Old 04-12-2013, 07:50 PM   #1
donthekawguy
donthekawguy's Avatar
question about 4 inch lowering in rear
Do I need to get a shock re locator kit with 4 inch springs? All I could find was an article about 6 inch drop springs.
66 shorty
donthekawguy is offline   Reply With Quote
Old 04-12-2013, 08:00 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: question about 4 inch lowering in rear
Yes you do and an adjustable rear track bar. shorter rear shock monroe pn-32207
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-12-2013, 08:20 PM   #3
donthekawguy
Dang this is getting spendy!
66 shorty
Old 04-13-2013, 09:31 AM   #4
da_bears_da1
I agree. I am going to drop my rear 5 inches. Based on numerous recommendation on this forum, I am going to order it from Early Classic Enterprises. They have a full kit that includes Rear Coils, Super Track Bar Kit, Shock Mount Relocator Kit and 2 KYB Shocks.
Jeff
Simplify Life!
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=566533
da_bears_da1 is offline   Reply With Quote
Old 04-13-2013, 11:20 AM   #5
66redw/white
made in america
66redw/white's Avatar
i have 5 inch drop springs. nothin else. that bein said i do want a new track bar but she rides like a caddy without it. no inter-fearance anywhere
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes.
sounds good
1964 c10-283 powerpack, 3 on the tree
2004 corvette- lowered, borla, tuned. slow
my old girl
1966 c10- 305v8, t-5 sold
66redw/white is offline   Reply With Quote
Old 04-13-2013, 11:25 AM   #6
Clyde65
Clyde65's Avatar
I dropped mine 4" and only put an adjustable track bar and drop shocks. i was told the relocators are needed in 5+" drops, is that not correct?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-13-2013, 03:49 PM   #7
donthekawguy
I read that the shocks should be no more than 15 degrees. Not sure what they would be at with a four in drop. But in case I want another inch I'll install the kit and see how it looks and rides. BTW Summit has the shocks on sale for 20 bucks each so if you want to get a few extra sets now is the time.
66 shorty
Old 04-13-2013, 05:45 PM   #8
Rich 5150 69
Angle of the Dangle...... this thru KYB 4x4 review site
Mounting shocks at angles reduces the overall dampening effect of the shock. Reason being; the shock’s mechanisms will travel geometrically, less of a distance than that of the suspension system. Some vehicles (early model Land Cruisers, etc.) have their rear shocks mounted at about a 30-degree inward (inward = leaning toward the differential, not forward or aft-ward) angle, while others have their shocks mounted at a 20 degree angle or so forward and/or aft ward of the rear axle (e.g. Chevy, Jeep CJ’s, etc.). There are several reasons why this might be done. First, available space… regardless, if this is something you are going to do yourself, you’ll need to increase the static pressure of shock to mimic the shocks effectiveness of it being in a perpendicular location. Secondly, you can gain more suspension articulation than would normally be limited by the overall travel of the shock absorber if it were located perpendicular to that of mounting your shocks at an angle, if you don’t have room for a taller shock absorber. The charts here show the overall estimated reduced effectiveness of a raked shock absorber. However, these numbers should only be used as a rule of thumb as other factors such as the arc of the suspension cycle can factor in.
A four inch drop at stock location means the shock is at a 42 degree angle without a load....
Old 04-13-2013, 07:21 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
That shock is 15 dollars everyday price at Rock Auto
Tx Firefighter is offline   Reply With Quote
Old 04-13-2013, 08:46 PM   #10
donthekawguy
Dammit!
66 shorty
Old 04-13-2013, 09:07 PM   #11
Rich 5150 69
I bought monroe pn - 32207 for my lowered truck, 4 inch drop on line ebay, $24.00 delivered to my door..
Old 04-13-2013, 09:23 PM   #12
Trsmotrhed
Trsmotrhed's Avatar
For what it's worth, I installed 4" rear drop coils and also did the shock relocation bracket along with the longer trac bar. Rides so much better now. There are so many opinions on this. Do what your budget will allow . The rear of our trucks bounce anyway . Hey, post a pinion angle question and see what you get.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline   Reply With Quote
Old 04-13-2013, 09:25 PM   #13
Tx Firefighter
Dammit!
Don't beat yourself up. We've all done it.
Old 04-13-2013, 09:33 PM   #14
Tx Firefighter
Smart guy here.
Guys lowered many thousands of these trucks well before anyone ever made shock relocators or adjustable track bars. I had several dropped 6 in the back with my only mod being installing front shocks on the back since they were shorter. The shocks were laid over like hell with the truck that low. And the rear ends were surely not centered. Only later did folks start doing it textbook properly.
Old 04-14-2013, 01:04 AM   #15
donthekawguy
I used to cut the springs on everything I owned. I had a huge caddy so low I would rip the tranny pan open about once a month. It had a bent pushrod so I pulled the rocker off and the pushrod out and drove it like that for a year or so before selling it. Ahh to be young and dumb! And broke.
66 shorty
Old 04-14-2013, 08:17 AM   #16
brokenspoke
brokenspoke's Avatar
I usded the shock relocators from CCP at first....didnt work well...I then bought the relocators from No Limit.....the kit was $149.... money well spent....
brokenspoke is offline   Reply With Quote
Old 04-14-2013, 09:37 AM   #17
Rich 5150 69
Upper shock mounts about 6 bucks...
Old 04-14-2013, 09:42 AM   #18
1964Chevy
1964Chevy's Avatar
Thanks Rich, that's what I was looking for, a picture.
If your strength is small, don't carry heavy burdens. If your words are worthless, don't give advice. Chinese Proverb
1964Chevy is offline   Reply With Quote
Old 04-14-2013, 09:46 AM   #19
Rich 5150 69
Rear track bar from POL http://www.performanceonline.com/60-...on-components/
Springs from Cpp are cheapest, and shocks off ebay, he should be able keep this under 200.00
Old 04-14-2013, 10:30 PM   #20
donthekawguy
What was wrong with the kit you got? I got the 60 dollar kit from brothers I think. All the 60 dollar kits look the same and the CCP site isn't user freindly enough for me to use.
66 shorty
Old 04-15-2013, 07:22 AM   #21
brokenspoke
The shock was still at way too much of an angle.....No Limit works great
Old 04-15-2013, 07:56 AM   #22
Clyde65
Clyde65's Avatar
So with the No Limit kit, do you use stock shocks?
Clyde65
Rebuild of Clyde
support our troops!
