Old 02-02-2013, 03:05 PM   #1
bigguy69
dazed and confused
bigguy69's Avatar
gas tanks
What are you guys using for under bed tanks? I have a poky blazer tank now and is letting water in somewhere. I have had this thing off several times. This is in a 70 Chevy fleetside thanks in advance.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 02-02-2013, 04:05 PM   #2
jetfixr
Re: gas tanks
Seen a post where some folks are using a 69 camaro tank. Do a search for it. The Blazer tanks hang a bit too low for my taste. You could put a custom tank in but its $500+
jetfixr is offline   Reply With Quote
Old 02-02-2013, 07:20 PM   #3
rogergodding
rogergodding's Avatar
Re: gas tanks
Chevelle tank going in now.... will post a thread with pics when done!
rogergodding is offline   Reply With Quote
Old 02-02-2013, 09:11 PM   #4
kevmac
kevmac's Avatar
Re: gas tanks
Looking forward to this
kevmac is offline   Reply With Quote
Old 02-02-2013, 10:20 PM   #5
ole dollor
ole dollor's Avatar
Re: gas tanks
x-2
ole dollor is offline   Reply With Quote
Old 02-02-2013, 10:22 PM   #6
bigguy69
dazed and confused
bigguy69's Avatar
Re: gas tanks
Me too
Old 02-02-2013, 11:16 PM   #7
Pro Performance
Pro Performance's Avatar
Re: gas tanks
We have had a lot of customers go with the Boyd Welding tank, which is a direct fit into the 67-72's. Comes in both carb and EFI applications with a side or bed fill option.
http://www.azproperformance.com/Boyd...nks-67-72-C10/
Pro Performance is offline   Reply With Quote
Old 02-02-2013, 11:27 PM   #8
bigguy69
dazed and confused
bigguy69's Avatar
Re: gas tanks
Do you sell the senders to? Those tanks look good!
Old 02-02-2013, 11:48 PM   #9
67c10rustbuket
67c10rustbuket's Avatar
Re: gas tanks
Boyd's are the way to go. They start at only $349. Pretty reasonable once you compare to a blazer tank conversion kit for $250, hack up the bed cross sill, get pissed off, cuss at said "bolt in tank" which does not really just bolt in.
I paid a lot more for mine with the Efi stealth model, aeromotive Efi in tank pump, sending unit and roll over valve. Over $600 I think.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 02-03-2013, 08:43 AM   #10
JointTech
JointTech's Avatar
Re: gas tanks
oh you said under bed..
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 02-03-2013, 11:30 AM   #11
RexDodge
Re: gas tanks
This pic is from a while ago but shows my blazer tank without a bumper. By the time I get a bumper on there you'll need to lay on the ground to see my tank...well almost. I have around $50 into the tank swap.
RexDodge is offline   Reply With Quote
Old 02-03-2013, 11:56 AM   #12
Davemotohead
Davemotohead's Avatar
Re: gas tanks
I installed a 1985 44 gal suburban tank under the bead of my 71 4x4 LB,,used the Cross members/skid plate and parts from the susburban and managed to get the filler pipe between the bed walls without choping things up,,very pleased with the way it turned out and it tucks up nice between the frame rails and looks factory,,cost me maybe $50 for misc parts and just some time and thought!
edited by staff
Davemotohead is offline   Reply With Quote
Old 02-03-2013, 12:19 PM   #13
88fordf150
88fordf150's Avatar
Re: gas tanks
16 gal from summit racing.
Brad handshoe
88fordf150 is offline   Reply With Quote
Old 02-04-2013, 06:38 AM   #14
merlin3
Re: gas tanks
just wondering were you got those fender well headers,are they hand made?
merlin3 is offline   Reply With Quote
Old 02-04-2013, 12:23 PM   #15
Pro Performance
Re: gas tanks
Yep, we sure do!
Old 02-04-2013, 05:49 PM   #16
88fordf150
88fordf150's Avatar
Re: gas tanks
They are for a 55 Chevy BBC that came from Speedway Motors. They do need to be cut and rewelded to fit. I still have more work to do on mine.
Brad handshoe
Old 02-04-2013, 09:04 PM   #17
rogergodding
Re: gas tanks
Originally Posted by ole dollor View Post
x-2
Me too
Here's a link to my thread.... be gentle
http://67-72chevytrucks.com/vboard/s...d.php?t=564509
