01-24-2013, 02:41 AM | #251 |
Re: 66 suburban build
hey Nobby, what are the make and model of those 20'' rims please I really like em! Good job on the build so far!
01-24-2013, 09:04 AM | #252 |
Nevermind I was wrong.
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
01-24-2013, 10:35 PM | #253 |
01-27-2013, 08:12 PM | #254 |
hey nobby the wheels are sweet,I have the coys on my 69 20x10 and 20x8.5 was wandering if you knew since i dont have my truck on my new frame will a 10 fit under the back of the burbs or maybe even a 22x9 under the rear
01-27-2013, 09:50 PM | #255 |
Well I haven't tried 20x10 yet but I borrowed a 22x9 and it fit like a glove..I aired it out and no rubs anywhere...I just can't remember the back space..
01-27-2013, 10:12 PM | #256 |
Wow, u need dat
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped 1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant |
02-01-2013, 04:25 PM | #257 |
chevy only
LOOKS GREAT!! if its a coy it maybe 22x9.5 4" back space i have had a few sets of them, not 100% sure , but 100% sure that you sub is bad a$$
CHEVY ONLY... Nothin Else ! |
02-01-2013, 06:14 PM | #258 |
02-08-2013, 10:17 PM | #259 |
Junior Member
Love it and the colors rock!
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
03-21-2013, 05:30 PM | #260 |
Made me a pattern out of 3/16'' plywood for my glass guy to cut me some glass for the rear 1/4..If anyone ever wondered if the forward 1/4 and rear 1/4 glass are the same...Well there NOT..I think the window rubber/gasket is the same but not the glass..
03-31-2013, 09:35 PM | #261 |
tanks for the window repay nobby you answered my questions on the windows keep up the work im still plugging along
03-31-2013, 10:54 PM | #262 |
Just here to tinker
Man that burb is one sweet machine.
Feel lucky you are going with solid windows because re-building the sliders are such a pita. Posted via Mobile Device
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
04-01-2013, 08:54 AM | #263 |
Thanks Cort...I rebuilt my front sliders...My frames were rusted out so I welded in some new channel.Got the rubber kit from Steele..I took on one at a time so I could go back and look at the other..I haven't spayed water on it yet,it might leak like a basket
04-01-2013, 09:43 AM | #264 |
04-14-2013, 11:02 AM | #265 |
chevy only
your sub makes me want to find another sub such nice work
04-16-2013, 08:51 PM | #266 |
05-02-2013, 08:51 PM | #267 | |
Keep the posts coming it keeps me going when the doldrums set in and I wonder why I started all this. Dewey Posted via Mobile Device |
05-04-2013, 11:48 AM | #268 |
Hey, can you tell us a bit about your brake setup please?
Thanks!
65' Chevy C-10 Shortbox |
05-04-2013, 01:49 PM | #269 |
I didn't want to go through the brake horror stories from my last build using a big cam engine (no brakes at idle), so I went to Tallon Hydraulics Inc. and had them build me a hydraboost system (call Butch and he will help you through the selection of the right unit for your application). He uses a new Wildwood master cylinder hooked up to the booster that is driven off the power steering pump rather than the vacuum set ups. I'm using a NASCAR style power steering pump that I had to make custom mounting brackets for but it gives me the insurance of higher PSI needed to run the power steering and brake units. With this type of set up you also get to use a remote reservior for the power steering which is nice when your running out of space on the motor to mount things. As for the brakes - CPP big brake disk set up front and rear. I also used their modular drop spindles. Porterbuilt is suppling the rest of the drop with their "A" arm coil spring front and mild air bag drop rear. Hope to have all the running gear installed this month then on to the body.
05-04-2013, 01:55 PM | #270 |
Got carried away with the description of what I'm doing and forgot to thank Nobby for the great pics and comments on his build. It has given me some great ideas and got me motivated to finish mine.
Dewey |
05-14-2013, 07:32 PM | #271 |
Thanks guys...We are cranking back up on the burbStarted blocking the liftgate and tailgate..I know it's not much but we gotta start back somewhere..
05-14-2013, 08:08 PM | #272 |
67-72 parts collector,…
This burb is going to be so nice!
05-14-2013, 09:58 PM | #273 |
Yeeeeeeaahhhhh...Getting it purdy Nobby!!!
My '65 Suburban Resto build-- http://smg.photobucket.com/albums/v6...65%20Suburban/ And it's story of being 'saved' http://www.jalopyjournal.com/forum/s...d.php?t=631495 |
05-14-2013, 10:44 PM | #274 |
Thanks Guys..I need them 4 access plates for the tailgate..If anyone has an old gate laying around there not gonna use let me know.. Thanks
05-15-2013, 05:55 AM | #275 |
65 suburban vortec 5.3 bagged
worst case just cut some flat sheet metal to fit them that is all the factory ones are the sub is looking great! keep up the good work maybe it will get me back on mine soon!
