Old 03-20-2013, 07:37 PM   #51
nuke82
nuke82's Avatar
Re: what seats did you put in your 67-72 Chevy truck ?
Thanks for the tips Mikey. I was thinking about ordering a set of these Juliano's anchor plates to reinforce the new driver side holes, just to be on the safe side. The passenger side will get washers
http://www.julianos.com/anchor_plate.html
nuke82 is offline   Reply With Quote
Old 06-25-2013, 10:38 PM   #52
nos81z28
@ nuke82 cant wait to see yours done I have the same seats for my 72!
72 Chevy C-10 Project Big Easy!
nos81z28 is offline   Reply With Quote
Old 06-25-2013, 11:37 PM   #53
Gokart Mozart
Originally Posted by 54belair View Post
These are the seats Ive decided to put in mine. They are black leather trailblazer seats. Both are power and heated.
I dont have them yet (still in transit) so I have no idea about fabbing the mounts. (supposedly they are relatively easy to install)--We'll see.
** I have since received the seats and they Will take some fabbing on the inside rails (outside rail is at least 2 in. higher) No hill for a stepper!!!!
These are nice! How much room is between the seats?
Gokart Mozart is offline   Reply With Quote
Old 06-26-2013, 12:13 AM   #54
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
2004 Blazer.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 07-15-2013, 11:07 PM   #55
his15153
Has anyone put a bench seat from a 1960-66 Chevy? I've found one for cheap for my 1969, but want to see if it would work.
his15153 is offline   Reply With Quote
Old 10-27-2013, 05:18 PM   #56
Patina'd_402
Patina'd_402's Avatar
Just wanted to post mine....
2004 GMC Kodiak/Topkick (REAR) bench seat, chopped the brackets ~3", welded to factory bench rails.
I'll get it re-upholstered.... Whenever I do the interior.
The top is EXACTLY where I wanted it.
'70/C10/402/TH400.
Patina'd_402 is offline   Reply With Quote
Old 12-02-2013, 11:55 PM   #57
nuke82
nuke82's Avatar
Nice pics Patina'd_402, wish I had seen them before I started my install. I didn't realize the B&M light truck shifter was so large! I did manage to make it fit, I've got to have my cup holders! Here are some pics of my install.
Old 12-03-2013, 02:14 AM   #58
nos81z28
@nuke 82 how was the install? I have same set up also. Looks really good.
Old 12-03-2013, 03:36 AM   #59
boynton
boynton's Avatar
Originally Posted by mortoyz View Post
I picked up my seats from the upholstery shop today. These seats are out of a 2011 chevy truck. We cut them down about 4 1/2 inches, they should sit right at the bottom of the window.
do you have any pictures of these installed? or anyone else have multiple pics of a 2011ish seat installed?
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 12-03-2013, 12:40 PM   #60
Molberg
Molberg's Avatar
These were high back buckets from an early '90's chev truck.. i cut the head rest pan off and had them covered.
Molberg is offline   Reply With Quote
Old 12-03-2013, 02:18 PM   #61
heathbirkendahl
Picked my truck up this morning. New belts in and ready to rock. Drove to work and they head and leg room are awesome.
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline   Reply With Quote
Old 12-03-2013, 02:19 PM   #62
heathbirkendahl
Uploaded the wrong pic. Let's try it again.
Old 12-03-2013, 04:38 PM   #63
dan468
dan468's Avatar
what kind of seats are those?
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 12-03-2013, 08:17 PM   #64
Spartan
Spartan's Avatar
I'm going with Buddies...well actually it was my wifes call. I votes for the bench. They'll be restored by then. She wanted buckets and a console but I told her we would have to by a different truck if I was going to drill holes in the floor.
'69 K20 350/4 speed/Rockwell/D44/HO52.
"orange rhymes with door hinge"
Spartan is offline   Reply With Quote
Old 12-03-2013, 08:52 PM   #65
BigCountryx
BigCountryx's Avatar
I got real fancy and put a bench out of an 87 c10 in mine lol.
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped
1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant
BigCountryx is offline   Reply With Quote
Old 12-03-2013, 10:32 PM   #66
heathbirkendahl
That's my factory 71' bench seat. They formed the foam by hand.
Old 12-04-2013, 12:24 AM   #67
nuke82
nuke82's Avatar
@nos81z28, The seat install was a lot easier than I thought, I was a little afraid of it since my fabrication abilities are almost non-existent. The process was pretty simple and went smoothly, I just sat the seats in the truck to see where I wanted them (warning, if you center the 05 seats in the cab the driver seat will be slightly off center to the steering wheel. It's maybe 1/4 to 1/2 inch but would bother me). Then I marked where the bolt holes were, double checked to make sure everything was straight and then drilled the holes. The extent of fabrication was I had to cut a spacer/perch for the front left driver and front right passenger seat rails as they didn't reach the floor, but all the other holes are good to go. I did make sure to use extra large washers on the back bolts so they don't pull through in the case of an accident.
Old 12-04-2013, 09:45 AM   #68
ksshane
ksshane's Avatar
Heath, That bench seat is AWESOME!
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 12-06-2013, 02:48 PM   #69
mortoyz
Active Member
[attach]Name:  interior.jpg
Size:  37.9 KB[/attach]
mortoyz is offline   Reply With Quote
Old 12-06-2013, 03:54 PM   #70
nos81z28
. Great cant wait to do mine
Old 12-06-2013, 07:25 PM   #71
In The Ten Ring
I really like my factory seat but it was reupholstered in the early '90's and has too much foam in it now. My legs rub the steering wheel!
AND I'd like to have head rests without seat belt connectors getting in the way of sliding over....
Not sure what I"ll do but it'll come later.
In The Ten Ring is offline   Reply With Quote
Old 12-08-2013, 07:02 PM   #72
K10 STEPSIDE
K10 STEPSIDE's Avatar
I used 2009 seats from a GM truck, and pull the seat belt from the rear seats of a 2000 dodge. I did do some cutting on the center to make it sit flush with the front of the sides but it was minor, then I only needed to drill holes.
This is a diagram showing the cut I made, this only moves the middle seat forward and might not be necessary.
I also use a small steering wheel.
_______________________________________________
A project can be finished, but a car is never done.
1967 chevy K10 step
2002 chevy Impala
Latest Project http://67-72chevytrucks.com/vboard/s...d.php?t=605308
K10 STEPSIDE is offline   Reply With Quote
Old 12-08-2013, 11:25 PM   #73
sublime1996525
There are some sweet seats in this thread!
2006 Z06
2013 Cruze
sublime1996525 is offline   Reply With Quote
Old 04-03-2014, 10:13 PM   #74
FrankenCub
FrankenCub's Avatar
Since I'm on the hunt right now for newer seats with the belts attached I got thinking about floor reinforcements. I was a wrecker opperator for a body shop and hauled in some nasty wrecks. The metal failures I seen were all where there was a weld joint. Most of the newer cars have much of them glued together. Not once have I seen a glued joint failure, or the metal near it. It might be something for those of you who were going to weld 2" supports under the seat bolts to look into something like Fusor. A bit expensive but it's much stronger than welding, won't compromise the floor strength, and great corrosion resistance. We had the big tubes at the body shop but Fusor does have smaller single use sizes that don't need the special gun.
FrankenCub is offline   Reply With Quote
Old 04-21-2014, 02:01 PM   #75
gwynne
OK--here we go, I usually don't post--but I installed an unusal seat in my project you might like to see--a 2001 Dodge Ram power seat--the feet fit, except for the contractor office console in the middle that require a 3/4 inch shim--I used a polyurethane bushing about 3 inchs wide and 3/4 tall. Don't have a lot of pics, but here is what I have. This seat is way more comfortable than in other truck seat I have sat in and maybe this is because when it came time to buy a diesel truck I wanted a Cummins engine and my seat is now used to the seat. You do sit a few inches taller than the stock seat, I am 5'-9" and have several inches from the ceiling--if you are tall, better measure or cut the seat frame down.
gwynne is offline   Reply With Quote
