Old 11-27-2012, 04:22 PM   #51
'55Chevylover
'55Chevylover's Avatar
Re: 55 Chevy stepside project
The newly painted cab is now going back on the frame. I was holding my breath the whole time.
God Bless America
'55 Shortbed Stepside
'79 C10
2010 Malibu
Not too proud of: 2011 Nissan Altima, (Not American made)
'55Chevylover is offline   Reply With Quote
Old 11-27-2012, 04:30 PM   #52
'55Chevylover
Now the front fenders, doors and new hood is going on.
God Bless America
'79 C10
2010 Malibu
Old 11-27-2012, 05:04 PM   #53
'55Chevylover
More assembly. Fenders, hood and front grill outer shell painted and installed.
God Bless America
'79 C10
2010 Malibu
Old 11-27-2012, 05:15 PM   #54
'55Chevylover
This is the steering wheel that I am going to use. It is a Flaming River steering wheel. I am going with about the same color on the interior. Also the gauge panel was specially designed with the engine turned look. Most of the panels you see on these trucks are plain chrome. I wanted something different.
God Bless America
'79 C10
2010 Malibu
Old 11-27-2012, 05:41 PM   #55
bowt1ed
Unhappy Re: 55 Chevy stepside project
Gotta say - I love that steering wheel! Nice work on the 55! Only wish mine was coming along that fast....
bowt1ed is offline   Reply With Quote
Old 11-27-2012, 06:00 PM   #56
bowt1ed
Hey 55 Lover, what tire/wheel combo are you going with? Not a bad stance without bagging. I went the No Limit Fat Bar and Camaro sub route myself (no bags) and looking to still get the nose down a little bit. Although with a cut-coil stock spring now, hopefully more with new shorter springs. Looking nice!
Old 11-27-2012, 09:47 PM   #57
Kim57
Kim57's Avatar
Looks good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 11-27-2012, 10:15 PM   #58
Highsider
Highsider's Avatar
Absolutely LOVE the color!
Highsider is offline   Reply With Quote
Old 11-28-2012, 09:00 AM   #59
'55Chevylover
Well, it is not really going that fast. I started working on it in 2001 and I am just now posting the past photos to catch up with where it is now. Thanks for the comment.
God Bless America
'79 C10
2010 Malibu
Old 11-28-2012, 09:21 AM   #60
'55Chevylover
I now have American T100 classic chrome 7" on the front with 235-60 BF Goodrich on the front. The back has 8" American mags with 255-60's. It actually dropped the whole truck about 3" with this tire. I will more than likely have to raise it up another 1 - 2"s so I can get better clearance on the front. The front suspension is now about 2" off the floor. I won't be able to drive it with speed bumps.
God Bless America
'79 C10
2010 Malibu
Old 11-28-2012, 09:38 AM   #61
'55Chevylover
Now for the wiring. I went with the Painless wiring kit. The fuse box will be at the rear of the cab between the seats. I am going to have a console with the glove box that has a false bottom for access to the fuses. This actually looked like a rats nest with all the wiring strung out. I had a professional do the wiring. He does a lot of motorcycle wiring. The wiring was run under the fenders to hide it from the engine compartment. I didn't want a lot of wires running around in there. The black wire running along the top of the valve cover is the wiring for the A/C components.
God Bless America
'79 C10
2010 Malibu
Old 11-28-2012, 09:44 AM   #62
'55Chevylover
Radiator and cooling fan installed. Some of the earlier photos of the truck. Kind of looks like a rat rod with no rear fenders. The chain at the back of the truck was so we could pull it out of the garage.
God Bless America
'79 C10
2010 Malibu
Old 11-28-2012, 09:53 AM   #63
'55Chevylover
A/C box going in, LED park lights, new door hardware, door glass, windshield and back glass is in and new Hooker Super Comp Ceramic headers.
God Bless America
'79 C10
2010 Malibu
Old 11-28-2012, 10:02 AM   #64
'55Chevylover
I had a cabinet guy finish the bed wood for me. He put the stain of my choice and put 5 coats of sealer. This sealer is what they use on boats when the wood is refinished. He did not put this on the underside of the boards because he said the wood has to breath. If he put this on the underside of the boards, they would warp. It only took us a day to install the wood.
God Bless America
'79 C10
2010 Malibu
Old 11-28-2012, 10:12 AM   #65
made2drag
made2drag's Avatar
i absolutely love your truck and how you conquered it! did you make the dash filler panel to shave it or is that something i can buy somewhere? thanks
made2drag is offline   Reply With Quote
Old 11-28-2012, 10:24 AM   #66
'55Chevylover
Brake reservoir, door wire cover from a Saturn to feed the wires out to the power windows, rear fenders on, gas tank painted black with tail lights and bed lights installed and I am going with the side exhaust in the steps.
God Bless America
'79 C10
2010 Malibu
Old 11-28-2012, 10:32 AM   #67
'55Chevylover
Made smooth firewall cover, steps installed, I am going to replace the fender welt, rear bumper installed, smooth firewall cover installed and I had the hood hardware nickel plated.
God Bless America
'79 C10
2010 Malibu
Old 11-28-2012, 10:37 AM   #68
'55Chevylover
Firing it up getting ready to bring back home. It is now sitting back in my garage. I still need to do a lot of little adjustments to it. Also, for what reason, it does not run as good as it did before I took it down for the final body work and paint. I will have to figure out what they did to it so I can get it running right again. The vacuum plug was removed from the rear carburetor, so I will have to get another fitting so I can run the vacuum hose to the power brake booster.
God Bless America
'79 C10
2010 Malibu
Old 11-28-2012, 10:47 AM   #69
'55Chevylover
I bought the new wheels and tires last week, 11-23-12 and finally got them on the truck. These tires dropped the truck 3" so I may have to raise it back up about an inch or two. I am also installing new polished angle strips in the bed. These are the valve covers and Hilborn scoop that will be going on the engine when finally finished. On the valve covers, I had the black Chevrolet script removed and powder coated with the Corvette yellow as is on the truck. Now this build is up to date. I will try to keep the updates coming until completed finished. Hope I don't bore anyone.
God Bless America
'79 C10
2010 Malibu
Old 11-28-2012, 10:51 AM   #70
'55Chevylover
This is a panel that I bought a Brothers. It is made just for the '55-'59 Chevy trucks to get it smooth. I also filled in the holes on the left of the gauge panel so it is smooth all the way across. All the stereo, A/C controls, light and wiper switches will be mounted on the console.
God Bless America
'79 C10
2010 Malibu
Old 11-28-2012, 10:55 AM   #71
Kim57
Kim57's Avatar
It's coming out real nice.
Kim
My build thread
Old 11-28-2012, 02:29 PM   #72
_Ogre
_Ogre's Avatar
looks real good.
bed wood came out spectacular
shop air compressor timer
Old 11-28-2012, 04:13 PM   #73
oldcouple
oldcouple's Avatar
So, its gonna be yellow?
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 11-28-2012, 04:45 PM   #74
'55Chevylover
Yep, it is Corvette Millineum Yellow.
God Bless America
'79 C10
2010 Malibu
Old 11-28-2012, 06:06 PM   #75
bowt1ed
What wheels and sizes did you say those were? Almost look like AR TT's.
