Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 12-11-2012, 12:30 AM   #101
Coboyle04
Coboyle04's Avatar
Re: project pacific wonder
more of the fuel lines and pump wiring harness
also the exhaust manifold and turbo housing
Chuck
Coboyle04 is offline   Reply With Quote
Old 12-19-2012, 04:18 PM   #102
Coboyle04
Coboyle04's Avatar
more pictures
motor mount
fuel pump/ filter
transmission mount
exhaust manifold
Chuck
Old 01-03-2013, 11:24 AM   #103
Coboyle04
Coboyle04's Avatar
we got the rear sway bar mounted
drive shafts arrived and in place but still need to adjust the rear axle up 3 degrees and measure for appropriate shocks
Chuck
Old 01-03-2013, 11:27 AM   #104
Coboyle04
Coboyle04's Avatar
the front axle is also in place
time to install the skid plate and finallize the fuel lines and fuel pump wire harness
also have the mounting bracket and serpentine tensioner
i purchased the vintage air ac kit and the compressor it came with will be a challenge to fit into the place we need to put it so we have decided to go with a dodge AC compressor instead
Chuck
Old 01-03-2013, 11:51 AM   #105
OLDIRON69
Cool build. Love the Cummins!
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 01-03-2013, 11:48 PM   #106
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Very inspirational!
1978 C3500 Crewcab (Project)
1979 C2500 Crewcab (Driver/project)
1988 R2500 Crewcab (Driver)
1988 V3500 Crewcab
1988 R2500 Crewcab (Mint, Ex Fire Dept)
1968 Chev Suburban (4x4 conversion) LINK
1970 Chev C20 Suburban (driver/cruiser)LINK
2005 Impala (Incognito vehicle)
2004 Yukon XL Denali (Kid hauler)
1947 Case tractor
Facebook Page(1000's of pictures of GM cars and trucks organized into albums)
YouTube Channel
Mr Pops is offline   Reply With Quote
Old 01-03-2013, 11:53 PM   #107
jbclassix
Junk Yartist
jbclassix's Avatar
what ac/tensioner bracket is that?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 01-04-2013, 12:01 AM   #108
Coboyle04
Coboyle04's Avatar
jeremy, i dont know right off but i will get back to you on that.
Chuck
Old 01-04-2013, 12:03 AM   #109
jbclassix
Junk Yartist
jbclassix's Avatar
Thank you! And the burb is looking great!
-Jeremy
Rebuilding an NP205
Old 01-12-2013, 11:56 PM   #110
Coboyle04
Coboyle04's Avatar
Jeremy, the bracket is from an industrial application motor, working on a part number for you.
Chuck
Old 01-12-2013, 11:57 PM   #111
Coboyle04
Coboyle04's Avatar
and thanks for the positive comments you guys.
Chuck
Old 02-05-2013, 02:07 PM   #112
Coboyle04
Coboyle04's Avatar
the previous accessory/tensioner bracket pictured does not work as it blocks a coolant port at the top of the motor....here is the progress on the new bracket we are machining.
Chuck
Old 02-05-2013, 02:09 PM   #113
Coboyle04
Coboyle04's Avatar
here is a customed machined swivel port for the coolant, it will mount between the accessory bracket and the motor.
Chuck
Old 02-05-2013, 02:44 PM   #114
jbclassix
Junk Yartist
jbclassix's Avatar
metal candy!
-Jeremy
Rebuilding an NP205
Old 02-08-2013, 02:19 PM   #115
Coboyle04
Coboyle04's Avatar
i have finally bolted the body to the frame....it is comming together!
some more headway in the machining department... the adapters are about finished and the gear has been mounted to the PS pump which will run directly from the cam shaft
Chuck
Old 02-08-2013, 02:51 PM   #116
vegadesign
vegadesign's Avatar
words cant explain how badass this build is,
iv been looking for 4bt locally to swap out in my truck but they are hard to find.
love the truck, very beautiful
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 02-08-2013, 09:17 PM   #117
jbclassix
Junk Yartist
jbclassix's Avatar
Chuck, is that the cummins ps pump adapter or one you made?
-Jeremy
Rebuilding an NP205
Old 02-08-2013, 10:20 PM   #118
Coboyle04
Coboyle04's Avatar
well i think it is the adapter.....i will check, you see i am not the one doing the machining work.
Chuck
Old 02-08-2013, 11:07 PM   #119
jbclassix
Junk Yartist
jbclassix's Avatar
Cool man! I would love to find the part numbers for that so i can ditch ny vacuum pump!
-Jeremy
Rebuilding an NP205
Old 02-26-2013, 01:35 PM   #120
Coboyle04
Coboyle04's Avatar
it is a factory cummins adapter
you can see the part numbers in the these pictures
i think it is tree parts
Chuck
Old 02-26-2013, 01:40 PM   #121
Coboyle04
Coboyle04's Avatar
well the push rod for the brake has been adapted with an adjustable fitting to better reach the pedal. and finally mounted. we bench bled the master cylinder and then the brakes. only 2 leaks so far. i expect more leaks when the motor is running and the hydro boost pressure is applied to the brakes.
also mounts and brakets are in process for the radiator and intercooler. should be done this week, fingers crossed!
and finally here is a picture of the grid heater for extreme cold weather starts.
the last picture is an eyelet for hoisting the motor in the future as well as a solid anchor for aligning the accessory bracket and coolant intake port.
Chuck
Old 03-07-2013, 03:35 PM   #122
Coboyle04
Coboyle04's Avatar
alternator if here...we will be adding an after market internal regulator to it.
had some trouble getting the right mounting pads for the radiator, now that we have them it is time to make the mounting brackets.
also have all the tubing bends and connectors for the intercooler, etc...
really beginning to come together.
Chuck
Old 03-16-2013, 12:28 PM   #123
scotts72heavyhalf
scotts72heavyhalf's Avatar
looking good Chuck, that will be on the road soon.
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 03-16-2013, 04:06 PM   #124
Coboyle04
Coboyle04's Avatar
hey did you enter your truck into the hot rod show this weekend?
Chuck
Old 03-17-2013, 02:19 AM   #125
scotts72heavyhalf
No, still working on it a bit, final cut and buff and a few more billet pieces on order. Working on the shop too.
Scotts72C10
