
SS Tim's Avatar
Most seller's claims of "numbers matching" are full of something beside honesty. To know for sure would require a tear down inspection of a known documented engine. Anything less is a guess
from a very confident, expert informed external inspection to a WAG for ad copy.
Since GM did not VIN stamp these blocks you cannot say 100% this is it. However you can come close with the engine number. It tells us the plant build date and intended application of the engine.
So yours is:
V Flint engine plant
01 January
21 21st day of the month
TDJ conventional cab with auto trans. 175hp 4bbl carb.
Now the problem is TDJ was also used in 1980 in a similar 155 hp application. To verify yours is a '72 you would need to check the casting number and the casting date. These numbers will precede the build date but the range varies greatly. The other dated parts to check would be the heads, intake, carb, distributor and exhaust manifolds. These will all give you clues about how original an engine is or how bad someone wanted it to look original.
The little ray of sunshine here is the protecto plate has the engine number on it. This cross confirmation on top of the date on the blue door certification label gives a good firm date everything will precede.
Have fun!
SS Tim is offline   Reply With Quote
Old 11-26-2012, 05:23 PM   #4
tommys72
tommys72's Avatar
good info guys, thanks, im gonna investigate a little more. the old man i bought it from said it was original motor and trans, i dont doubt him at all...just seeing if i could get closer to actually verifying that. the block being a 72 is a good sign...with a 4 bbl and the TH350
Old 11-26-2012, 05:43 PM   #5
tommy69
not for sure on the trucks but on gm cars there is another set of numbers stamped right below those that you listed that should be specific to the later part of the vin number if it is the original engine
tommy69 is offline   Reply With Quote
Old 11-26-2012, 06:01 PM   #6
SS Tim
SS Tim's Avatar
Just remember the suffix codes were reused often several times. It is important to verify the casting number and date to be accurate. From your description it probably is the correct block. But could just as easily be a 1980 van short block that had be stuffed in there fifteen years ago, that is why we check if original or correct is a consideration.
The trans and carb. of course have no bearing on the block being original or not. In fact most carbs. I dare say are replacements that only application and date codes can confirm as correct.
Old 11-26-2012, 06:55 PM   #7
Duncan and son
Jason "son" will hop on here and let us all know how to confirm if is in fact a correct original matching No. engine
You can shear a sheep every year, but you can only skin it once
The person dealing with facts is never at the mercy of the person dealing with theory
1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn
1975 Silverado 454 Crew cab camper special dually
Duncan and son is offline   Reply With Quote
Old 11-26-2012, 08:44 PM   #8
72 K20
72 K20's Avatar
I have an engine number That I'd like to decode as well,, actually,, 4 of them. Would it be alright to post it here ?
Thank You ! Tom
72 K20 is offline   Reply With Quote
Old 11-26-2012, 09:00 PM   #9
sameyrasmea72
sameyrasmea72's Avatar
I agree with the above, There is no way to know 100% for sure if the block is the original block. If the VO121TDJ matches the protectoplate, then that is about as close as you can get. If the VO121TDJ matches the protectoplate, the only way it would not be original was if the engine came out of a similarly cofigured truck built on the same day and same plant.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 11-26-2012, 09:20 PM   #10
Duncan and son
[QUOTE=72 K20;5724572]I have an engine number That I'd like to decode as well,, actually,, 4 of them. Would it be alright to post it here ?
Thank You ! Tom[/QUOTET
Tom, Jason is very good on numbers codes etc ( I always say he is smarter than a white rat) I am sure it is ok to ask questions and Jason and others will help you.
Old 11-26-2012, 09:29 PM   #11
72 K20
72 K20's Avatar
Ok ! Here goes !
Big Block in my 72 C20 TO527CLB
Small block in 71 C20 parts truck VO403TDS
Small Block was told it was a 305 K1212 CDD
Small block supposedly from an 88 chevy van V0802 TWA
Any and all help is greatly appreciated !! Thank You ! Tom
Old 11-26-2012, 09:33 PM   #12
SS Tim
SS Tim's Avatar
Thank You ! Tom
Sure, this thread is about decoding and examples always help.
Old 11-26-2012, 09:54 PM   #13
SS Tim
SS Tim's Avatar
sameyrasmea72,Duncan and son, Thanks for hoping on this thread. You have opinions I trust and invite corrections or clarification of ambiguities.
Old 11-26-2012, 10:18 PM   #14
tommys72
tommys72's Avatar
Thank You ! Tom
go ahead man
Old 11-26-2012, 10:22 PM   #15
tommys72
tommys72's Avatar
i know there is no bearing to those, it was good to know that nothing crazy like a 2 BBL came out lol...id love to have the protecto plate with the truck...that would be nice
Old 11-26-2012, 10:29 PM   #16
MusicMan70
MusicMan70's Avatar
Another possible alternative may be the buildsheet...
I believe that the Buildsheet has a location for the block number as well. I have seen Buildsheets posted on this Forum with the corresponding number; unfortunately does not have it on there. I'm still confident it was original to the truck.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 11-26-2012, 10:37 PM   #17
SS Tim
SS Tim's Avatar
Ok ! Here goes !
Thanks Tom!
Now I see why you were asking. This what I have crossed through a couple of sources. To do anymore a casting number and date will be needed. In the case of the car line engines the VIN too.
TO527CLB Tonawanda May 27th CLB is a 71-72 car line LS3 engine code.
VO403TDS Flint April 03rd TD "S"? Are you sure???
K1212CDD St. Catherines, Ontario December 12th CDD is a 72-85 car line code used on 267, 305 and 350
V0802TWA Flint August 2nd TWA is a 74 C60/6000 350 160hp 2bbl
Old 11-26-2012, 10:47 PM   #18
bruceman1968
bruceman1968's Avatar
Hey Tim, I have TDS listed as a 1980, c-10 truck, 350cid, 170 hp, manual trans, LS-9, 1x4, vin code L, and federal smog.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 11-26-2012, 10:53 PM   #19
SS Tim
SS Tim's Avatar
True... I should have mentioned that as well. Not sure but I think the engine suffix code is the same for most build sheets in box 11.
Old 11-26-2012, 11:13 PM   #20
SS Tim
SS Tim's Avatar
YES, That seems to be the only application. Found it over in a camaro forum I haunt from time to time.
Old 11-26-2012, 11:35 PM   #21
SS Tim
SS Tim's Avatar
This will help get people started.
http://www.nastyz28.com/decode.php
Old 11-27-2012, 12:26 AM   #22
72 K20
72 K20's Avatar
SSTim
Thank You for the results ! I'm pretty positive on the S in the TDS code and Bruceman1968 could be right,, the engine has a sticker on the valve cover from a local shop that has long been out of business suggesting that it is not original to the truck.
The K1212CDD is probably a 305,, it has an aluminum Q-jet intake and this seems right for one of the so called "high output 305 ". I will have to tear it down to see what it is. I know that the cam is flat on several lobes so it is ready for a rebuild whatever it is.
The TO527CLB is in my 72 C20,,the truck came with a 402 but I didn't think it was original to this truck. Either way,, it's a big block and will be coming out.
The K1212 CDD was pulled out of an 88 van and has TBI on it with the pan mounted dipstick.
This is the motor I wanted to build for the C20. I sure think that GM could have come up with a better code system.
Prime example The LS3,, 71 or 72 402,,,,, or the LS3 vortech. How about the LT-1 ?
If it warms up some I will try to get some casting numbers off of these small blocks to zero in on the year,, that will probably tell us what they are.
I thank you all for the information and discussion !! I will be looking forward to future postings in this thread !!!
Take care everyone !!!
Tom
Old 11-27-2012, 08:45 AM   #23
bruceman1968
Tom, If you grab the date code and the casting number off the blocks, we can tell you exactly what those engines are without tearing them down.
Old 11-27-2012, 10:24 AM   #24
Duncan and son
Hey Tim, you have some good info..you must have been taking your smart pills. Bruce excellent job explaining what is needed to identify an engine (picture is worth a 1000 words)
Old 11-27-2012, 10:46 AM   #25
bruceman1968
Thanks, SS Tim is a numbers guru like your son. Tim has been very helpful to lot's of members questions and he is very gracious teaching me and others the art of gm numbers decoding. It's guys like you, Jason, and Tim that make this site such a great source of information.
