02-18-2013, 07:59 PM | #201 |
Re: SPID Picture thread?
here's an oddball for ya... A Z84 Cheyenne Super?? Never saw that before! (A Z84 is a Cheyenne (or CST) and a Super is a YE9, normally). Maybe they do stuff different up in Oshawa. For what it's worth, the truck was indeed a Cheyenne - the only "super"-ism was in the name of the RPO, which was clearly incorrect. I do believe it was original - this was a truck I was looking at a while back.
02-19-2013, 05:23 PM | #202 |
Have any of you guys seen this on a 1970 c10 big block, air but no radio
Posted via Mobile Device |
02-19-2013, 05:37 PM | #203 |
Latest parts truck. Z-fremont, 1972
02-19-2013, 06:12 PM | #204 |
Its not unknown and being Custom Deluxe makes it even more likely than say a Cheyenne or a Super.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
02-19-2013, 10:04 PM | #205 |
Who Changed This?
That's the second one I've seen with Turbo Hydra-Matic misspelled, mine being the other one- a "U" instead of an "I" in the last word.
02-27-2013, 08:04 PM | #206 |
Typical Western Canadian farm truck. 250 six cylinder, gauges with a
Turbo 400 and the optional wood floor box. Not too sure about the J63 brake shield option with drum brakes. Sorry about the poor picture quality. Posted via Mobile Device |
02-27-2013, 10:42 PM | #207 |
This is a great resource and I can understand not wanting to post a VIN. However if at all possible, those that do edit their pictures or cut off the top, it would be really appreciated if you would state the plant and model year. Chevy examples would be 2Z,1S or 9A. It helps me to track changes between years and plants.
02-27-2013, 10:50 PM | #208 |
Justin |
02-27-2013, 11:04 PM | #209 |
SS Tim, I posted one that's on page 6, it's post #148. I was wondering what the "Georgia Power Company" was? Did other utility companies have there own codes?
02-27-2013, 11:24 PM | #210 |
Just as an example of my last post. Of the 1970 Freemont 0Z SPIDs I have data from several show it. Roughly between 125800 and 167800 are the only examples showing it though. Sounds like a code or printer problem. If yours (and anyone else's) is outside that range I'd be interested in adding data points.
02-27-2013, 11:54 PM | #211 | |
Could very well be that the AA code is for special paint though.
02-28-2013, 12:09 AM | #212 |
Pretty normal truck, only thing that is weird thing is that the truck has a 14000lb gvw plate but has no options that say it should have it.
72 K5 Blazer 68 C30 95 Buick Roadmaster 90 Geo Tracker(dune beater) 89 Honda Civic (winter beater) |
02-28-2013, 12:31 AM | #213 |
Your truck was probably rated at 14k as it has the Z51 rating plate (build sheet code) and not the lighter 10K plate found on R05 chassis cabs. But like you say it does not show a supporting tire RPO or the H22 axle required for the bump. Does it have the HO110 axle with ten lug rear and five lug fronts?
02-28-2013, 12:53 AM | #214 |
Do you have any pictures of this truck??
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 |
02-28-2013, 01:01 AM | #215 |
It has the HO72 rear and and eight lug all around. The truck also has 18 in wheels which aren't listed. But it has the 18in spare listed.
02-28-2013, 01:25 AM | #216 |
Then it was a 10K truck. The spare and carrier were options on chassis cabs with R05. It has the R05 included maker lamps though? If you look up the load chart in the drivers handbook you will see it requires the H22 option for the 14K capacity. Looks like the load plate was a missbuild. Have seen a few pickups with the incorrect 10K plate vs the correct 9K too. As unlikely as it is does your truck have a build sheet or Protect-O-Plate?
02-28-2013, 01:39 AM | #217 |
Yea the misbuild makes sense, that gvw chart always is what got me. I wish I had the protecto plate or build sheet although I thought the never put them in the trucks, but I don't know every thing. I'm still confused as way they didn't list the 18in wheels as an option unless that was a misbuild to.
02-28-2013, 01:51 AM | #218 |
Well strange things happen. The 18" tire were a dual only size and that spare wheel RPO is not on my list. "...that gvw chart always is what got me." is there something I can help with?
02-28-2013, 01:59 AM | #219 |
No I'm all good With the info you gave. The chart confused me because it said I need the 11000lb axle for the 14000lb gvw plate. But I didn't have that axle.
02-28-2013, 02:08 AM | #220 |
Now that I look at it more Q31 is the code for 18x5 wheels I wounder if it meant that it came equipped with them and had a spare.
02-28-2013, 02:36 AM | #221 |
Don't know what to say 7.00x18 8 ply tires were one of six dual only sizes in 67. They were RPO code R90. The Q31 code (found it...) was for a bare wheel only as was the custom.
02-28-2013, 08:58 AM | #222 |
A truck we recently sold
Justin |
02-28-2013, 09:25 AM | #223 |
Here's one from c60 I was looking at. I thought it was pretty well optioned.
Posted via Mobile Device Posted via Mobile Device
02-28-2013, 09:40 AM | #224 |
Here is my 67, for some reason the VIN does not match a VIN Code Chart I found on the net.
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new. 66 GMC Short Step, 84 Front Suspension, many more mods to come 67 Chevy 3/4 Ton, 327, Auto, Factory A/C Ya must have been movin cause I was haulin a*$ when I passed you |
02-28-2013, 12:23 PM | #225 |
So what is the problem?
C Conventional Cab 4x2 E V-8 Engine 2 3/4 ton 4 Pickup 7 1967 Z Fremont CA assembly plant 149875 serial number
