Old 04-14-2013, 07:41 PM   #1
way2lo2
way2lo2
way2lo2's Avatar
How to on our inexpensive airride kit
Guys I just wanted to thank you for all the support over the last couple years.
I get alot of the same questions about our airride kit for the 63-72 C10's so I thought I would answer them here along with a how-to. Our Basic $1000 complete 4 way airride kit gets the job done but most guys will opt for some extras like 2.5" drop spindles, lowering blocks, shock relocators, etc.
What we're working on is a bone stock 65 C-10 so follow along as we transform the suspension in about 14 hours from start to finish. Here is the truck last friday when we purchased it at the Charlotte Auto fair.
Dealer for Billet Specialties, Ridetech, Airlift, Vintage Air and others. Feel free to call, email, or PM for a quote.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Way2Lo2@aol.com <----also my paypal
http://www.hubgarage.com/mygarage/way2Lo2
way2lo2 is offline   Reply With Quote
Old 04-14-2013, 07:47 PM   #2
way2lo2
way2lo2
way2lo2's Avatar
Re: How to on our inexpensive airride kit
for some reason the rear axle saddles were a little thin where the u bolts go through so a little repair was in order before we started the air suspension.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 04-14-2013, 07:59 PM   #3
way2lo2
way2lo2
way2lo2's Avatar
The rear coil springs were on bolted and a template was made to locate and drill in the bottom of the frame, the same bolt pattern that is in the top of the air bag along with a hole for the air fitting to go through . No cups or brackets are used in the rear to locate the air bag. We also welded in a small c notch, we offer bolt in versions as well. In this picture you can see we added a 2" lowering block to get the rear axle into the c notch with the bags deflated.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 04-14-2013, 08:05 PM   #4
way2lo2
way2lo2
way2lo2's Avatar
on the front we disassembled the front suspension enough to remove the coil springs and the factory bump stop pads/turning stops. These must go to get a decent drop. The upper and lower mounting plates are positioned on the bottom of the crossmember and the top of the lower control arm, the holes are drilled and everything is bolted together.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 04-14-2013, 08:09 PM   #5
way2lo2
way2lo2
way2lo2's Avatar
The first photo shows bump stop mount we removed. You can see that we added a disc brake conversion with 2.5" drop spindles to get the truck a little lower and stop better at the same time.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 04-14-2013, 08:13 PM   #6
way2lo2
way2lo2
way2lo2's Avatar
The tank was mounted on the rear crossmember nas we don't plan to run a spare on the truck. There is room on the sides of the frame rails incase you want to keep your spare. We also mounted the compressor on the rear passenger side to keep the noise in the cap to a minumum.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 04-14-2013, 08:18 PM   #7
way2lo2
way2lo2
way2lo2's Avatar
I didn't get a chance to take a pic of the gauges and controls but I'll do that tomorrow. Here is what it looks like done after 14 hours which includes a dual master cylinder and replumbing the brake lines. Best of all done basically with common hand tools.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 04-14-2013, 09:06 PM   #8
jmedero
jmedero's Avatar
Nice work borris.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 04-14-2013, 09:09 PM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
Thanks for the write-up!
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 04-14-2013, 09:40 PM   #10
oldman3
oldman3's Avatar
Big difference, looks great...Jim
oldman3 is offline   Reply With Quote
Old 04-14-2013, 10:05 PM   #11
jd7
jd7's Avatar
I just went to your site and could not locate this kit ...... found one for $ 1400.00
jd7 is offline   Reply With Quote
Old 04-14-2013, 10:09 PM   #12
way2lo2
way2lo2
way2lo2's Avatar
It's for forum members
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 04-14-2013, 10:31 PM   #13
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
great work.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 04-14-2013, 10:41 PM   #14
darkhorse970
darkhorse970's Avatar
Very nice change in the trucks overall look!
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 04-15-2013, 01:16 AM   #15
YBNORML
YBNORML's Avatar
Nice work, and a good kit for a nice price.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 04-15-2013, 01:30 AM   #16
broey
Square
broey's Avatar
Hey Borris, nice write up! Truck came out good!!
Squarebody Syndicate
broey is offline   Reply With Quote
Old 04-15-2013, 10:07 AM   #17
SCOTI
SCOTI's Avatar
Amazing what the right stance & rolling stock choice can do for a vehicle.... Well done. This is 'Flip-It 101' @ it's core.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 04-15-2013, 10:16 AM   #18
T Smith
T Smith's Avatar
Nice write up and pictures! Great looking truck too!
What is bit thing that you used to bore the large airline holes in the frame? I drilled mine using progressively larger bits up to 1" and man did that kick my ass, those old frames are tough to drill through even with good quality bits. Laying on my back in the driveway all contorted has a lot to do with it as well.
Any benefit to using those bottom plates vs cups?
Looking forward to pics of the gauges and controls..
T Smith is offline   Reply With Quote
Old 04-15-2013, 10:51 AM   #19
way2lo2
way2lo2
way2lo2's Avatar
Scoti, sold it friday, 7 days from purchase in NC to sale in OH
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 04-15-2013, 10:55 AM   #20
way2lo2
way2lo2
way2lo2's Avatar
The hole saw we use is called Roto-Kut and they work great. No huge advantage to the plates other then a flat surface that doesn't move around.
I'll post controls tonight.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 04-15-2013, 11:21 AM   #21
N2TRUX
Happy to be here
N2TRUX's Avatar
BAM! Now thats what it takes to increase the resale value of a classic truck. I love it when guys comment that your hacking a classic and decreasing the value by bagging a truck. My guess is that you made a nice little profit and one very happy customer....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-15-2013, 12:12 PM   #22
way2lo2
way2lo2
way2lo2's Avatar
[QUOTE=N2TRUX;6013042]BAM! My guess is that you made a nice little profit and one very happy customer....
Absolutely!
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 04-15-2013, 01:48 PM   #23
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Thanks for taking the time to do the write up Boris. Another great ride rolling out of your shop.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-15-2013, 06:19 PM   #24
way2lo2
way2lo2
way2lo2's Avatar
our kit comes with a panel that has the paddle valves mounted and plumbed to the 2 dual needle gauges as shown in the first picture but we can also supply a paddle panel to mount the paddles remotely as we did in our truck and you can mount the gauges where ever you would like. Someone in the past had cut our dash for some sort of switches that weren't hooked up to anything so we went ahead and put the gauges there.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 04-15-2013, 06:30 PM   #25
broey
Square
broey's Avatar
looks good!
