#402 |
Re: 72 k20 project
are you looking to bag the rear, or just link it? if its a coil rear 2wd to start with, the bag mounts i have drawn probably wont work with the frame. otherwise i think itll be fine as long as you are not shooting for 2495" of lift. this should sit close to level or a touch high in the rear at ~ the same height as my 4" front springs
Ryan |
#404 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: 72 k20 project
By the looks of that cross member, it looks like coil to me.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#405 |
Re: 72 k20 project
Id have to agree.
Posted via Mobile Device |
#406 |
Re: 72 k20 project
I'm pretty sure it is. I want to say i have seen trailing arms under it.
I haven't read up much on the 4wd swap. I didn't know the coil trucks were unliked for the swap |
#407 | |
Re: 72 k20 project
#408 |
Junk Yartist
Re: 72 k20 project
Do I see propane?
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#409 |
Re: 72 k20 project
so new they still have the stickers on them. crimeny
![]() mocked up the pass. axle brackets ![]() ![]() and made some mock up links so i can continue working without having to possibly miscut my DOM ![]() i still need to check the fore and aft location of the axle but this should be the ride height geometry ![]() |
#410 |
Junk Yartist
Re: 72 k20 project
What is that you have on welded on the old-no-longer-needed spring hanger? is that for reinforcement or repair?
#411 |
Re: 72 k20 project
Yeah. the holes got torched out when my dad cut the bolts out years ago. i welded some .25" over the mangled holes
#412 |
Junk Yartist
Re: 72 k20 project
Also, is ride height where it was with the old 4" lift?
#413 |
Re: 72 k20 project
Nope. i think it is close to what i would expect the 4" to be. it was really high in the rear with the springs. its still a little ass high, but not so much.
#414 |
Re: 72 k20 project
Great work. This is going to be a killer set up when you're done.
#416 |
Re: 72 k20 project
Ryanroo I think I might hate you....
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
#417 |
Re: 72 k20 project
![]() bring it on out, i bet we can get er done |
#418 |
Re: 72 k20 project
I wish! I think I still have a long ways to go. Seems like all the cool kids box and bag the rear right?
#419 |
Re: 72 k20 project
all the ones i know at least....
#420 |
Re: 72 k20 project
So, i didnt do much this weekend, i was being lazy and had some glacier sized ice to chip off my sidewalk since it was warm too.
anyhow i did do this ![]() ![]() i also looked at a tranny i am going to pick up tomorrow. a 98.5+ NV4500. it works but i am treating it as a core. so, i think, i am going with the manual now.... Ryan |
#421 |
Chevy Enthusiast
Re: 72 k20 project
Sweet! You can't beat that trans!
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
#422 |
Junk Yartist
Re: 72 k20 project
Hey Ryan, can you give me the LxWxH of the 2nd gen radiator you are using? Core only
#423 |
Re: 72 k20 project
The core is 36" long, 20" tall and 2.375" thick.
Ryan |
#424 |
Junk Yartist
Re: 72 k20 project
Bigger than a 6.2L radiator at 34X20X2.375. Looks like We will be looking for a second Gen since both mine and my brothers have quick release passages in them. Thanks!
#425 |
Re: 72 k20 project
Quick release eh?
