#26 |
Re: what seats did you put in your 67-72 Chevy truck ?
Just an idea but the 2000-05 deville has some really comfortable seats its a bench seat with built in armrest and cupholders leather heated and full power plus there realitively low i bet theyed be perfect in one of these trucks plus i seen them at junkyards cheap
70 SWB STEPSIDE 70 BLAZER 09 challenger |
#27 |
05 silverado seats in mine. It's tight with the factory big wheel and no tilt.
Posted via Mobile Device |
#28 | |
www.tomthetruck.blogspot.com <-- Aka build thread. |
#29 |
Junior Member
![]() Join Date: Jan 2010
Got this middle seat out of a 93 Suburban. Cut the brackets down to lower the seat and drilled and re-enforced the floor. The seat bottoms pull up for storage underneath.
#30 |
dirty and nothin fanzy 84 c10 but wuts best its i found it like it is and my local pull and save
Im stright up ESL student........ ![]() 94 s10 4x4 4.3/5speed (dd) 68 lwb GMC 350/4speed 52 5 window GMC I6/4speed 12v (8lugs and long bed) 53 bel air 235 I6/powerglide |
#31 | |
Seems like these are what you have, no?
www.tomthetruck.blogspot.com <-- Aka build thread. Last edited by Tmwoodall; 09-02-2011 at 03:14 PM. Reason: Found a set. |
#32 |
![]() ![]() Join Date: Jul 2002
From a 90 Chevy C1500. No longer in the truck, but looking for another 90-94 seat to use since I was stupid enough to get rid of the seat.
#33 | |
#34 |
![]() Join Date: Aug 2010
Mine are out of a 2003 Avalanche.
67 5.3L Build |
#35 |
Old member
60-40 out of a 1989 Chevy 1500.
No cutting just braced the underside of the floor and drilled new holes. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#36 | |
Junior Member
I haven't really done any long drives bit they are comfy around town. I think I'm going to shorten the steering column as the wheel is still too close, and I'm kinda anal about getting it perfect ![]() I'll get some better pics. |
#37 | |
#38 |
![]() Join Date: Jul 2009
Check post # 19
#39 |
#40 |
Junior Member
More pics. It is a center seat form a 95-99 Suburban.
#41 |
upgrading to an older model
Mine are a whole lot like Classic69's except yellow and black. I built a frame to mount the seats on (out if 1 1/4" square tubing) bolts to original seat mounting holes. For belts i went with PEAK racing harnesses. The lap belts use the original seat belt holes. I took removed the gas tank, cut a peice of 1 1/4" square tubing that went all the way across the cab, mounted the bolts for the shoulder straps then bolted the bar to the top mounting holes from the where the gas tank was mounted.
I tried to take some pictures but my camera is screwed up...I got one decent one but then I gave up on the pics and just took a video
68 stepside, short-box, multi-colored (for now) ![]() ![]() ![]() |
#42 |
We put in 2002 Mustang buckets with the driver seat is powered. Can't move very far backwards,though. Howard
1967 C10 LWB, painted 2010 MUSTANG GRABBER BLUE & finally got it on the road after sitting in garage for 10+ yrs. Howard in MI. |
#43 |
I found someone in town selling 70's Camaro seats. I was worried about height as I just bought them but they look awesome! When it's closer to finished I'll get some leather seat covers for her and that'll be all she wrote!
#44 |
Active Member
![]() Join Date: Nov 2008
I picked up my seats from the upholstery shop today. These seats are out of a 2011 chevy truck. We cut them down about 4 1/2 inches, they should sit right at the bottom of the window.
#45 |
99 f150 40/20/40 split bench........drill holes...gives nice fit and very soft seat.
#46 |
They look great!
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 ![]() My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! |
#47 |
![]() Join Date: Mar 2011
These are the seats Ive decided to put in mine. They are black leather trailblazer seats. Both are power and heated.
I dont have them yet (still in transit) so I have no idea about fabbing the mounts. (supposedly they are relatively easy to install)--We'll see. ** I have since received the seats and they Will take some fabbing on the inside rails (outside rail is at least 2 in. higher) No hill for a stepper!!!!
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 Last edited by 54belair; 03-20-2013 at 07:46 PM. |
#48 |
Love the different options seen here ! My stock bench is in really good shape but not so good on a messed up back. I like the newer Chevy seats with built in seat belts, really easy install. Also really want something with the head rests. I was in an accident quite a few years back, my ex and I were stopped waiting for traffic to clear and got rear ended by someone doing 65 (according to the investigating sheriff). The only reason our heads didn't go through the back window is a gun rack with my shotgun in it, our heads hit the gun. The rack did push the top of the window out about 3/4 inch though. The head rests may not look as clean but they sure are much safer. Something to think about ...
#49 |
I just picked mine up from a local salvage out of a 2005 Silverado, the whole package for only $250. They are mint for 05, just need to clean the pop off from the wreck. The drivers seat is electric. Hopefully it's an easy install.
#50 |
Nuke82
They are real simple to install I used the holes in the middle to bolt the console and seat then marked the other holes and drilled those. You will want to reinforce under the bolts and I shimmed the back of the track with front end alignment shims so the seat would travel back. Let me know if i can be any more help |
