Old 03-03-2013, 06:54 PM   #51
71K20chevy
71K20chevy's Avatar
Re: HELP! First truck, need to be back on the road
Originally Posted by Yellow72C10 View Post
Would it be worth it to go ahead and get them professionally done as I have zero experience? Also, worth it too swap the rears to disc?
Yes. Or, you could pick up a Chilton book as those usually have detailed steps on how to do it yourself.
For the disc conversion, that's up to you, properly working drum brakes are just fine. Why do you think they used them so long?
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 03-03-2013, 10:42 PM   #52
Yellow72C10
Haha very true. Any idea what it would cost for a full brake job?
Yellow72C10 is offline   Reply With Quote
Old 03-03-2013, 10:47 PM   #53
71K20chevy
71K20chevy's Avatar
I'm not sure, we're in the middle of doing mine right now and the back is done and it cost roughly $200. Got the drums turned but we replaced the wheel cylinder, pads, springs etc. Front will probably cost about the same but it will be so much easier since there are less parts.
71 K20
64 GMC mud truck
Old 03-03-2013, 10:49 PM   #54
Yellow72C10
What do you mean less parts? Because its disc up front and drum in the rear?
Old 03-03-2013, 11:37 PM   #55
71K20chevy
71K20chevy's Avatar
Yes sir. It's a lot less complicated than drum brakes.
If you don't replace the calipers, only push the piston in (using a C clamp) as far as you need to otherwise the rust on the piston could get hung up on the caliper and not come back out. Hopefully that makes sense, I'm not the best at explaining things
71 K20
64 GMC mud truck
Old 03-04-2013, 12:57 AM   #56
Yellow72C10
Haha that was good, and thanks for the responses!!
Old 03-04-2013, 01:03 AM   #57
Scott>72-GMC
Scott>72-GMC's Avatar
Brake jobs usually won't break the bank. And like stated better safe than sorry. There are some idiot drivers out there. Sticky drum brakes are a bad story too
72 GMC super custom.
Scott>72-GMC is offline   Reply With Quote
350, 4wd, automatic, restore, stepside
