Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 09-25-2012, 01:22 AM   #251
Captainfab
60-66 Nut
Re: Power Steering Adapter Plates
Are you referring to just the spacers or the adapter plates?
Originally Posted by 62-One-Ton View Post
So do these work on a 60-62?
I wouldn't say that it changes the geometry, it just moves the steering box to the left 1/4". That can be compensated for during a front end alignment. No they do not have to be stitch welded, I just prefer to. It just eliminates one part that can move around.
Originally Posted by VA72C10 View Post
Interested in a set of these for my 67 also....any issues with steering geometry (I realize it is slight). And I'm assuming they don't have to but it makes the install easier?
Old 10-25-2012, 02:01 AM   #252
Snowbound
Snowbound's Avatar
I'll take a bracket kit for my '65. Please PM me with payment details.
Thanks,
Brian
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600
Snowbound is online now   Reply With Quote
Old 10-25-2012, 09:46 PM   #253
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Also in need of one for a 68 4x4. The previous owner hacked some holes and I keep breaking steering box bolts! I even keep a ratchet and socket to check the bolts daily.
Please shoot me a PM and I'll get you some dinero and an address.
Thanks,
Andrew
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 10-25-2012, 11:08 PM   #254
Captainfab
60-66 Nut
PM's sent
Thanks,
Brian
Thanks,
Andrew
Old 10-26-2012, 08:34 AM   #255
gmcpickup66
Captain what is the cost for PowerSteering adapter and PowerBrakes adapter? You can PM me with info and payment information. Thanks
gmcpickup66 is offline   Reply With Quote
Old 10-26-2012, 03:27 PM   #256
Captainfab
60-66 Nut
PM sent
Old 11-02-2012, 08:58 PM   #257
lowrollin70gmc
Too many projects
Bracket received with great packing and awesome instructions.
Thanks,
Andrew
Andrew
Old 11-02-2012, 10:48 PM   #258
Captainfab
60-66 Nut
Thanks for the compliment Andrew. I'm glad you are happy with your purchase
Thanks,
Andrew
Old 11-15-2012, 03:01 AM   #259
Ipaintgrt
I'm working on a 68 GMC C10 with my son and I'm putting suspension and steering from an 87 2wd suburban. I think I need one of your adapter kits for the steering box. Now I'm not sure what I need. I see in post #66 you say the 67 and 68 just need 1/4 inch spacers. Let me know what I need to do. Also the rag joint part/adapter. Thank you. Scott
Ipaintgrt is offline   Reply With Quote
Old 11-15-2012, 08:39 AM   #260
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
got my second cap'n fab plate mounted, this one on a 64 4X4.such a beautiful piece, its a shame to paint it... my next one gets clear coated!
A tip or trick, I don't know if this has been mentioned: 1 new hole falls partially over an old one, you guys know how impossible it is to drill out 1/2 a hole...
so what I did was drill the other 3 holes, bolt the plate to the frame, and then use the plate as a guide to drill out the oblong hole.
Old 11-15-2012, 10:04 AM   #261
Harley918
Can you send me a pm an tell me how to buy your stuff.
Harley918 is offline   Reply With Quote
Old 11-15-2012, 11:19 PM   #262
Captainfab
60-66 Nut
PM's sent
Old 11-15-2012, 11:19 PM   #263
Captainfab
60-66 Nut
Thanks for the compliment and the tip Jon
Old 11-22-2012, 01:49 AM   #264
travz500
travz500's Avatar
ok got a question I am putting the steering box out of my 87 4x4 blazer on my 65 4x4 frame getting rid of the original power steering it dont work well and the box leaks do I need a plate like yours to mount the newer box? I am assuming that the spacers you got on here make up for the dip in the newer frames? and does it line up with original holes in the frame or will I have to drill all new ones? thanks oh and how much for the plate? thank you
Travis
travz500 is offline   Reply With Quote
Old 11-22-2012, 02:42 AM   #265
Captainfab
60-66 Nut
Yes, you will need an adapter plate to mount the '87 box onto the '65 frame. I do not know all the specifics on the 4x4 frames, as no one has given me any feedback on those. However on the 2wd's, the adapter plate comes with a template to locate the new holes you will need to drill. One hole is partially overlapping an existing hole as Jon mentioned above. For the guys installing these on a 4x4 frame I include another measurement and 3 pics, in addition to the standard installation instructions. The price is still the same as in post #1...........which is $55.00.
Old 11-22-2012, 10:37 AM   #266
travz500
travz500's Avatar
well thank you sir when i get to that point I will be in touch with you for a adapter plate thanks again
Old 11-24-2012, 09:40 PM   #267
RustySpoke
RustySpoke's Avatar
Hey Capt. I need plates for a 1965, please send me all the info.
also I got a 73-78 front suspension and it has the 1 inch rotors is this the most desired model or is the 1 1/4 rotor the most popular? I plan on installing drop spindles.
thank you,
Greg
RustySpoke is offline   Reply With Quote
Old 11-25-2012, 01:09 AM   #268
Captainfab
60-66 Nut
In my opinion, the 1-1/4" rotors are more desireable. I do not know if anyone makes dropped spindles for the 1" rotors. You may have to get the dropped spindles for the 1-1/4" rotors and buy new rotors and calipers. New rotors should be around $40.00 each and calipers $20.00 each.
I'm sending you a PM with payment info.
thank you,
Greg
Old 12-19-2012, 07:58 PM   #269
CarlosRamirez
Hi captainfab i will be needing one of your power steering adapter plates, and a steering shaft adapter, can you pm me with info on cost and payment info. Thanks in advance!
CarlosRamirez is offline   Reply With Quote
Old 12-20-2012, 12:22 AM   #270
Captainfab
60-66 Nut
PM sent
Old 12-20-2012, 08:46 AM   #271
jlsanborn
jlsanborn's Avatar
Have you got a map with push-pins showing where you've shipped? You've sure touched a lot of trucks out there. Nice work!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 12-21-2012, 01:51 AM   #272
Captainfab
60-66 Nut
No, I haven't done anything like that. Most of my sales have been all over the US and Canada. I believe I have just one sale in Australia. Thanks for the compliment
Old 01-11-2013, 10:51 AM   #273
Racefan31820
Hi captainfab i will be needing one of your power steering adapter plates, and a steering shaft adapter,for my 65 c10 can you pm me with info on cost and payment info.
Racefan31820 is offline   Reply With Quote
Old 01-11-2013, 09:08 PM   #274
travz500
travz500's Avatar
Hey got my plate today and it fit great had it on in 5 mins. well mine is a bare frame but it fit perfect thanks (65 chevy 4x4 frame) with 87 suspension
Old 01-12-2013, 12:37 AM   #275
Captainfab
60-66 Nut
PM coming your way......
Thanks for the compliment Travis
