Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 01-15-2013, 10:20 AM   #1
rs74
rs74's Avatar
About how much does a 60 panel weigh.
My trailer is rated at 7,000 pounds. I am going to possibly get a 60 panel and dont know if they are rated heavier than the trailer. I loaded my old 63 K20 on it and end up bending one of the axles do to the weight. Of course it was a brush truck for the local fire department and had a few extras on it.
rs74 is offline   Reply With Quote
Old 01-15-2013, 11:05 AM   #2
Reyals Bemus
Re: About how much does a 60 panel weigh.
They certainly don't weigh that much. You'll be fine with that trailer.
Reyals Bemus is offline   Reply With Quote
Old 01-15-2013, 11:22 AM   #3
rs74
rs74's Avatar
I didn't think so but after loading the 63 K20 I wanted to make sure.
Old 01-15-2013, 11:49 AM   #4
63burban
Chevy addict
7000 lbs includes the weight of the trailer, most trailers weigh around 2000 lbs so you can haul 5000 lbs. You didn't say if this was a 1 ton panel or 1/2 ton panel. I have hauled a one ton panel on my trailer, I took it real easy and had no problems. The faster you go the harder it is on the wheel bearings and tires when you have a heavy load.
63burban is offline   Reply With Quote
Old 01-15-2013, 11:53 AM   #5
rs74
rs74's Avatar
Yeah that is my fault. It's just a 1/2 ton.
Old 01-15-2013, 01:28 PM   #6
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Panel is likely in the 4000-4500 lbs range, depenind on what's in it. You're likely close to the limit on that trailer but should still be under it.
I put my '65 panel on a U-haul car trailer with no problems.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-15-2013, 07:49 PM   #7
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
My 61 1/2 ton fleet pickup weighs 3700 with me in it if that helps.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 01-15-2013, 08:42 PM   #8
ABX131
ABX131's Avatar
Up here in WA our transfer stations (the dump) charge based on weight. They weigh you on the way in and then on the way out and the difference is your load weight. It shows on the receipt the in and out weights...not sure if other areas do that but it is a great way to get your truck weight. Also all gravel pits, quarrys, and landscape materials companies have scales for their dump trucks and are usually friendly about letting you drive across to determine your weight.
ABX131 is offline   Reply With Quote
Old 01-17-2013, 10:53 AM   #9
rustyrodknocker
Those are my favorite car trailer. I love the short deck. They don't drag on every transition and tie down is a snap. A friend got ahold of one with no axles . Which is hard to do . Uhaul scraps them if they can't fix them.
You also have to make up a story about towing volgswagon if you want to rent them.
rustyrodknocker is offline   Reply With Quote
Old 01-17-2013, 11:20 AM   #10
chevy_mike
chevy_mike's Avatar
Yep... I was towing a "Miata".
Old 01-18-2013, 11:47 AM   #11
hemifalcon
Hahaha... I was towing a "1961 Volkswagen" too!!! ;-)
My '65 Suburban Resto build--
http://smg.photobucket.com/albums/v6...65%20Suburban/
And it's story of being 'saved'
http://www.jalopyjournal.com/forum/s...d.php?t=631495
hemifalcon is offline   Reply With Quote
Old 01-18-2013, 11:54 AM   #12
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Add 200 lbs for the 1960-62 frame. 1963 Chevrolet had a new lighter frame. Curb weight is at the bottom of the page.
Old 01-29-2013, 01:20 AM   #13
Brad54
Brad54's Avatar
My '61 Suburban went over the scale at exactly 4,000 pounds with a rear seat, most of a tank of gas, me, my son and a 100 pound tool kit.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
