10 gauge copper
Any one know what 3 seperate 10 gauge copper standed wires together can handle amp wise 180 feet. Would be a total of 9 wires 3 each spliced together.
1963 chevy shortstep 327 1965 c60 292 2007 Ram 3500 5.9 cummins |
Re: 10 gauge copper
so your doing a stereo amp with 180ft of 10 gauge wire???
Re: 10 gauge copper
IM to cheap to buy good welding cable for amp wires, so I use good extension cords. I use all 3 strands for the power from battery to amp, and a short section in the rear the same, 3 wire from amp ground to body ground, as a ground should be as big or bigger then the feed and as short as possiable.
Re: 10 gauge copper
oh haha i get what your asking. i just spent like 10 minutes writing up a complete car stereo write up. i thought you meant car amplifier but your talking about amperage. just use a bigger wire. if im reading this correct you have 3 10 gauge wires that your are going to twist together thus making it like a 3 gauge? i dont know jame you need to rephrase your question
Re: 10 gauge copper
confuzed..
#6 | |
Re: 10 gauge copper
Re: 10 gauge copper
10ga wire is usually good for 30 amps, so 3 would be 90 amps. It really depends on what you're doing though...
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's. You can set my truck on fire and roll it down a hill, and I still wouldn't trade it for a Coupe de Ville. |
Re: 10 gauge copper
I have over 600 feet of good 10 gauge water well pump copper stranded wire. I was thinking rather than buying aluminum 2-2-2 entrance cable, using the copper I already have in conduit. I cant see how this would be any different that using a larger conductor if splicing 9 wires into 3 seperate runs. But wanted to insure it would carry 90A like it should in my mind. Sorry for the radio confusion.
Re: 10 gauge copper
Bad idea. You said "entance wire" so I assume you mean to power something like a garage. Follow the National Electric Code. It was made for a reason. Your was drasticly increases the possibility of carona and ringing. And I am not talking about beer or your door bell.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Re: 10 gauge copper
Agreed after more research it is not pratical. I wanted to use copper if possible over Al. #4 copper is just not economical. IN case anyone wants to know 3 -10s together = 5.5 gauge. Any two wires connected in parrell creates a 3 gauge larger cable. It is not 2xs ratio as I first thought. Just ordered 2-2-2 service feed cable so it will be done correctly.
#11 | |
Re: 10 gauge copper
Just a jumble of crap, my auidophile friends who tune their system daily with an osiloscope always give me crap for my junk science but have no choice to give it a pass as it works well. Some junk brand 800watt amp, bridged running two 6x9s in a box on one side and a single 12in on the other side. Feed on the clean mono sub out channel of a Pioneer DEH deck. Couple more 6x9s in the rear and two tweeters on the dash for mids and high. In the past long ago when gas was $1 a gallon I can member sound or noise issues that almoast always were power related, now I over do the power needs and a $9 extension cord made it easy to run power to the back of the station wagon where the amp and boxes are. But if I listened to my friends, id have $10,000 in equipment and $200 in welding cable for power wire. |
Boss Hogg
![]() Join Date: Apr 2002
Re: 10 gauge copper
Use the correct wire for wiring your structure. Don't be a Darwin award winner!
