Old 12-28-2012, 12:02 PM   #1
70blackfish
rear mounted Fuel tank?
when you moved you fuel tank to the rear, how do you fill it?
any pictures would be great too....
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 12-28-2012, 12:11 PM   #2
Pro Performance
Pro Performance's Avatar
Re: rear mounted Fuel tank?
A lot of guys will run a door in the bed, which will give them access to the filler cap on the tank. Or have a filler cap directly on the bed floor that is tied right into the filler of the tank.
http://www.azproperformance.com/Boyd...ill-14001.html
Here is the Boyd tank.
Some filler ideas...
Pro Performance is offline   Reply With Quote
Old 12-28-2012, 12:13 PM   #3
54belair
54belair's Avatar
depends on the tank just how you fit it.
Search this site for more info. there are several threads dealing with how, and where and the types of tanks available. All very good info.
It not a big job, but will take prob. a weekend to do. Good luck.
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 12-28-2012, 12:28 PM   #4
RexDodge
Here in sunny Oregon (not) we cannot pump our own gas. Someone leaning over the side of my truck to fill my tank doesn't thrill me so I installed mine as shown.
RexDodge is offline   Reply With Quote
Old 12-28-2012, 01:07 PM   #5
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Here's mine:
TobyArnot is offline   Reply With Quote
Old 12-28-2012, 01:18 PM   #6
69GWC
For real you cant pump your own gas...?? What the heck is up with that.
69GWC is offline   Reply With Quote
Old 12-28-2012, 03:26 PM   #7
sharpmark
made my own tank and filler assembly
cut this assembly out of old behind seat tank and modified it to fit
this was out of a japper
1969 stepside-305/4spd/12 bolt posi
http://67-72chevytrucks.com/vboard/s...d.php?t=477157
1968 pontiac lemans convertible-350/pwrglde/10 bolt
1934 oldsmobile sedan-350/350/12 bolt posi
1930 model a pickup-350/350/jag ind
1928 model a roadster-283/350/9"
sharpmark is offline   Reply With Quote
Old 12-28-2012, 04:25 PM   #8
haysonj
haysonj's Avatar
Here is what I did, cut the filler out of a 96 Silverado
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 12-28-2012, 06:03 PM   #9
Tinkermc
some people and there is a thread here put it behind the tailite or behind the side marker lite, so many good ideas and so few trucks.
Tinkermc is offline   Reply With Quote
Old 12-29-2012, 12:41 AM   #10
70blackfish
Thank you for all of the replies...keep em coming!
Old 12-29-2012, 01:15 AM   #11
SS Tim
SS Tim's Avatar
Here is the factory aux. tank filler installation, essentially but not exactly a Blazer setup.
SS Tim is offline   Reply With Quote
Old 12-29-2012, 01:25 AM   #12
1972gmcblue
Does anybody know where i could find this setup?
http://www.classictrucks.com/feature.../photo_03.html
1972gmcblue is offline   Reply With Quote
Old 12-29-2012, 11:04 AM   #13
cleanfreak
cleanfreak's Avatar
I made a filler pipe to stick the cap in the left rear corner of the bed floor , that way the bed floor is still useable , without going thru the bed side , filler , or taillight.
cleanfreak is offline   Reply With Quote
Old 12-31-2012, 12:57 AM   #14
dylanprice00
i got the boyd tank but had my filler nozzle run to the side marker light and we made the light a gas door so its hidden. were still working on it but heres it on the truck with out the bed
dylanprice00 is offline   Reply With Quote
Old 12-31-2012, 03:53 AM   #15
jc70chevy
jc70chevy's Avatar
job security.... i was amazed when i lived up there it was astounding.
jc70chevy is offline   Reply With Quote
Old 12-31-2012, 09:55 AM   #16
cantcode86
Do you have any pics of this set up? It sounds like that you did it the way I've been thinking about.
72 C10 stock for now
cantcode86 is offline   Reply With Quote
Old 12-31-2012, 10:37 AM   #17
bbadfred
bbadfred
bbadfred's Avatar
Heres mine made from a race car latch, hinge and steel plate. the bed patch in front of the fuel door is for fuel line and in tank fuel pump access. Homemade alum tank with vented Speedway sprint car cap and bung.
bbadfred is offline   Reply With Quote
Old 12-31-2012, 12:21 PM   #18
Davemotohead
Davemotohead's Avatar
44 gal suburban tank in mine,,when its half full I still have more gas than the stock tank!
edited by staff
Davemotohead is offline   Reply With Quote
Old 12-31-2012, 04:46 PM   #19
cleanfreak
cleanfreak's Avatar
How's this?
Old 12-31-2012, 06:08 PM   #20
cantcode86
cleanfreak.
Thanks. That's almost identical to what I was thinking. The only difference I was thinking about mounting the filler higher in the bed. My way is a little more clunky looking. My other idea is to do a flush mount gas cap (from a custom motorcycle) in the stake hole. I can't make up my mind.
Old 01-01-2013, 01:22 AM   #21
cleanfreak
cleanfreak's Avatar
If I would change any thing , I would raise the cap a bit. It fills well , but the fuel splashes back a bit if it isn't angled perfect. Another 12" , angled cap towards the inside , might work better.
Old 01-01-2013, 08:28 PM   #22
cantcode86
That's exactly what I was thinking about doing. I think what you did is cleaner looking but up higher is a little more practical. Hopefully I can get to somewhere that I can start that project and I'll post up my pics. It's kinda hard to work on the truck in a hotel parking lot.
Old 10-13-2013, 02:06 PM   #23
70blackfish
anymore pictures on this????
Old 10-13-2013, 02:15 PM   #24
Lees68GMC
Lees68GMC's Avatar
I don't care for any of the in bed fill location Ideas, and most of the side fill have been kinda crude looking (my opinion) except the nice fill door, body & paint work shown. Just a lot of work though.
I was at a local Hot Rod shop the other day and the Shop Manager swore there's a modifier kit he saw that uses the rear side marker light as the fuel filler access door. He said you push in on it and it pops open (outward).
I'm pressing him to find the info on it because that might push me over the top to doing a tank relocation myself.
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline   Reply With Quote
Old 10-13-2013, 02:20 PM   #25
RockinRiley
Yes I know their is no cap, but if you have some wheel gap to play with you can't see that at all
RockinRiley is offline   Reply With Quote
