01-11-2013, 03:28 PM | #51 |
GEARHEAD
Re: PROJECT EVOLUTION 70 jimmy build
Nice color. What is it?
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
01-11-2013, 03:34 PM | #52 |
its a copper orange,, it was vht high temp engine paint..comes very close to the color we are painting the rig
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
01-11-2013, 03:43 PM | #53 |
That looks great
Scott |
01-15-2013, 08:50 PM | #54 |
well, ordered my adapter today for the transfercase,,the guy on the phone cut me 150 bucks off,,i was surprised,,still 600 bucks, but saved some dough
01-23-2013, 02:52 PM | #55 |
got the AA kit today,all minus the reluctor ring, it was on backorder, i cant finds an image of what is exactly included in this kit so i decided to show you guys what you get for 700 bucks..all the machining is done,, this is a bolt on adapter from the box(once you have your tailshaft changed)
01-23-2013, 03:25 PM | #56 |
Nice stuff, 700.00 doesnt go very far on these old trucks
01-23-2013, 04:05 PM | #57 |
no it doesnt, plus the 250 bucks for the new gaskets, filters,pressure control switch, update kit, and shell just to maintain the reliabilty of the transmission,but in the end, i should not have to pull it back out
01-24-2013, 11:26 PM | #58 |
well, since the tranny is out getting worked on, i figured i would knock out the gauge cluster,,came out pretty good
01-28-2013, 05:23 PM | #59 |
after checking this out in the blazer, i realized that i couldnt see the top inch of the gauges,,so i had to redo it,,although i think i like it better like this, plus it has perfect vision of everything
01-28-2013, 08:21 PM | #60 | |
Just a nother gear head
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 |
01-30-2013, 12:01 AM | #61 |
its coming along real nice. Nice score on the AA kit I'm getting ready to order one after all. Anyone in particular I should talk to.
71 K5, AC/Tilt, 4" lift 33" tires 5.3L/4L60E/NP 205 (Under Construction) 05 Dodge 2500 4x4 5.9 Cummins (Daily driver) "Common sense is not so common" My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=555879 |
01-30-2013, 01:09 PM | #62 |
talk to matthew,,,kind shoot the sh#t with him,,he will cut you a break
01-30-2013, 01:13 PM | #63 |
Will do thanks for the info.
02-04-2013, 09:27 PM | #64 |
started working on the hood today,,its coming along nicely
02-05-2013, 08:12 AM | #65 |
GEARHEAD
Nice!
02-11-2013, 03:40 PM | #66 |
got the hood in epoxy primer,,just need to put some seam sealer on the underside and some filler primer before i paint it,,but came out really nice, i like it
02-11-2013, 03:49 PM | #67 |
That looks great.. looking forward to seeing it on the truck. I really like how it still has the center ridge. A lot of the cowl hoods I've seen don't have that.
02-12-2013, 08:23 PM | #68 |
finally got the tranny back so i got the drivetrain in the truck,,had to redo my mounts, but that was expected
02-15-2013, 03:11 AM | #69 |
ordered some TBSS manifolds, so hopefully those should take care of that, and also took the driveshafts to the shop to get them lengthened...started removing the gas tank out of the yukon, the ol lady had to go to the hospital for some numbness..not sure what happened,,i just tell her its a lack of..... anyway...should have the tank out so i can get the fuel pump out and start fitting it in the blazer tank
for future refernece for anyone..TBSS manifolds http://67-72chevytrucks.com/vboard/s...d.php?t=565949
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 Last edited by hilljob26; 02-17-2013 at 09:35 PM. |
02-15-2013, 08:17 AM | #70 |
GEARHEAD
Great progress. Looking real good.
Numbness in the wife, never a good thing. Take care of her.
02-15-2013, 10:10 AM | #71 |
You have one sweeeeeeet ride coming along!! I'm going to be watching this.
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
02-17-2013, 09:36 PM | #72 |
it should be pretty nice when all said and done,,working on the fuel system now,,hopefully have some pics in a day or 2
02-19-2013, 03:27 PM | #73 |
well, time to figure the fuel system out,,i got the lines to the engine ready for new line,,i got the pump and cut the ring out of the 01 yukon tank,now i just need to get it to fit in the blazer tank,which is plastic, and sucks really bad,but its what i have....didnt get too far ...had to get to work, but i did manage to make the piece that i will fit in the tank to drop the pump down
02-23-2013, 04:51 PM | #74 |
got the tank all done and sealed up,,used about 3 tubes of seal all,,its the only sealant i could find that was gas and oil resistant, i kind of underestimated how hard it was going to be to bolt it up,i couldnt get my arm all the way on the bottom side, so i had to take some all thread and hold the brace on the underside then bolt it up from the top,,also had to make a couple curved pieces to follow the contours of the tank to ensure a good seal,,it came out well,,you will never see it when its in anyway,,but i didnt have to spend 400-600 bucks on a tank
links to questions i asked relating to the fuel http://67-72chevytrucks.com/vboard/s...d.php?t=566624 http://67-72chevytrucks.com/vboard/s...d.php?t=491781
02-24-2013, 08:00 PM | #75 |
tank is in,lines are ran,,,gettin closer every second
