12-31-2012, 08:41 PM | #1 |
Motor Mounts
While acquiring parts for my T56 swap and needing motor mounts anyways I came across these and after looking at what is out there for the factory "clam shell" type they seem like crap and a poor design to begin with. They want you to peel apart a factory mount, remove the worn mount, install their mount and put the old crap back in. Lame.
I found these Camaro solid frame mounts from Moroso planning to weld them to my frame brackets and guess what. They BOLT IN! $30 from Jegs. Then I went with a PROTHANE short motor mount early 70s Malibu/Impala ish also from Jegs. They will end up being same height as stock block mount/clam shell setup, bolt in and way cleaner looking. Anyone use this? Mounts in either set of frame holes... Bolt is an old cab mount bolt I cut down Had to drill out hole in Prothane mount so I tapped threads in one end so don't actually need a nut. |
01-01-2013, 12:06 AM | #2 |
Re: Motor Mounts
Posted via Mobile Device I just rebuilt the old ones not bad just time consuming
Posted via Mobile Device |
