![]() Join Date: Aug 2005
Tilt Column from burned truck
This column is an original truck column that was in the truck I was driving when it caught fire on the Interstate.
The tilt works, but the fire melted the aluminum housing. Thought somebody might have the parts needed to make it whole. 40.00 plus shipping |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Re: Tilt Column from burned truck
how bad would shipping probably be? Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
Ill get in line, if the tilt is working
Moderator
![]() Join Date: May 2007
This is a good ballpark. I have shipped columns in the past as well.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
![]() Join Date: Apr 2010
I,ll take it, if it gets to me
SWB 4x4 Collector
I believe i will pass on this. Thanks for getting back with me.
It was working a couple years ago, but I didn't specifically check it yesterday. I'm going to where it is on Saturday and will check it then to make certain. I'll get back with you over the weekend or Monday. You're first in line.
I'll take it if everyone else passes.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Thank you, i can wait. Just concerned if it melted the aluminum, what kinda shape the knuckle is in
72 chevy
![]() Join Date: Jan 2007
where you located at
Ed |
I'm in Rantoul, but the trucks/parts are in Arcola.
Dirk |
OK, the tilt appears to be OK, but when I had it in my hands and looked closer, the shaft doesn't turn. I assume it got hot, melted the grease out and then rusted, because after the fire it turned just fine.
I think that's about all I can tell you about it, but if you have more questions, please ask. Thanks, Dirk |
#15 | |
#16 |
Has this column sold? If (Jaros44sr) passed I'm up, let me know, thanks Les
#17 |
Les, go ahead of me, i was just going save it as a back up. You probably need it to sell a tilt, putting another one in service. Good luck, i hope it works for you
#18 |
OK, it looks like it's available. If you want it let me know. I told Jaros44sr that if it isn't usable I would credit the 40.00 and you would just be out the shipping. Mutual trust, that's what is so nice about dealing here. I make the same offer to you or anybody.
#19 |
I will go ahead and take it, PM me with your payment information, thanks Les
Tags |
tilt column |
