04-08-2013, 07:11 PM | #1 |
late dually wheels to 83 1 tonner ?
i have a 83 chevy car hauler -1 ton -c-30-i would like to put some later 90s -wheels w/fancy rings and caps -whats needed ?i was told to just buy some adapter nuts ? where ? OR will the 2012 year -17" wheels fit ? also what nuts and so forth ?anybody done either ? thanks mike
04-08-2013, 07:13 PM | #2 |
67-72 parts collector,…
Re: late dually wheels to 83 1 tonner ?
2011-up 3/4-ton and 1-tons have a different bolt pattern.
04-08-2013, 07:16 PM | #3 |
thanks for the info-i looked at a 2012 on dealers lot -they did look like a wierd bolt pattern !guess im back to the 90 abd newer styles !
04-08-2013, 07:26 PM | #4 |
2010 on back, should be the same bolt pattern.
04-08-2013, 09:19 PM | #5 |
Regarding lug nuts, look for 9/16" conversion lug nuts. They will look like the newer lug nuts with the external threads but have a 9/16" center instead of M14. The external threads are used by the center cap retainers.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
04-09-2013, 10:55 AM | #6 |
Be aware of some other wheel info, the center hub bore diameter is larger on new style wheels causing wheels to run off center. You can fix it by using a "Hub Ring" or just checking the wheels before you purchase them.
Here is some helpful info... 76-2000 Hub Bore is 4.56 / wheels are 8 X 6.0 01-2007 Hub Bore is 4.60 / wheels are 8 X 6.5 Desert |
04-09-2013, 11:21 AM | #7 | |
Charlie Daniels w/ a Tq Wrench
True, but having a machine shop drill out the correct pattern is not a big deal at all, but keep in mind the hub bore diameter.
It WILL be an issue if he used 8x6.5" Ford wheels with a 4.88" bore, older Dodge with a 4.75" bore, or newer Dodge with a 4.78" bore, although with those sizes, a hub ring would be feasible to machine. If you just want the "fancy rings and caps" just put them on your wheels. As 83GMC mentioned; just get the correct conversion dual threaded lug nuts, IIRC McGard produces them, in 9/16 with the external threads. Then just thread on the newer caps, and pop on the rings to your existing wheels.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
04-09-2013, 06:17 PM | #8 |
THANKS EVERYBODY !! i knew somebody would have the answer !! now to find some wheels -seems like -there hard to find ?? thanks mike
