Old 07-24-2012, 09:21 PM   #1
<<<1983GMC>>>
Lets see some custom instrument clusters
I will be installing some aftermarket gauges in my 83 and need ideas and how to do this.
If anybody has pics and steps of how to go about doing this please post them up.
All info is appreciated
thanks
<<<1983GMC>>> is offline   Reply With Quote
Old 12-06-2012, 08:48 PM   #2
4x4toy
Re: Lets see some custom instrument clusters
I would like to see some set ups too, I am thinking of going after market instruments also.
04 Yukon XL 2500 w/ Quadrasteer
61 Chevy C60, 261 inline six
86 Chevy C20 2wd, Banks 6.2
05 GMC Sierra 2500hd Duramax
4x4toy is offline   Reply With Quote
Old 12-06-2012, 09:28 PM   #3
trivon56
trivon56's Avatar
Stock but refaced
trivon56 is offline   Reply With Quote
Old 12-06-2012, 10:17 PM   #4
1981Stepside
1981Stepside's Avatar
Originally Posted by trivon56 View Post
Stock but refaced
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
Old 12-07-2012, 12:54 AM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
Take a look in my sig
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 12-07-2012, 02:51 AM   #6
bk2life
not mine, found on the net...
but i love it!
bk2life is offline   Reply With Quote
Old 12-07-2012, 10:42 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
not quite stock
replaced idiot lights to gauges/tach
added red LEDs as a second colour
and painted inside of course for added reflection
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 12-07-2012, 11:14 PM   #8
wraprail
wraprail's Avatar
Here's mine, All the pointers and faces match, all factory GM gauges and looks totally stock
wraprail is offline   Reply With Quote
Old 12-08-2012, 12:35 AM   #9
vazquezguitarras
vazquezguitarras's Avatar
This is my custom instrument clusters!
vazquezguitarras is offline   Reply With Quote
Old 12-08-2012, 11:51 AM   #10
84chevyguyid
Wraprail, where did you come up with the 150 mph speedo? I am doing a cummins in my 86 crew cab and wanted a place to mount a pyro and boost guage so I cut the upper left double gauge piece out and grafted it into the right side where the a/c vent was then grafted the a/c vent in the bottom where the radio was. I havent got any further with the project yet as I am working on putting the drivetrain in the truck still. I hit the truck wrecking yard last summer and picked up a couple of clusters with the different gauges I wanted, just need to get it all put together. Got a 5,000 rpm tach with the little fuel gauge in it, 80 lb oil pressure gauge, volts, water temp, double air gauge, (for air ride system), then I still need to buy a pyro and boost gauge. I would like a 150 mph speedometer though, with 3.54 gears, 35 inch tires, and the .61 allison 6th gear overdrive, it works out to 144 miles an hour.
84chevyguyid is offline   Reply With Quote
Old 12-08-2012, 10:28 PM   #11
wraprail
wraprail's Avatar
That looks cool with the extra gauges added.
I got the 150mph speedo out of an early 70s (71 or 72 iirc) Camaro Z28. I just saw one on ebay last week. Don't know if its still there. To install it I just removed the Camaro face, which is held on with 2 screws and sandwiched the truck face between. The screw holes line up as does the high beam light. You need the truck face for the mounting ears. Simple bolt in. I also took the Camaro needles and swapped them on all my other gauges so they matched.
Old 12-09-2012, 12:11 PM   #12
84chevyguyid
Thanks, I forgot to take a pic with the vent relocated. There is one on ebay, ends tonight, im going for it!I am going to have all my gauges white faced so I imagine I could just use the truck face and have the 150 sticker put on it.
Old 12-10-2012, 07:29 PM   #13
Hammered 77
Hammered 77's Avatar
INSIDIOUS86 is that tach/fuel gauge factory, if so where can I get one at?
Hammered 77 is offline   Reply With Quote
Old 12-11-2012, 10:25 AM   #14
carboncrew
carboncrew's Avatar
Custom but stock looking at the same time:
carboncrew is offline   Reply With Quote
Old 12-15-2012, 10:30 PM   #15
85supersierra
85supersierra's Avatar
Hey vaz I like that dash what type of gauges are those and what color is your bezel
85supersierra is offline   Reply With Quote
Old 12-15-2012, 10:43 PM   #16
JRANGER
JRANGER's Avatar
Digi Tach in my cluster, silver needles, blue leds...
Pic of my test cluster i destroyed to make sure my tach would fit how i wanted it behind my custom dash bezel
JRANGER is offline   Reply With Quote
Old 12-15-2012, 10:46 PM   #17
INSIDIOUS '86
Arrow Re: Lets see some custom instrument clusters
Welcome to the best truck forum ever hammered, the gauges are factory but...from an iroc Camaro and need much fitting and fab. In my sig is a link on the build. And here is a vid to enjoy http://youtu.be/szh8D-UoESA
Old 12-15-2012, 11:40 PM   #18
burb1085
burb1085's Avatar
burb1085 is offline   Reply With Quote
Old 12-15-2012, 11:44 PM   #19
INSIDIOUS '86
Originally Posted by burb1085 View Post
I leave you speechless?
Old 12-17-2012, 06:35 PM   #20
Hammered 77
Tell me more about the Tach/Fuel gauge. Did GM make one for squarebodies? If so will it work in place of the 5" gas gauge?
Old 12-17-2012, 07:13 PM   #21
INSIDIOUS '86
Yes gm did and very recently lmc truck had made reproductions of these so looking hard for one is no longer an issue. The issue is truck gauges go to 5k and not all have fuel gauges the lmc ones don't either http://www.lmctruck.com/newparts/csb/csbrpt.htm
Old 12-28-2012, 11:45 PM   #22
JRANGER
JRANGER's Avatar
o and now with the tach working
Old 12-29-2012, 02:20 AM   #23
KQQL IT
At the body shop.
KQQL IT's Avatar
Cut the whole dash out. 64 dash in...
