Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-26-2013, 10:14 PM   #1
Rusty Shacleford
Rusty Shacleford's Avatar
Drew's 72 K10 Shortbed
Hello all. I've been a forum observer for quite some time, building ideas for my own project. Like most everyone, it is going to be a slow process that really only moves forward when I can get the old lady to turn loose of a little cash .
Anyway, a little background on the truck. I bought it in 2009 to be a daily driver. I got a pretty good deal on it because both axles and the transfer case were shot. The engine was also needed a water pump and a general tune-up. As far as the body goes it was in pretty good shape. It is the kind of truck that looks really good going down the road, but you're disappointed when you get close. The PO gave it a quickie paint job and it showed. It was originally a longbed that was shortened.
I had a heavy half 80 farm truck that I robbed the axles and transfer case off of before I sent it to the crusher. At that point I was driving it to work every day. Not long after that I ended up with a company car and the 72 became garage art, then yard art when the wife made me move it out of the garage.
The plan is to swap in a 5.3/4l60e. I've kicked the idea of changing from the stepside to a SWB. Then, a friend of mine that is building a 72 C10 with his son told me he wants the stepside bed, so I let that make my decision for me. Surprisingly I've already got a bead on a local SWB, but I'm not sure what kind of shape it's in.
Here are some photos of the truck when I bought it.
And the truck after about 8 hours (with help from the wife's brother) over the weekend.
Wish me luck.
Drew
Drew's 72 K10
85 k10 AKA "The Turd"
Rusty Shacleford is offline   Reply With Quote
Old 03-26-2013, 10:36 PM   #2
Rusty Shacleford
Re: Drew's 72 K10 Shortbed
BTW this is the end goal. I found this on the web.
Drew
Drew's 72 K10
Old 03-27-2013, 07:03 PM   #3
muddnutz
muddnutz's Avatar
Keep up the work. Looks good
1986 K-10 "ole blue"
muddnutz is offline   Reply With Quote
Old 03-28-2013, 09:32 PM   #4
mjensen
mjensen's Avatar
Done yet?
I does look like a great start!
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 03-28-2013, 11:27 PM   #5
Rusty Shacleford
Originally Posted by mjensen View Post
Done yet?
Thanks. I hope I can keep a little momentum going. My wife is already starting to throw out comments like, "you think you'll ever drive it again?"
Drew
Drew's 72 K10
Old 03-28-2013, 11:28 PM   #6
Rusty Shacleford
Thanks!
Drew
Drew's 72 K10
Old 03-28-2013, 11:44 PM   #7
mjensen
mjensen's Avatar
Ha ha! My wife just laughs at me when I tell her my goals on the truck
Mike
Old 03-29-2013, 12:43 AM   #8
bilfman
bilfman's Avatar
Looks great!
Most wives don't understand.
My wife tells me when I die...Funeral at 12 auction at 2.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 03-31-2013, 11:44 AM   #9
mjensen
mjensen's Avatar
Originally Posted by bilfman View Post
Looks great!
Ha that's funny!
Any new updates?
Mike
Old 03-31-2013, 11:15 PM   #10
Rusty Shacleford
Update time.
Well, after removing some brake lines, fuel lines, and the like I rolled the frame outside for some cleaning. Oh boy!
On one side we have Dad's 56 3100 watching... My brother claimed it long ago, but it ended up getting stored at my place. I ask him to sell it to me so often he's either going to give in or come get it. I'll call it a win either way
And on the other side... "The Turd"
The rattle can rubberized frame coating (or that's what I think it is) is coming off in chunks.
I have a little frame repair work to do hear... nothing major though.
Drew
Drew's 72 K10
Old 03-31-2013, 11:27 PM   #11
mjensen
mjensen's Avatar
Now that's what I call progress! Great job, also I like the other rigs as well :-)
Mike
Old 04-01-2013, 12:01 AM   #12
Rusty Shacleford
While the frame was drying in nice warm Good Friday sun (hard to believe there was 8 inches of snow on the ground just over a week ago) I went back inside the shop to do a little inspection on the cab.
The rockers and a couple floor/inner rocker patches were installed with pop-rivets.
Here's an overall view of the floor. Notice the old license plate used to patch the trans tunnel.
So, I drilled out the rivets on the driver side to get to the floor patches
Then removed the floor patches to find out what I was really dealing with... There's some work to be done, but nothing too bad.
Then I moved to the passenger side... Not as bad, but still some work to do.
Cab corners don't look too bad on the outside...
And the inside cab corners...
We'll see what the sandblaster reveals, but it will be a while before we get there.
Then I pushed the frame back inside after doing some much needed cleaning. It probably would have saved a lot of time if I'd found a home for parts as they were coming off, but what can I say...
I also did some cleaning on the NP 205 on Saturday, but forgot to take the camera. It was pretty dirty... and still has a little way to go to be clean. I'll post some after photos later.
Drew
Drew's 72 K10
Old 04-01-2013, 12:03 AM   #13
Rusty Shacleford
Thanks. The "free" part of the project is quickly running out. Time to start working on my sales skills with the wife.
Drew
Drew's 72 K10
Old 04-10-2013, 11:40 PM   #14
Chevymaniac
Hey your truck looks like mine, good from the outside until you take a look
under neath and than its a little scary.
I have a 69 stepside swb 4x4 and the patch works needs attention, but mine is just alittle worse so i"am looking for another cab.
I like the your truck in white, stands out nicely.
What size of lift and tires came with the truck?
Chevymaniac is offline   Reply With Quote
Old 04-11-2013, 12:16 AM   #15
69short
69short's Avatar
Looks like a fun build. I like the end goal.. Where in Missouri are you from?
69short is offline   Reply With Quote
Old 04-15-2013, 01:28 PM   #16
Rusty Shacleford
Yeah, when I saw it listed for sale online I was pretty excited. Of course, I knew there were some mechanical issues. When I got close to it I was disappointed. It did get plenty of looks when I was driving it though.
I like the white also, but since it is a local truck, I decided I want to go another direction (two tone fleet side).
It has a 6" lift. The tires are Mickey Thompson Baja ATZ 35x13.50 R20.
Drew
Drew's 72 K10
Old 04-15-2013, 01:32 PM   #17
Rusty Shacleford
Well, it is fun when I have time to work on it. I've been covered up at work lately and unable to do much. I am from the West Plains area of the Show Me State.
Drew
Drew's 72 K10
Old 04-15-2013, 01:40 PM   #18
Rusty Shacleford
Quick update...
I haven't been able to do too much work on the truck lately. Most free time has been devoted to the yard and garden. I was able to acquire a set of Mickey Thompson Baja ATZ's (the same as what is on it in the original photos) for about half the price of a new set. The have less than 1000 miles on them, the person I got them off of just wanted something different. I've also been kicking around the idea of farming out the sand blasting. I've done some in the past but nothing on this scale. I really don't care for the job, but it's cheaper to do it at home.
Drew
Drew's 72 K10
Old 05-02-2013, 09:34 AM   #19
Rusty Shacleford
Originally Posted by Rusty Shacleford View Post
Update time.
Ok, got the photos back on this post.
Drew
Drew's 72 K10
Old 05-02-2013, 09:38 AM   #20
Rusty Shacleford
Photos, part 1 of this post.
Drew
Drew's 72 K10
Old 05-02-2013, 09:41 AM   #21
Rusty Shacleford
And now, part 2.
Drew
Drew's 72 K10
Old 05-02-2013, 09:44 AM   #22
Rusty Shacleford
Sorry no updates yet, but I should have some updates soon, now that I've got the photos lined back out. I've been spending a lot of time outside lately, neglecting the truck.
Drew
Drew's 72 K10
Old 05-03-2013, 11:09 AM   #23
Daubs
Daubs's Avatar
Looks great!
Oh, wives understand, all too well. They want husbands to spend time with THEM, not with trucks. It's kind of funny, because I can tell when my wife is getting jealous when i spend time or energy on my daughters, and not her (she is their step-mom). And when i work on my truck, she throws out subtle and not-so subtle comments. So I do the same when she's spending energy on her iPad (and not me ), if it's good for the gander, it's good for the goose as well
Funeral at 12, auction at 2 is hilarious!
'72 Chevy K-20 Crate 350, SM465, 4.10's
Daubs is offline   Reply With Quote
Old 05-03-2013, 11:13 AM   #24
Daubs
Daubs's Avatar
Rusty, talk to me about having the frame sandblasted? Are you sending the rolling chassis to the blaster? Or tearing it down to just frame? I'm about to start my K-20 project and contemplating if i even want to touch the frame at this point(?)
Old 05-03-2013, 12:39 PM   #25
CUSTOM/10
CUSTOM/10's Avatar
"LOL" On the Ipad comment.... I recently bought my girlfriend one, and just last night I told her I was going to throw that thing out because she paid more attention to it than me.....
She is good about me working on the truck, but then she's my girlfriend, Not my wife !!!
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
