01-30-2013, 11:47 PM | #1 |
60-66 Nut
Re: D52 Caliper Rear Disc Brake Brackets
Did you check to see if the shaft is rotated as to engage the parking brake function of the caliper. If not you might try turning the shaft coming out of the back of the caliper. A box end wrench or a deep socket should work to grab it. I just don't remember what size off hand.
01-31-2013, 07:00 PM | #2 | |
Building Dreams out of Dimes!
Posted via Mobile Device Last edited by Hazieview; 01-31-2013 at 07:21 PM. |
01-31-2013, 11:48 PM | #3 | |
60-66 Nut
I have a pair of used calipers at the shop. I'll check out the fitment tomorrow and post my findings here. I have not heard of this issue from any of my other customers.
02-01-2013, 06:07 PM | #4 |
Do you know of any customers that we can contact? Perhaps they can be of some assistance too. What size rotor, caliper inside width, and brake pad width and what brand they went with is all I need.
thanks!
1981 Chevy short/wide. SB400 350th |
02-01-2013, 09:26 PM | #5 |
Would this work on a 69 Suburban C20 rear axle (8 bolt drum)
Thanks |
02-01-2013, 11:45 PM | #6 |
60-66 Nut
No, These only work with the '64-'82 GM truck 12 bolt and '80-'87 truck 8.5 10 bolts.
Does your Suburban have the Eaton HO52 or the Dana 60?
02-01-2013, 11:42 PM | #7 |
60-66 Nut
Right now I can't think which of my custromers that have bought these brackets are using the Eldorado calipers.
I can not get a set of the D122 pads until tomorrow, but I did put a set of the D52 pads in a Eldorado caliper today. With the piston all the way retracted, there is 1.312" (1-5/16") between the pads. The pads I used were each about 9/16" thick. I'll check again tomorrow when I get the D122 pads.
02-02-2013, 10:48 AM | #8 | |
Posted via Mobile Device |
02-03-2013, 12:06 AM | #9 |
60-66 Nut
I got my D122 pads from O'Reilly's this morning. I put a set inside a caliper and the Astro rotor fits with a little room to spare. The D122 pads are noticeable thinner than the D52 pads. I didn't get a chance to try a set of D52 pads with the rotor as I had a bunch of work to do today. I'll try and check the D52 pads tomorrow.
