Old 01-06-2013, 11:25 PM   #1
'63GENIII
'63GENIII's Avatar
'63 K NV4500 removal / reverse build thread
This is my first time posting any type of build thread so please be patient. I've learned so much from the members on this forum without anyone asking anything in return except pictures.... so that said here we go.
I bought this truck in 2008 from a guy in Oregon. Who said he was the 2nd owner. As I drove it back to the Bay Area, I promised the 396 that if it got me home that one day I would put an overdrive in it. I ended up getting towed home from Redding but I'm still keeping my promise. Enter the NV4500.
My '63 was an Oakland built K15 that may or may not have come with a small block and 4 speed. I say small block because it uses the small block motor mounts on the sides. There is now a 396 in its place and as far as I know, the mounts have not been moved. When I bought the truck in it also had a floor shifted TH400 of questionable durability. It also has an HEI with no firewall clearance issues or dents. Out front I installed the serpentine drive from a '97 454 with the reverse rotation water pump. Theres about 2" from the factory fan to the radiator. Main reason that I mention this is that I have heard alot of talk about moving the engine forward.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 01-07-2013, 12:00 AM   #2
'63GENIII
'63GENIII's Avatar
Re: '63 K NV4500 removal / reverse build thread
I bought the transmission back in October from a guy off of C.L. I believe it to be out of a '94 c3500. Its came with a stock bellhousing, clutch and complete hydraulic clutch pedal, master and slave set up. The guy I bought it from said he had a shop look at it and it was given a clean bill of health before he installed it in his Blazer. He said it ran perfect no grinds - no popouts.
As soon as the last Christmas guest left, I began pulling out the old TH400 with the intent of a three day turnaround. I didn't take pics at the time BC I was in a huge hurry. Working on youre back on fairly steep driveway in between rain storms has a way of doing that to you. So Dec. 30th I finished bleeding the clutch for the 4th time and I took her for a ride. First thing I noticed was the incredibly short, positive throw of the 4500. The second thing was that my 2-3 shift was grinding EVERY time. I did say that he told me it was perfect right? I checked the clutch release point a few more times, made absolutely sure that I had the correct transmission fluid (because I had been warned not to use the wrong one) and then it dawned on me... When I bought it, I did at least open the inspection cover just to take a look and distinctly remember the strong gear oil smell that came out of it. When I put the synthetic stuff in, no such smell. I'm guessing that the P.O. put regular gear oil in and hosed the syncros. From what I hear, it doesn't take long. I figure that I'm pulling it out to do the syncs anyway so I figure I'll take pics in hopes of helping some of the members here that are doing their swaps.
I'll start with what it looks like installed and go backwards. Hereit is in 1st and 2nd gears. There's about 3" to the AC unit and a little over 1" to the front of the seat.
Enjoy the pics.. Chris
Chris
'63 k15 long step
Old 01-07-2013, 12:07 AM   #3
Redcap
Now that is a sweet old truck!
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 01-07-2013, 12:09 AM   #4
'63GENIII
'63GENIII's Avatar
I bought a replacement clutch master BC the one I had was leaking and I was stalling while trying to figure out wher to put it. I ended up putting it farther to the drivers side of the brake booster and the pushrod lined up with a hole that was already in the pedal arm. I ground down the end of an old brake pushrod (so that it fit the new master), gave it a very slight bend and installed it. I could have really used on of Captainfab's cool brackets here! The clutch release point is about 1/3 of the way off the floor and has a good feel to it.
Chris
'63 k15 long step
Old 01-07-2013, 12:24 AM   #5
'63GENIII
'63GENIII's Avatar
I had one of the kids help me bleed the slave, which, if you're not paying close attention (like I wasn't) can drain the little master quite quickly, making it necessary to start all over again The preformed clutch line/tubewas plenty long enoughand had small clamps that allowed it to be secured to the bellhousing bolts. The preformed bends did make it a little aggravating a few times though.
Hey John, I thought you may like this shot I took to show the clearance between the front DS and the slave. It's just over 4" to contact. I don't think that the front of my truck has that much travel anyway. I think it will be fine.
Chris
'63 k15 long step
Old 01-07-2013, 12:33 AM   #6
'63GENIII
'63GENIII's Avatar
Here's the new driveshaft (halfshaft?) that mates the original T221 to the NV. 12-1/2" to be exact. The guy who built it said he didn't want to reuse the old one due to it having some pretty bad welds. Interestingly the new shaft is actually 1" longer than the one for the TH400. I'll try toadd some side by side pics later.
Chris
'63 k15 long step
Old 01-07-2013, 12:44 AM   #7
'63GENIII
'63GENIII's Avatar
Here's the home made transmission jack waiting to lower the transmission. I highly recommend taking the stub shifter out before installing and removing this trans. Just makes it a little easier. I did strap the trans down to the 6x12 just to be safe. I also jerried up a trans brake (BC the driveway is about a 20-25 deg. slope). Don't laugh it worked!
Chris
'63 k15 long step
Old 01-07-2013, 12:57 AM   #8
'63GENIII
'63GENIII's Avatar
I did have to lay the NV on it's side to get it out from under the truck. This is where a lift and a real transmission jack would have come in handy. The 20$ per quart oil sure comes out WAY faster than old gear oil used to! Hopefully it cleans up easier. I can't wait to try and put this thing back in LOL. BTW I was trying to lay it on it's side on the jack and roll it out. It decided it wanted to lay on the ground. There wasn't much arguing. It weighs over 200lbs.
Chris
'63 k15 long step
Old 01-07-2013, 01:03 AM   #9
'63GENIII
'63GENIII's Avatar
Here it is on the workbench draining the rest of the synthetic stuff. I think it left about a quart on the driveway already. I ordered a manual from Quad4x4.com so that I can see if this is going to be a DIY repair or if I have to take it in. I'll try to take more pics of the underneath of the truck while the trans is out.
Chris
'63 k15 long step
Old 01-07-2013, 01:07 AM   #10
'63GENIII
'63GENIII's Avatar
Thanks. Just trying to give it a few upgrades and keep it "old" at the same time.
Chris
'63 k15 long step
Old 01-07-2013, 01:35 AM   #11
'63GENIII
'63GENIII's Avatar
Here's the hydraulic line attached to the bellhousing bolts. The clutch is a standard replacement 12-1/4" kit from Oreilly's. While it says Sachs on the boxes, the parts were all stamped Valeo. The flywheel is for a '69 396. The clutch kit came with a pilot bearing but I opted for a bronze bushing as I had heard of some issues with the needle bearings.
The second pic is of the trans hump and what I had to do to it in order to get the trans in. That was before I had learned that the stub shifter comes out . It was butchered by the P.O. anyway. As soon as it's running again, fixing the tunnel is one of the first things on the list!
Chris
'63 k15 long step
Old 01-07-2013, 01:43 AM   #12
'63GENIII
'63GENIII's Avatar
Here's the old and new DS side by side. The welds on the new one are WAY cleaner than the original. Spicer Joints. The guy does killer fast work and is affordable. He had it done 2 hours after I dropped it off.
Another pic on the bench. Damn thing's heavy!
Chris
'63 k15 long step
Old 01-07-2013, 01:52 AM   #13
'63GENIII
'63GENIII's Avatar
Ok. So I couldn't wait for the manual to get here Tuesday! I pulled the shifter cover and one of the inspection covers. Guess I better wait for the book. I have no idea what I'm looking at let alone what to be looking for. The gears in this thing are pretty massive! After looking at the gears though, they don't apear to be very worn or have any strange wear marks or chips that I can see. I have no idea yet if I can even see or inspect the syncros while it's still together. Should know more on Tuesday.
Chris
'63 k15 long step
Old 01-07-2013, 09:35 AM   #14
Zane M
First off, awesome truck!
I look forward to seeing the progress of this "journey".
Zane M is offline   Reply With Quote
Old 01-07-2013, 10:57 AM   #15
Yukon Jack
Yukon Jack's Avatar
Have to agree with everyone else, that is an awesome truck - I really like that body style in the 4wd flavor!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-07-2013, 01:26 PM   #16
61K10
61K10's Avatar
agree, nice truck! great build as i was thinking of doing the same to my 61k10. thanks for the build.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 01-07-2013, 02:53 PM   #17
SunSoaked
SunSoaked's Avatar
Some of that synthetic fluid leaked out of my 4500 onto the driveway last week. It penetrated the concrete and my ZEP concrete cleaner wouldn't even touch it. It beaded up and ran off like water on a duck. It must be some slippery stuff
My fluid was clear however, but it was still new (less than 200 miles).
Good thread.
SunSoaked is offline   Reply With Quote
Old 01-07-2013, 04:09 PM   #18
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Really cool swap. That is the beauty of divorced transfercases, you can easily swap just about any transmission combination in there with ease. That looks like an early NV4500 with the nice low granny gear too! Nice work and sweet truck!
DirtyLarry is offline   Reply With Quote
Old 01-07-2013, 10:24 PM   #19
'63GENIII
'63GENIII's Avatar
Thanks for all the compliments. This is my third. I started with a '62, then a
'64 and now the '63. I like this one the best so far. Maybe because this is the only one that I've been able to get running and roadworthy too!
Hey Jack you've got some pretty cool trucks yourself! Love that bodystyle too. Wish I could have a Chevy "preserve" where I could keep all the ones I like. It's a sickness I think.
61K10 - My kid brother is down in Roseville not too far. Love that truck of yours too. There used to be a guy around here with a '60 3/4t fleet BBW but I think the uppity neighbors either ran him out or he got rid of the truck. no appreciation for the "patina".
Chris
'63 k15 long step
Old 01-07-2013, 10:31 PM   #20
'63GENIII
'63GENIII's Avatar
Good thread.
I threw the kitchen sink at it as soon as I got it moved. Foamy Engine Brite, Castrol Oil Eater and then some old school regular Tide (not that HE stuff either!) It cleaned up pretty well but it's also been dark every time I've had a chance to look. Funny you mention yours was clear. Mine was clear going in but black coming out. ..Less than 5 miles. Looks like I flushed out the old syncro material I guess. I think I may have to find a cheaper flushing oil! LOL
Chris
'63 k15 long step
Old 01-07-2013, 11:40 PM   #21
'63GENIII
'63GENIII's Avatar
Hey Larry, First off I'd like to personally thank you for all of the super detailed posts on your swap. Your truck to me is the armageddon truck and the trips you take with it are awesome! If I ever get some time off, a trip like those would be my ideal vacation! I'd also like to blame youre making it look easy which lit a fire under my*ss to do this swap! In all seriousness though, I was on the fence between a 4L80E and the NV. It was your thread that made gave me much of the info I needed to even attempt this swap.
The guy I got it from said it was out of a '95 but it has a build date on the tag of 10/29/92 and yes it does have the lower 1st gear. That gear is really low. Starting out in 2nd seemed comfortable for the few miles that I did get to drive it. The short shift throw is what's really impressive. I grew up with sm420's, 465's, a T19 (I think) and even a Clark 5 spd. The NV shifts like a race car compared to anything I'd ever known.
As far as the divorced set up goes, I've heard some people say that it's just another set of U joints to worry about. I don't worry about it too much as I try to keep an eye on that stuff and usually things don't get too out of shape before I fix them. I too like the setup for the flexibilty it has and the easier driveshaft angles.
I picked up a divorced 205 after hearing that the T221's were prone to burning up. While not as strong as the 205, the 221 has held up real well since I got the truck. The 205 is just sitting for now. Someday.
Thanks for the kind words and the great reading material. Hopefully the manual comes tomorrow so I can start trying to get it back on the road!
Chris
'63 k15 long step
Old 01-10-2013, 02:19 AM   #22
'63GENIII
'63GENIII's Avatar
So my manual showed up from quad4x4 yesterday. It seems detailed enough that Im confident that I can pull this job off. Upon looking closer and with the book in hand, it does look as if the third gear syncros are hosed as well as the third gear syncro teeth (meaning a whole new third gear) and the 3-4 syncro ring. The manual says that the two most common causes for 3-4 syncro failure are; a. wrong or dirty fluid or b. excessive mainshaft endplay. I was able to check endplay without completely disasembling the unit and it seems within the specs.
After thinking about what SunSoaked said about the condition of his fluid, the gear oil smell that I first noticed, the color of the fluid after I drained it and all the black "silt" in the bottom of the trans, I'm inclined to think that it was just the wrong fluid used in the past sometime. Which is the best bad news I could get right now.
At the moment, I'm collecting the tools needed to do the dissasembly / reassembly and may even make a couple of the puller collets as I really have to try to not spend alot of $ where I don't need to. I stopped reading the required special tool list when I hit about 700 bucks. So far I picked up a floor press off of C.L. today for 80$ and ordered a bearing splitter / puller set which started out at 140 + tax and ended up at 90 (with some price matching) including tax and shipping. I figure I can use the stuff again when it comes time to do axle bearings and seals on the wifes Yukon.
Untill its completely apart, Im really not going to know the full extent of the damage but at first look, I may be into this for around 275 + tools if Im lucky. Im still fairly p.o.'d at the guy who sold it to me for not being honest but I figure I've got to let that go. At least I'm learning more about something that I'd never otherwise have a chance to learn about.
I tried taking pics of the syncros but the camera couldn't focus in on the small teeth that are messed up. I'll try again while dissasembling and may have a better shot. I would like to post pics of the tools that work and hopefully save some money over the "specialty tools" in hopes of saving someone else a couple of bucks too.
Chris
'63 k15 long step
Old 01-13-2013, 08:08 PM   #23
low67chevy
The first pic of the inside of the tranny dude is the mainshaft assembly and the 2nd is the counter shaft just below it , the NV series of transmissions are very easy to rebuild ONCE you have most of the special tools lol remember also to make sure you put loctite on that 5th gear retaining nut if and when you get it off to rebuild it, if not your gonna be in a world of pain later on when all of a sudden you lose 5th gear.
If you need help with it ive rebuilt a couple of those trannys and am currently building another for my 57 chevy snow wheeling rig, shoot some questions and pics of anything that stumps you and I might be able to give you a hand.
cheers
Nick
low67chevy is offline   Reply With Quote
Old 01-15-2013, 12:18 AM   #24
'63GENIII
'63GENIII's Avatar
Thanks Nick. Im slowly putting together the tools which now includes the 1-1/2" socket for getting the yoke off of the back. Now I just need the time to start breaking it down. Id love to see a pic of that '57. I had one back in the day. It was 1 ton Napco with a utility bed. That had a Clark 5 spd in it. Thanks for the offer, I may have to take you up on it if I get stuck on the NV. Thanks again, Chris
Chris
'63 k15 long step
Old 01-15-2013, 04:28 AM   #25
argonaut
argonaut's Avatar
Looking good man! I love your truck and I'm glad to see its getting a little overdrive lovin'!
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
