Old 12-18-2012, 09:58 AM   #1
slownugly
Cupped control arm trouble??
Hey guys, i have a 69 c10 and just got done cupping the control arms to drop the front a few more inches....every little bit helps!
I know this mod has been done numerous times, so I wanted to see if anyone could shed some light on my situation.
I got the cup cut and plate welded in last night and wanted to make sure everything fit up. If I had been thinking I wouldve tack welded first then checked but, like I said I have seen this mod tons of times. I cut the desired amount out of the ca's from pictures of other members who have also done it with success. Rookie mistake!!
I got the bag centerd in the lower cup to make sure it didnt rub, it looked good! I purchased a pair of upper plates from suicidedoors bolted them up and raised the lower control arm up to check alignment.......and the bag sits back about an 1 1/2" from the top lining up with the bolt holes!???
I redrilled the top plate to align it, but it just bothers me tha it doesnt line up properly?
I have no idea why its not lining up? If anybody has done this mod and can point me in the right direction Id really appreciate it!
slownugly is offline   Reply With Quote
Old 12-18-2012, 10:10 AM   #2
bk2life
Re: Cupped control arm trouble??
Originally Posted by slownugly View Post
.......and the bag sits back about an 1 1/2" from the top lining up with the bolt holes....
i dont understand this?
bolt the bag to the arm/cup how ever you can, they will move.
this is from my 84. does this pic help at all?
(dont mind the 3x3, chassis was being sandblasted, no air in bags, 3x3 holding front up..)
bk2life is offline   Reply With Quote
Old 12-18-2012, 10:34 AM   #3
slownugly
Sorry, I didnt realize how confusing that was....if you look straight on from the tip of the control arm (ball joint), looking towards the drivers side control arm, the bag is centered in the lower cup but i hat to drill the top plate 1 1/2" forward, towards the front of the truck.
That will probably confuse you more?? lol sorry
Heres a rough drawing to help clear it up:
Old 12-18-2012, 12:15 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
You might have better luck with this if you have the Moderators move it to the "Suspension" forum. I have never heard of anyone doing this mod myself...
LockDoc
Leon
Old 12-18-2012, 12:43 PM   #5
70blackfish
i bet it just the top plates were not drilled properly for your year truck.
I think mine are the same way
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 12-18-2012, 01:50 PM   #6
slownugly
Thats kinda what Im thinking since this is pretty straight forward? The plates are designed for 63-87 c10's, so there could definitely be some differences in lay out. I wanted to make sure I wasnt the only one before I modified the top plates. Didnt think it would be a problem, but it threw up some red flags when I went to bolt up the bag to the top plate. I cant cut much more out of the bottom cup for clearance, especially not 1 1/2", but I can modify the top plate no problem.
Old 12-18-2012, 02:06 PM   #7
ol_skool_chevy
ol_skool_chevy's Avatar
Are your control arms on the right sides?..there is a left and right..
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 12-18-2012, 02:19 PM   #8
Square_78
Square_78's Avatar
The bag shouldnt be "centered" in the lower control arm. Judging by your pic that you drew up, thats probably the issue. You should bolt the bag to the upper plate first, and then mark the location for the bottom mount.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 12-18-2012, 02:31 PM   #9
RenoKeene
Florida Edition
RenoKeene's Avatar
Welcome aboard from Central Florida! Man, I sure hope you don't have to throw that stuff off Sligo bridge and start over.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 12-18-2012, 03:48 PM   #10
slownugly
Yea I pondered that at first, but the shock mounts reassured me that they were on the correct side. I was hoping that was the case since it wouldve been a easy fix, my pride might have been hurt but at least it wouldve fixed it.
You are exactly right! I didnt even think about it when I drilled the bottom mount. Logically I just assumed it was going to be centered but looking at your picture I realize that the spring pocket sits back towards the shock instead of center. Im attempting to run an 8" diameter bag and centering in my cup allows for adequate clearance, sooooo my next question is do you guys think it would cause any issues if i center it in the lower and then modify the top plate and run with that?
Haha I take it youve been up this way?? One question....why in the WORLD were you in smithville!!!???? I actually just moved up here a few months ago from Jupiter, Fl ....and to be honest Im starting to miss the weather and daylight down there!? It gets pitch black dark here at 4 pm!? Makes it had to get motivated after work...but I guess I will push through
Old 12-18-2012, 03:53 PM   #11
shawno72
C/10 junkie
shawno72's Avatar
Curious to see how this plays out.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 12-18-2012, 04:08 PM   #12
slownugly
me too! lol Got any sugeestions? I dont see modifying the top plate causing any issues as long as theres plenty of clearance, I just hope somebody with a experience with this situation can shoot me straight
Old 12-18-2012, 04:17 PM   #13
shawno72
C/10 junkie
shawno72's Avatar
I don't see why modifying the top plate would hurt but I would think it would line up. Just wondering why it doesn't..
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-18-2012, 04:54 PM   #14
slownugly
It didn make sense to me either, until Square posted that picture. If you look at square 78's picture, you can see that the stock spring pocket isn't exactly centered in the lower control arm. When I cut and cupped mine I just centered the bag in the lower control arms new cupped opening(my picture at the beginning shows my new cup), which in turn moves the top plates center line off by about 1" - 1 1/2" ....I may just fudge a little on both top and bottom until I get a happy median with adeqaute bag clearance
Old 12-18-2012, 05:08 PM   #15
shawno72
C/10 junkie
shawno72's Avatar
I think that is probably the easiest fix.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-18-2012, 05:12 PM   #16
slownugly
Shawn, Is that your truck in your avatar? How did you get it that low? LOOKS GOOD!
Old 12-18-2012, 05:47 PM   #17
shawno72
C/10 junkie
shawno72's Avatar
Photoshop for now...shhhhh
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-18-2012, 06:52 PM   #18
slownugly
Well regardless it sits good....and dont worry your secrets safe with me
Old 12-18-2012, 07:57 PM   #19
RenoKeene
Florida Edition
RenoKeene's Avatar
I havn't bagged a truck yet but you should be ok, basically it changes the bump-steer as far as a spring goes, you can adjust the change out with the final caster, camber setup. Check all your clearances in mockup for your brakes and steering. Try to factor in realistic weighs on the front end under ride height. You seem like you have the skills to figure it out.
I moved from FL to Sparta when I was a JR in high school, the waterskiing on the lake was the best I had ever seen, at 6am it was glass all the way from Sligo to Rock Island! I jumped off of Sligo bridge not once but twice!! That was 1974. Good times. My daughters live in Cookville today. Small world.
Old 12-18-2012, 08:04 PM   #20
RenoKeene
Florida Edition
RenoKeene's Avatar
After looking at this again I don't think you will have room for swaybar mounts.
Old 12-19-2012, 09:28 AM   #21
slownugly
Wow! It really is a small world. How cool! I have friends in Cookeville and if Im not out in the garage, then Im usually in Cookeville.
WAIT......WHAT!! YOU JUMPED OFF SLIGO BRIDGE!!!??? You sir are a braver man than I! Ive jumped off the cliffs by sligo numerous times and my friends and I have always joked about jumping off the bridge....but I could never bring myself to actually do it. You wouldn't happen to be the guy in the video on youube jumping, would ya??
Old 12-19-2012, 09:59 AM   #22
midniteblues
midniteblues's Avatar
sometimes I really pick up on what people say/type
i dont think u tube was around in 74'
I loved jumping off bridges/cliffs when I was younger but theres really nothing serious around here maybe 120ft. at the most.alot of us wanted more
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 12-19-2012, 10:58 AM   #23
shawno72
C/10 junkie
shawno72's Avatar
And we thought we were brave by standing on the train tresal and jump about 40ft into the river just before the train hit us Man that tresal would shake and the engineer would blare the horn. Haha good times, good times. Sadly now the kids use that area for drug use and you know what else.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-19-2012, 10:59 AM   #24
slownugly
Old 12-19-2012, 11:28 AM   #25
RenoKeene
Florida Edition
RenoKeene's Avatar
Yep, no video back then. The reason I jumped the second time was the girl I was trying to impress wasn't looking the first time and yes she was that hot! Her name was Wanda Rose and I still think she was one of the most beautiful girls I have ever seen. Whoever ended up marrying her...congrats sir, you are my hero
Now go finish your truck
