Old 02-01-2013, 07:35 PM   #1
jmedero
jmedero's Avatar
New air ride valves. Simple and clean.
I've decided to change my air ride set up. I had te accuair set up but just wanted to simplify everything. Project started to get "complicated" if you know what I mean. I started the search for a simpler but excellent quality manual valve set up. I found board member DLOE who sells and makes his DLOE valves. Saw the video and did some research and I'm sold. Ordered me 4 valves and fittings ... $240!!! Can't beat that. Here is some information from his web site and a video.
http://dloesvalves.webstarts.com/index.html
http://youtu.be/aZMW3RVDVkQ
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 02-02-2013, 03:18 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: New air ride valves. Simple and clean.
I like these alot!
Keith
Convert to disc brakes.
Old 02-02-2013, 09:08 AM   #3
jmedero
jmedero's Avatar
I do too. I placed an order yesterday at 3pm and had a shipping confirmation and tracking number by 5 pm. Can't wait to get them installed.
Old 02-02-2013, 05:42 PM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I agree... these things look awesome and I hope to use them sometime in the future.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-02-2013, 06:24 PM   #5
bigbeardedbastard
i wish the were a bigger than 1/8" otherwise i'd be all over them! i tried emailing him but the addy given doesnt seem to work?
bigbeardedbastard is offline   Reply With Quote
Old 02-02-2013, 06:33 PM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
jmedero... can you provide me with some measurements of the switch itself?
Also have you sourced your fittings yet? Curious what you are planning on running and how much that will add to the overall length/width of the switch.
-Nate
Old 02-02-2013, 06:34 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
His boardname is DLOE65.
-Nate
Old 02-02-2013, 06:38 PM   #8
bigbeardedbastard
great! thank you sir!
Old 02-03-2013, 12:24 AM   #9
jmedero
jmedero's Avatar
Ok the air lines are 1/4 the exhaust is 1/8. Fittings can be had by Derek when you order your valves. I had him include all the fittings I would need. Nickel platter like the valves. At 1/4 they flow fast and the switch operation them selves are very smooth.
Old 02-03-2013, 05:28 AM   #10
DLOE65
DLOE65's Avatar
Hey guys, here are a few measurement pictures for you. Hope these help! The fill,dump and supply lines all have 1/8" npt ports. I can supply 1/4" tube by 1/8" npt fittings for the valves. You could run 3/8" lines if you really wanted to but it would be so bulky and kind of a pain in the butt. I dont recommend it. You really wont see any gain in speed either since the internal diameter of the threaded portion of the fitting is the same.
DLOE65 is offline   Reply With Quote
Old 02-03-2013, 02:54 PM   #11
Rusbuilt
Rusbuilt's Avatar
These are great! I helped board member Cubber install his on his 69 step side! very simple install and they function just as they should!
Rusbuilt is offline   Reply With Quote
Old 02-04-2013, 01:07 AM   #12
Zoomin
Man of Mini-Talents
Zoomin's Avatar
How much is the whole panel/gauge setup?
Zoomin is offline   Reply With Quote
Old 02-04-2013, 01:44 AM   #13
jmedero
jmedero's Avatar
I coppied a pm from Derek with the pricing on the parts.
Here's a breakdown of everything..
Valves ($49.00 each)
Nickel plated fittings ($5.00 each) *need 8 for the whole setup*
4x1 fitting ($5.00 each)
Mufflers ($4.00 each)
Polished aluminum gauge/valve panel ($29.00)
Shipping is a flat rate of $10 bucks.
Thanks,
Derek
Check out my Manual Valves
Old 02-04-2013, 02:12 AM   #14
DLOE65
DLOE65's Avatar
trying to find a different 4x1 fitting, i cant get the same one anymore
Old 02-04-2013, 02:52 PM   #15
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Thanks,
Derek
If you have time can you post a picture of the 4x1 fitting?
-Nate
Old 02-04-2013, 02:55 PM   #16
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nevermind... I think I found it in another picture.
-Nate
Old 02-04-2013, 06:21 PM   #17
jmedero
jmedero's Avatar
That's the one.
Old 02-04-2013, 07:14 PM   #18
ulakovic22
Is there enough room for the mufflers in the picture of the whole assembled setup?
ulakovic22 is offline   Reply With Quote
Old 02-04-2013, 07:37 PM   #19
DLOE65
DLOE65's Avatar
My current panel cannot use the mufflers. I am working on a new panel that will have the valves in a different position and make the panel a little smaller. I also have new mufflers that have a smaller profile. ( cheaper too). I am going to update my webpage tonight with new pics and more info.
Old 02-06-2013, 03:21 AM   #20
cubber
These valves work great! I am running a 200 psi pressure switch, and I was surprised at how fast they air up. DLOE is a great guy to do business with, he has helped me with advice on several aspects of my build.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 02-06-2013, 02:25 PM   #21
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I really like that 4-to-1 fitting; hopefully you can locate an alternative one that is as compact.
-Nate
Old 02-07-2013, 12:50 PM   #22
DLOE65
DLOE65's Avatar
Updated the website a little bit, new mufflers, more pics
Old 02-07-2013, 08:12 PM   #23
jmedero
jmedero's Avatar
Got my valves in on Tuesday. Man that was quick. Order Friday and get them on Tuesday. That's what I'm talking about.
They are supper nice... Pics don't do them justice. Can't wait to hook them up.
Old 02-09-2013, 11:38 PM   #24
Dinos63
chevy only
Dinos63's Avatar
I have ran these valves on two of my trucks soon to be on my third truck i am building they are killer not one problem !! thanks dloe one cool kat!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 02-10-2013, 01:52 AM   #25
Malamute
Malamute's Avatar
I would love to see a final install pic on these. They look nice.
Malamute is offline   Reply With Quote
