#51 |
Re: HOW TO: Crossmember sectioning ...
Thanks for taking the time to write this up!
Posted via Mobile Device |
#52 |
Hollister, CA.
![]() Join Date: Sep 2006
No problem ...
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
#53 |
Wow.... Really nice job Chief as usual..read a couple of yourt projects just never posted... Just went and bought a bunch of cutoff wheels and am going in after reading this. Will definitely be bookmarking this one for a reference. Thanks again
My frame Layin 63 short bed project ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=551353 |
#54 |
Very nice write up, thank you!
"I feel the need for speed!"... as soon as I am done with my nap. |
#55 |
Hollister, CA.
No problem guys, my pleasure.
Hopefully, the steering will get my attention soon. Posted via Mobile Device
#56 |
Hollister, CA.
I took a few pictures of the crossmember, with the stock front suspension complete dropped (no coils) for some reference of clearances. Tire is a 215/65-15 (26" Diameter) ....Stock spindles.
(NOTE: V6 engine rear crossmember sitting on floor) - - ![]() - - ![]() - - ![]() - - ![]() - - ![]() - - ![]() - - ![]() - - Otherwise Stock, with coils removed: - - ![]()
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 04-12-2013 at 12:24 PM. |
#57 |
Doing mine now!! Using this thread as my guide!!!
Thanks Jason |
#58 |
Keepin it old school
Your burb looks so cool sitting that low. I spy a slick Impala in the background too
#59 |
Square
Great work!
Squarebody Syndicate |
#60 |
You are the man! Gonna look for a doner x-member to do this now! Are you gonna brace behind the upper control arm? Those two holes used to have frame behind them right? Think this is going to flex too much? Just rebuilt my whole front end too...darnit!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#61 |
oops
#62 |
Hollister, CA.
Thanks guys ....
Yes, the plan is too add some material behind the towers. This will also give me the spacing need to run factory engine mounts. I assembled this with just a few fasteners just t get it out of my home garage. It will all get blown apart after steering mockup ...
#63 |
![]() Join Date: Apr 2010
yeah thank you very much for passing this on. I just finished putting my front suspen together using this method, turned out great. I also found some bag cups that I welded in to give me more travel. Now I'm having to deal with the steering, because of the added travel my steering shaft is hitting my control arm, anyone have any ideas?
#64 |
Nice!!!! Lots of win here and lots to think about going forward...
#65 | |
#66 | |
Posted via Mobile Device Posted via Mobile Device |
#67 |
I found a couple pics of Dinos truck where he raised his steering.
![]() ![]() ![]() Posted via Mobile Device |
#68 |
#69 | |
![]() Join Date: Mar 2005
http://michiganmetalworks.com/store/...&product_id=79
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#70 | |
#71 |
Junior Member
![]() Join Date: Oct 2007
Any updates on the steering yet.
Thanks!! |
#72 |
#73 |
Anybody have a pic of the steering interference? Im out side looking at my uncut crossmember and Im not seeing it. Looks like the inner tie rod ends will clear the frame and uppers. I have the stock 87 steering and crossmember with my stock '62 steering box and 87 idler arm.
Project Change of Plans: http://67-72chevytrucks.com/vboard/s...d.php?t=513135 '62 C10 SWB '03 Express Van 5.3l Dead (parting out and using motor) '99 Silverado 4.8l 5 speed 4wd |
#74 |
Hollister, CA.
The steering will have to be raised.
I have been to busy with customers ride to even have time to get back on Burban. The set-up on Dino's ride is pretty much what has to be done.
#75 |
motor exploder
Just when I thought I had seen all the cool write-ups on this forum, I run across this! Awesome work ChiefRocka and THANK YOU for taking the time to do this!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
