Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 12-18-2012, 04:28 PM   #1
68 TT
Still plays with trucks
68 TT's Avatar
Re: Camaro Caliper Brackets
Originally Posted by rocknss View Post
Would the 93-97 Camaro Master work in my 69 Chevy Suburban?
The 93-97 Camaro used very small single piston front calipers. I wouldn't use it. The fluid volume is probably too little to work properly with a larger D52 front caliper in a 4-wheel disc application. Look at the 98-2002 Camaro master cylinder instead. They used dual piston calipers up front with much more piston area so the fluid volume would be more appropriate.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
