Closed Thread
Old 02-18-2013, 09:11 PM   #6076
Mister-B
Re: What did you do to your truck today!
Originally Posted by 71K20chevy View Post
WOW....that looks so much better than the old blue pa you had in there!
I recently did a swap and repaint on mine, masking was a pain in the butt!!
Thanks! Yeah, here's a couple before shots, and then one of it masked up and painted
And for sh!ts and giggles
Before:
After:
Mister-B is offline
Old 02-18-2013, 09:17 PM   #6077
haysonj
haysonj's Avatar
I started putting the motor back in
69 Chevy 4x4 383 Power
haysonj is offline
Old 02-18-2013, 09:18 PM   #6078
bugmasta
bugmasta's Avatar
Installed remflex header gaskets. These things are sweet! First set of header gaskets that haves actually worked! Love them, truck sounds awesome without that annoying exhaust tick.
Here is a link if ya want more info: http://catalog.remflex.com/
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130
Club longbed ...cause girls like'em long!!!!!
bugmasta is offline
Old 02-18-2013, 09:18 PM   #6079
bigike55
bigike55's Avatar
put my new door panels on. I have to say I had to trim the holes out bigger where the armrest goes on. I ordered lmc door panels don't know if any others line up better but you cant see where I had to make the hole bigger the armrest covers it so I guess its ok.
1972 Chevy C20 Pickup
1974 Plymouth Roadrunner
2009 GMC Sierra
2011 Chevy Equinox
bigike55 is offline
Old 02-19-2013, 02:49 AM   #6080
Square_78
Square_78's Avatar
Mine just barely lined up. The hole would be the right size if they put them in the right spot. Mine were the black metal panels from LMC.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline
Old 02-19-2013, 02:50 AM   #6081
Square_78
Square_78's Avatar
Been collecting parts... STILL waiting for my air bags and CPP brakes to arrive. Brutal. Got my GMC emblems installed, and got all the side trim cleaned up and repainted. I might install it this week. I bought all my 4 guage battery cable for the compressors, 80amp fuse block, continuous duty soliniod to control the compressor power. I made up some cables tonight with the 4 guage and copper ring terminals from the battery to the fuse and made a new 4 guage ground strap to go from the battery to ground. Just been slowly plugging away at it.
#teamlongbed
Old 02-19-2013, 03:02 AM   #6082
Trsmotrhed
Trsmotrhed's Avatar
Originally Posted by Chevyc10572 View Post
Por 15 my frame
Did you paint with a brush or spray the por 15?
Thx
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline
Old 02-19-2013, 08:14 AM   #6083
aventur1
aventur1's Avatar
Mister-B
What type of paint did you use?
1968 4x4 Frame, with a 67 Cab and Bed
A Shorter Step
1999 Dodge 2500 Cummins Diesel
aventur1 is offline
Old 02-19-2013, 08:30 AM   #6084
BugzC10
BugzC10's Avatar
Pulled the upper steering column apart to determine why shifter is sloppy. Didn't find anything obviously wrong with it other than needed a good cleaning and lubrication. Now I can pull the shifter inward, but it still moves from park to drive without any stops. Now to dismantle, inspect and lubricate the lower section and linkage.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 02-19-2013, 10:06 AM   #6085
Mister-B
Originally Posted by aventur1 View Post
Mister-B
Mister-B is offline
Old 02-19-2013, 11:10 AM   #6086
aventur1
aventur1's Avatar
Thanks...just looking to do mine and wanted some ideas..yours looks great
A Shorter Step
aventur1 is offline
Old 02-19-2013, 11:19 AM   #6087
Mister-B
No problem. Check out my thread from yesterday for instructions
Mister-B is offline
Old 02-19-2013, 11:52 AM   #6088
VWNate1
VWNate1's Avatar
Post Re : What did you do to your truck today!
M17 : thank you ~ I'm not always sure if My Tech Help is appreciated or not .
It sounds to me like you have your fans set up and working O.K. , I wasn't sure before .
Always remember : your coolant should run as close to boiling temperture as possible for maximum engine life , power and fuel economy .
Dennis : SWEET ! I wish you were closer , I really want to find an honest & reliable Body Shop to rebuild my '69 Stepper .
RE Driveshafts : I'd pass on that hybrid U-Joint , take anu old drive shaft(s) with the correct ends and measure *exatly* how long you need it then hie yourself to the nearest Big Rig Repair Shop and ask who does thier drive shaft works ~ take it there as they'll know and for $150 (assuming they're honest) you'll get your drive shaft back cut & measured , balanced with two new greasable U-Joints , ready to pop in and go.... no hassle .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 02-19-2013, 12:50 PM   #6089
Chevyc10572
Chevyc10572's Avatar
Thx
I used a brush
Chevyc10572 is offline
Old 02-19-2013, 01:17 PM   #6090
kkaa607
kkaa607's Avatar
Originally Posted by Mister-B View Post
Installed a new dash pad, and painted the dashboard behind it
Nice truck and was going to ask year/ model but didnt even bother to look at your handle..dohh! Working on mine to try and get a similar clean look but it aint easy.....
kkaa
kkaa607 is offline
Old 02-19-2013, 01:32 PM   #6091
Dale_Brown
Put on my new old 1971 Maryland State tags. Thanks Maryland.
Dale_Brown is offline
Old 02-19-2013, 08:18 PM   #6092
Expat_dude
Expat_dude's Avatar
Tires came in today !
1970 Chevy swb, project UGHH!
1987 Grand National
http://s168.photobucket.com/albums/u.../1970%20Chevy/
Expat_dude is offline
Old 02-19-2013, 09:37 PM   #6093
glider_6969
Put the new bearings and brushes in my alternator, funny enough it went back together,
68 Long stepper
My other ride ,,, 07 Streetglide..
glider_6969 is offline
Old 02-19-2013, 09:47 PM   #6094
GoaterAz
GoaterAz's Avatar
18" or 20"?
What are they going around?
GoaterAz is offline
Old 02-19-2013, 10:44 PM   #6095
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Didn't get much done today.
Or tonight.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 02-19-2013, 10:49 PM   #6096
mud.man.rj
mud.man.rj's Avatar
Did nothing on my truck today, but ordered a Comp cam 270H for my 454 to go with the Rpm intake and roller rockers I just got. Might as well go all out when it is apart and port the 781 cyl heads too while I am in there, work and more work. Ported 1 of a set of Dart Iron Eagle New cyl. heads today and reassembled, one more to go.
mud.man.rj is offline
Old 02-19-2013, 11:28 PM   #6097
bonnieclyde100
i finally got my engine back from the machine shop . i put it together and painted it. it is a 1993 chevy 5.7. my original engine had a cracked block in two spots.
bonnieclyde100 is offline
Old 02-20-2013, 12:29 AM   #6098
68 Longbed Dan
I put a tarp on mine, lol. We got alot of rain today right after I got off work. It's still going.
Dan
1968 Longbed Stepside C10
68 Longbed Dan is offline
Old 02-20-2013, 01:02 AM   #6099
Trsmotrhed
Trsmotrhed's Avatar
I'm out in Cali for work and was looking forward to some nice weather that's been going on lately. Nope, got wet and cold today in the bay area. Back in Roseville now. Still cold.
63 SWB C10
Old 02-20-2013, 01:18 AM   #6100
68 Longbed Dan
Yea yesterday it was 80 and sunny, currently it's 43 and raining lol what gives! They are talking snow tomorrow in the hills outside where I work in Taft, gonna be fun. Gotta love California weather though
Dan
Closed Thread
