04-20-2006, 06:04 AM | #1 |
Active Member
FS 3/8 Temperature Sensors
I made these mostly for myself and just to see if it would work. I am not a professional machinist, but I think they came out well. I can make some of these and ship them out if anyone is interested. They're just GP Sorensen sensors from Advanced Auto that I cut down from 1/2" to 3/8" pipe thread. Should work for temperature gauges in all 67-72 trucks with original gauges. $25 shipped in the lower 48. Thanks, Eric
69 GMC 2500 Camper Special 88 S10 Pickup 04 Impala I ship UPS from 24153 |
04-20-2006, 10:02 AM | #2 |
Re: FS 3/8 Temperature Sensors
I'd like one please. Do you take PayPal? Thanks!
04-20-2006, 02:49 PM | #3 |
Active Member
Yes I take Paypal. PMed you. Thanks, Eric
04-21-2006, 09:57 PM | #4 |
Eroc - I'll take one too - PM sent.
Just a note to others reading this if your're doing a newer engine swap you may need this since they may be no place screw in the normal sized 1/2 npt sender.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
04-22-2006, 03:42 AM | #5 |
Does anyone know where I could get the wire connector that fits the tip of the sending unit. Mine rotted away.
03 Tahoe 72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays. |
04-22-2006, 01:51 PM | #6 |
I have Trick Flow aluminum heads and they have the 3/8 npt holes also. Those senders would be handy if you're using the stock gauges, (I use mechanical Autometer).
Good idea EROC!
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
04-22-2006, 11:12 PM | #7 | |
Cantankerous Geezer
I use a spade terminal and bend things a little so it won't come off.
Fred There is no such thing as too much cam...just not enough engine. |
04-23-2006, 01:15 AM | #8 |
Thanks Fred. Maybe I'll try a spade connector. It'll look a lot better than my alligator clips
04-23-2006, 01:35 AM | #9 | |
http://www.ronfrancis.com/wiringaids.php |
04-24-2006, 09:09 AM | #10 |
DON'T TREAD ON ME
EROC I may need one of those. I bought a 3/8 sender from autozone but I'm not convinced it's the correct Ohms to read the temp correctly. I'm getting ready to put in a new radiator and figured I'd Ohm my current sender. Does anyone know what the Ohms are on the original sender?
Old Yeller |
04-24-2006, 11:12 AM | #11 | |
04-24-2006, 10:59 PM | #12 |
I found this cached link on google back to board, not sure if it exists anywhere else - has some ohm test reading and other good info -
or search for ts6641 http://72.14.203.104/search?q=cache:...s&ct=clnk&cd=1
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 04-24-2006 at 11:00 PM. |
04-24-2006, 11:11 PM | #13 |
DON'T TREAD ON ME
Thanks to both of you for the info. My gut instinct is telling me the sending unit I have ain't right. I sure would hate to ever burn up the engine you see in the sig just because of some kind of coolant failure. It may be a few days before I have a chance to get to it and let everyone know.
Old Yeller |
05-17-2006, 03:59 PM | #14 |
DON'T TREAD ON ME
I finally got around to checking my sender today and it is definitely not the correct ohms. At room temp it measured 2200 ohms and in a boiling pot of water it was 174. According to pj it should have been 1000 at room temp but in the thread Green Machine posted these were the specs given.
Temp..........Factory (Ohms) 70..............490 180.............130 200.............110 Either way mine won't work. So, EROC if you still have the correct sender I need one for sure. However, I'm completely broke at the moment so it will be a few days before I can even afford $25 but I will definitely take one when I have the dough.
Old Yeller |
05-24-2006, 01:03 PM | #15 |
Usually hate to bring old threads up..
But we are putting a '96 vortec 350 in a blazer at the shop and need a sending unit for it. so it will work with the early style gauge. You still have some??
Support The Board Last edited by drink2mny; 05-24-2006 at 01:13 PM. |
05-25-2006, 11:52 AM | #16 |
ya there EROC??
Support The Board |
05-25-2006, 12:07 PM | #17 |
Active Member
I can make a few more. PM sent.
05-25-2006, 12:12 PM | #18 |
back at ya..
Support The Board |
04-06-2007, 07:42 PM | #19 |
I PM'd you. I am interested in one of these. Thanks
01-30-2013, 11:55 PM | #20 |
If you still have any of the 3/8 NPT temperature sending units, I would love to buy one. New to the forum so not sure how to PM you, but will try to figure it out.
Posted via Mobile Device |
01-31-2013, 06:23 AM | #21 |
**** original poster not active since 2010 ****
Dave "... government even in its best state is but a necessary evil. Thomas Paine "It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men) |
02-05-2013, 04:53 PM | #22 |
I'm interested in one too if anyone knows where to get one.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
02-05-2013, 07:01 PM | #23 |
I just had one made. I bought the sensor at advance auto parts, then took it into work to our machine shop and had them do a G job for me. Any machine shop should be able to do this for you. Not sure what they would charge though. And I am not sure how accurate the sensor will be now?
02-05-2013, 11:40 PM | #24 |
That's what we are thinking about doing, but as common as the need for this is, it seems like someone would be selling them.
