01-12-2013, 10:17 PM | #1 |
Re: "cruznby" w/ big block
Some serious wheel tubs in the back, looks like you'll be running some serious rubber
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly |
01-13-2013, 01:07 AM | #2 |
67ctener I do plan on runner some large tires i am planning on some 20x11 if the budget allows we will see thanks for looking
2008 HD 2010 Camaro 2ss (The Wife's Ride) 2005 Suzuki GSX-R 1300 "Busa" 1969 C-10 (under Construction) 2013 Sonic LT "LIVE LIFE,TASTE DEATH" |
07-07-2013, 09:54 AM | #3 |
Formerly- 1972SuperCheyenne
Looks like its coming right along. That cab looks killer! Look forward to more progress.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
07-07-2013, 04:37 PM | #4 |
been a while since I have posted but got the front suspension back in for a test fit
I currently have the rear end tore apart to put in c-notch, 6" drop springs, 1" lowering blocks. I am also building my own rear disc brake set up, promise to post pics as soon as I can find them
11-15-2013, 11:12 PM | #5 |
Got my rear disc brake set up done,made my own rear caliper brackets,used 05 avalanche rear calipers and 00' chevy truck front rotors. C-notch is in and I debated on flipping the trailing arm brackets for my drop and decided it was a way better idea to order PB's trailing arm cross member. Way more options for adjustability with that option. Couple more weeks I will be able to disassemble and paint frame and components. Next up fuel system for the 8 liter.
11-15-2013, 11:14 PM | #6 |
Well pics won't post I will try again tomorrow
11-28-2013, 04:40 PM | #7 |
got pics to work, first one c-notch, second one my rear brake set up
