Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 03-10-2013, 02:01 PM   #126
jc70chevy
jc70chevy's Avatar
Re: 72 Suburban Started
great build
jc70chevy is offline   Reply With Quote
Old 03-14-2013, 01:59 PM   #127
Bud1300
Bud1300's Avatar
Update: I have the axel and trailing arms out, cleaned and painted them last weekend and the blocks and u-bolts are in as well as the trailing arm bushing. I will install them in a couple of weeks when I get back from Las Vega. Leaving tomorrow on a company trip 1st time every going. Anyone from the area that can give any suggestions of what I need to visit while there please let me know.
Bud1300 is offline   Reply With Quote
Old 04-08-2013, 02:52 PM   #128
Bud1300
Bud1300's Avatar
Rear notch is in and painted, rearend, trailing arm, 2" blocks new u-bolts and air bags are installed, so today I order some parts today to get the Fatty Natty on the road.
1 VIAIR 480 COMPRESSOR
5 GALLON BLACK 8 PORT TANK WITH 1/2" PORTS
4 SMC 1/2” VALVES
4 SMC 3/8” VALVES
AVS 7 SWITCH BOX (YOU CHOOSE COLOR)
165/200 PRESSURE SWITCH
VIAIR HIGH AMP RELAY
2 DUAL NEEDLE AIRLIFT 200 PSI GAUGES
1 SINGLE NEEDLE AIRLIFT 200 PSI GAUGE
50’ OF SMC 1/2" DOT AIRLINE
50’ OF SMC 1/4" DOT AIRLINE
1/2 type K copper
3/8 type K copper
Brass fittings
Both front fenders
Front bumper
Battery box
Complete SS fuel line
Complete SS brake lines
Carrier Bearing
3- drive staft u-joints
Complete Steel (in frame) gas tank
Core support with Hardware
I will be 2nd 5 gallon air tank and compressor as soon as I get it driveable.
More Photos coming soon.
Old 04-08-2013, 03:41 PM   #129
kev2809
low n' slo
kev2809's Avatar
nice parts list!
whar are you using for the rear floor and tubs?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 04-08-2013, 03:49 PM   #130
bcubed
bcubed's Avatar
Not sure, we are going to build a new floor .. raised if necessary .. the intent is to hide everything under it but still make it accessible.
2000 Bagged Silverado
1978 Chevy Malibu
1955 Apache Stepside (someday)
bcubed is offline   Reply With Quote
Old 04-08-2013, 03:51 PM   #131
bcubed
bcubed's Avatar
Here's the latest picture (with the old sheetmetal)
1978 Chevy Malibu
Old 04-08-2013, 04:27 PM   #132
kev2809
low n' slo
kev2809's Avatar
looks good laid out!! what are you going to do with the stock rear fuel line to the gas tank? im trying to address some issues with all the stock hosing and stuff back there before i take it around the block.
you can see in post 120 pic #2, it ends up going to the middle of the axle. is it going to stay like that, or are you going to bend it around the notch? trying to figure out some ideas because im working on that now...
-_--_--_ _________
Old 04-09-2013, 03:00 PM   #133
Bud1300
Bud1300's Avatar
I ordered the 2 piece SS fuel lines kit but I will have to cut it off and use A.N fitting and ss braided fuel line to the tank not real sure untill I reach that point, I am thinking about building the floor from 3/4 angle with raised floor and 1/2 hard wood flooring for the rear floor but 100% sure yet. I have a lot of ideas but no fixed plan...
Old 04-09-2013, 05:14 PM   #134
made2drag
made2drag's Avatar
guys, there is a show at the montgomery riverfront on saturday...it's the 1st annual show so not sure how big it will be.
http://www.montgomerystreetrods.com/
and you probably know about these. http://www.montgomerystreetrods.com/...ing_events.php
made2drag is offline   Reply With Quote
Old 04-09-2013, 09:15 PM   #135
kev2809
low n' slo
kev2809's Avatar
too far from texas made2drag..
i just ordered that same brake kit but in oem..i think i will leave it going across the axle like this, then mount it to a tab i will weld to the stock brake tab on the axle...not pretty by any means but it should be functional and covered up by the floor.
-_--_--_ _________
Old 04-09-2013, 09:53 PM   #136
kev2809
low n' slo
kev2809's Avatar
Scratch that...im gonna bend it along the notch and attach another bent up line around the rest of the notch and connect the 2 with a very small hose...then connect the hose from the tank to end of the line. Dumb idea above....lol
-_--_--_ _________
Old 04-10-2013, 11:54 AM   #137
Bud1300
Bud1300's Avatar
It is from 3 till 6 and then they will have the 2nd Saturday event, 80,s cover band till 10pm, 6 local car clubs are working on getting vehicle there. I was thinking about going but I will have to load the Camaro on the trailer Its not real streetable due to 411s on 15 x 12 x 27" tires and a large stall 3500 rms at 55 mph..
Old 04-11-2013, 03:50 PM   #138
made2drag
made2drag's Avatar
if it's from 3-6p looks like i wont be going. my daughter has a softball game in eclectic at 3.
Old 04-12-2013, 03:57 PM   #139
Bud1300
Bud1300's Avatar
I will post some photos of the show.
Old 04-12-2013, 11:29 PM   #140
jmedero
jmedero's Avatar
Nice work man. Looking good.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 04-15-2013, 12:27 PM   #141
Bud1300
Bud1300's Avatar
Riverfront was a good show about 100 cars / trucks attended, this was the 1st show the City of Montgomery has put on the Camaro won top 25. Ran into another member (Madetodrag) at the show and Bcubed will need to post photos of the event.
Old 04-16-2013, 01:26 PM   #142
bcubed
bcubed's Avatar
Here's the link to the show this weekend
https://www.facebook.com/media/set/?...1&l=22306aa669
1978 Chevy Malibu
Old 05-02-2013, 07:44 PM   #143
made2drag
made2drag's Avatar
ya'll going to the monthly gold star show on sunday? we started a little club and plan to be there around 2p...
Old 05-22-2013, 05:20 PM   #144
Bud1300
Bud1300's Avatar
Updateed Photo
Old 05-23-2013, 10:23 PM   #145
project 67 sub
project 67 sub's Avatar
looking good
project 67 sub is offline   Reply With Quote
Old 05-23-2013, 10:40 PM   #146
kev2809
low n' slo
kev2809's Avatar
I like!
-_--_--_ _________
Old 05-29-2013, 11:41 AM   #147
made2drag
made2drag's Avatar
love the grill...that thing is looking mean!
Old 06-03-2013, 06:33 PM   #148
fastnlow
fastnlow's Avatar
looking good man
Jim
fastnlow is offline   Reply With Quote
Old 08-20-2013, 09:38 AM   #149
bondo510
What are you going to do one the drivers side where the rust is in front of the rear wheel?
bondo510 is offline   Reply With Quote
Old 10-29-2013, 03:46 PM   #150
Bud1300
Bud1300's Avatar
Inter structure is not too bad, just going to cut out the cancer and I have a truck panel that I am going to cut up and use. It is not the same but I will make the needed changes to make it work. I have been ordering parts and next month I will get back started on the build.
