Old 02-12-2013, 12:39 PM   #101
CC69Rat
CC69Rat's Avatar
Re: barn find 67 c-10
Most of the 4/6 drops with 20's run a 295/40/20 So in comparison (for the rear)
295/25.4 = 11.61in wide
275/25.4 = 10.82in wide
Keep in mind, with a 15" wheel vs. 20" wheel you might have a little more sidewall 'puff' so the overall section width of the tire might be slightly larger than what of a truck with 20's.
In the rear, you are to a nice advantage in that a 67 rear end housing is 1.5" narrower than a late 69-72 housing. (so you can run less backspacing and make your wheels look wider)
Ex. 4/6 drop and narrow housing.
I would run a 20x10 with 5" BS and 295/45/20 (I just like a little more sidewall)
The same drop with a late housing, 20x10 with 5.5" BS This just offsets the extra width of the axle. I would think (just my opinion) on a 15x10, 5" BS would sit you nicely. Others may chime in and that's cool. Just my thoughts on it.
Up front, you might be a little tight with a 15x8. What I mean is the lower A arm specifically. I wouldnt sit it too far back under the truck just for turning and overall suspension clearance. This is not so much of an issue running 20's or the larger wheels just due to the diameter and of course more clearance in this area.
likewise, most run a 20x8.5 up front, with 5.25" BS. 255/40/20
255/25.4 = 10.03" wide either scenario but remember the sidewall 'puff' .. not a bad thing, just something to keep in mind. If it were me, I'd do the 15x8 with 4.75" BS. My thinking is 8" vs 8.5" in my previous example. You'd knock off the extra wheel width from the backside and help with the clearance issues but that tire is going to be out there too. .. humm. 5" BS on all 4 corners?
Not responsible if it doesn't fit.. I'm just saying, that's my logic on it. Hope it helps. Comparing an early housing and discs up front as the baseline. Non modular, or big brakes.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 02-12-2013, 01:00 PM   #102
lolife99
67-72 parts collector,…
lolife99's Avatar
You can't run a drop spindle, and a 15x8 wheel with any more than 4" BS up front.
The greater BS will drive the rim right into the lower a-arm.
(even with 4" BS you have to trim the lower a-arm for clearance)
It is possible to do with 17" and larger wheels.
(Don't know about 16" wheels, because I've never tried it).
Keith
Convert to disc brakes.
Old 02-12-2013, 01:04 PM   #103
lolife99
lolife99's Avatar
For 5-lug 15" steel wheels,... I would use Wheel Vintiques Series 62 steelies.
But I would run a 7" rim up front.
http://www.summitracing.com/search/b...ques-62-series
Keith
Old 02-12-2013, 01:31 PM   #104
CC69Rat
CC69Rat's Avatar
Didnt know.. thanks Keith.
7in with 255/60 or run 235/60?
Chad
Old 02-12-2013, 01:36 PM   #105
lolife99
lolife99's Avatar
215/70 or 225/70,... so the tire has some height.
255/60 is too wide.
I have a set of custom made rally wheels that are 15x8 with 5" BS.
(Stockton wheel made them for me years ago)
You can't even bolt them on a 5-lug rotor.
Keith
Old 02-12-2013, 01:40 PM   #106
chasinhiway
chasinhiway's Avatar
Man I really appreciate all the input!! So with 15x7's up front would you run 15x10's in the back or 15X8's?
chasinhiway is offline   Reply With Quote
Old 02-12-2013, 01:41 PM   #107
67_ShortFleet
67_ShortFleet's Avatar
217/70 or 225/70,... so the tire has some height.
255/60 is too wide.
217/70's those have to be rare
Matt
Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784
My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924
My philosophy on tires is the same as cigarettes. "smoke them if you got them"
HAPPILY DIVORCED!
67_ShortFleet is offline   Reply With Quote
Old 02-12-2013, 01:43 PM   #108
67_ShortFleet
Nice truck! So glad to see that the patina is staying. I give my right one for a truck like that to build.
Matt
HAPPILY DIVORCED!
Old 02-12-2013, 01:46 PM   #109
chasinhiway
OK, I looked online for these wheels and the 15X7 wheel has 4.25 inches of backspacing will that be ok with the dropped spindles?
Old 02-12-2013, 02:48 PM   #110
CC69Rat
CC69Rat's Avatar
Those 217/70's are pretty rare in fact. You can only buy them in MO as I understand it.
Chad
Old 02-12-2013, 03:15 PM   #111
lolife99
lolife99's Avatar
Ha.
I type to fast for my brain,...
Keith
Old 02-12-2013, 03:19 PM   #112
lolife99
lolife99's Avatar
To tell you the truth,... I don't know.
I know 4" BS will work.
I think Dino has some 15x7's on his newest project, with drop spindles.
They look like they clear fine,... but I don't know his backspace numbers.
http://67-72chevytrucks.com/vboard/s...d.php?t=556602
Keith
Old 02-12-2013, 03:24 PM   #113
lolife99
lolife99's Avatar
I like a 7 and 8 combo,... because there aren't many tires that look correct (to me) on a 15x10 rim.
Except a 26X12.00R15LT Mickey Thompson Tire.
Keith
Old 02-12-2013, 04:31 PM   #114
chasinhiway
ORDERED!!!! 2-15x7 and 2-15x8 wheel vintique 62 series. Thanks for all the input on the wheels. I'm a member of several forums but this one is by far the best out there!!!
I'd like to give 67Anthony a special shout out for donating a piece of trim for Sally. He saw in the pic she was missing one and sent it to me. I told my mother in law about it and she said "AWW bless his heart!"
Old 02-12-2013, 09:57 PM   #115
darkhorse970
darkhorse970's Avatar
Cool truck! I'm in.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 02-12-2013, 10:56 PM   #116
Rusbuilt
Rusbuilt's Avatar
Nice man! You've ordered a lot of really great parts!
Rusbuilt is offline   Reply With Quote
Old 02-13-2013, 12:31 AM   #117
black_sheep454
I know you've got to be more excited to see it done that me and everyone else here but damn the waiting is painful
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
Old 02-13-2013, 01:36 AM   #118
cubber
I have 2.5 drop spindles, and 15x7's with 4" bs. I have had a heck of a time keeping inside wheel weights on the front. They have been interfering with the outside edge of the LCA, just outboard of the ball joint.
BTW, I absolutely LOVE your truck, and what a cool story! Subscribed.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 02-13-2013, 10:07 AM   #119
chasinhiway
Ok tonight I started filling in the fire wall holes. While waiting in between welds i got my buffer out and worked a little.
Old 02-13-2013, 10:11 AM   #120
chasinhiway
Oh yeah, I finished the hood, and couldn't resist trying a spot on the bedside and roof.
Old 02-13-2013, 10:29 AM   #121
lolife99
lolife99's Avatar
You have to trim the lip on the lower a-arm to clear your wheels.
Keith
Old 02-13-2013, 11:10 AM   #122
N2TRUX
Happy to be here
N2TRUX's Avatar
Like...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-13-2013, 12:28 PM   #123
aggie91
I'm just glad to be here!
aggie91's Avatar
Looks good. Are you using something like CLR to remove the surface rust before buffing, or just hitting it with the buffer and compound?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-13-2013, 01:05 PM   #124
Rusbuilt
Rusbuilt's Avatar
That paint is looking good!!!
Old 02-13-2013, 01:38 PM   #125
chasinhiway
I'm using just the buffer. I know very little about buffing so I'm sure there's an easier way.
